60-1
Old Jan 11, 2004 | 07:50 PM
nY's FiNeSt's Avatar
Default 60-1
Alright i've been researchin the t60-1 the past few days and i just need a few comments from you guys.
Here's the plan:
stock b18b
t60-1
drag manifold
drag fmic
drag piping
hondata s200
rc550 injectors
Now my question is, will i benifit from having a 60-1 on a stock LS ? I've talked to some people and they've said i would not because of the later spool on the 60-1 i will not see much spooling time and will have to shift soon.
Am i better off with just going with a t3t4 ?
Please help me out, thanks John
Old Jan 11, 2004 | 08:26 PM
InTeGrA B18b1's Avatar
Default Re: 60-1 (nY's FiNeSt)
first of all how much power you gonna make? built? teh turbo probaly wont be efficient until 12 psi. WIth this turbo your probaly gonna need to rev to 75 or 8. Get the t3 t4 if you going to want only 250 ish.
Old Jan 11, 2004 | 08:29 PM
xxxmikenicexxx's Avatar
Yeah, dont go with the 60-1 unless you want lots of lag, even though it will give you great top end.
Old Jan 11, 2004 | 08:34 PM
DIRep972's Avatar
Smarter than you
A 60-1 is just a style of compressor wheel. You can get it in a T3/T4 or a strait T4. For a stock LS you are probably better off w/ a smaller compressor wheel if u want a more broad power curve.
Old Jan 11, 2004 | 08:41 PM
Default Re: 60-1 (InTeGrA B18b1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InTeGrA B18b1 &raquo;</TD></TR><TR><TD CLASS="quote">first of all how much power you gonna make? built? teh turbo probaly wont be efficient until 12 psi. WIth this turbo your probaly gonna need to rev to 75 or 8. Get the t3 t4 if you going to want only 250 ish.</TD></TR></TABLE>
i want to make 300 whp
eventually built block but for now stock internals
Old Jan 12, 2004 | 04:09 AM
Old Jan 12, 2004 | 07:55 AM
DLB1994's Avatar
your better off with a t3/t04e 57trim there good up to 400-440whp and will spool much faster then a 60-1
why buy a turbo thats good for 500-600whp and never see that kinda power
some vtec motors can make up for buying over sized turbos because they rev so far and still make a aright power band but if you have a engine thats peaking power at 6500-7000
Whats the point of having a turbo that spools at 5500rpms?
Old Jan 12, 2004 | 08:05 AM
Bnjmn's Avatar
Default Re: 60-1 (DLB1994)
Guys...a T3/60-1 won't spool much differently than a T3/T4 with a similar turbine A/R. Why? Because they have the same exhaust wheel. What almost wholly determines lag? Exhaust wheel size.
A T3/60-1 will spool a couple hundred rpm at most slower than a T3 and offer a bit more on top.
The 60-1 used to be the turbo, now it just doesn't get any love. It doesn't seem to care and still puts out big numbers.
However, in this case, if you only want 300, I'd go small. Real small. Like T3 super 60 or a 50 trim T3/T4.
Ben
Old Jan 12, 2004 | 08:16 AM
Default Re: 60-1 (Bnjmn)
^^^ very good info.
i don't plan on just making 300whp, that's just my first goal then after i'm built who knows. but i just wanted to reach the 300 level then see where i go after that. i don't want to jump the gun, make 500whp then kill myself, so i'll make small stepping stones for myself
Old Jan 12, 2004 | 01:48 PM
bump
Old Jan 12, 2004 | 03:21 PM
anyone else?
Old Jan 12, 2004 | 06:53 PM
need more feedback
Old Jan 13, 2004 | 10:46 AM
ttt for the last time
Old Jan 13, 2004 | 11:47 AM
kevinoneill's Avatar
Bump for you!
Just wanted to add to make sure you put some work into the suspension of the car and chassis, and don't forget the brakes. I couoldn't find any info on other mods on your car. It's no good to be able to hit 75 in 2 secs if you can't slow down just the same. Just some food for thought.
My personal opinion of the 60-1 is thats its just too big for most applications. Sometimes i think its considered more for a bragging right than anything else. I'd much prefer a turbo that gives more of an even power-band than a spike. Goodluck, I'm researching the turbo scene too for my b16a crx.
Cheers.
Old Jan 13, 2004 | 03:45 PM
Default Re: 60-1 (issues4)
yes my suspension is sitting stiff right now. GAB springs, gsr front tower bar, suspension techniques front and ( soon to be ) rear sway bars, 15' rotas wrapped in falken ziex 205/50/15's. So suspension is decent for now. A brake up grade will come in the near future.
thank you for the feedback, i am leaning toward just getting a t3t4 to have a nice all around powerback since it is daily driven, but i will see, 60-1 sounds berry berry nice
Old Jan 14, 2004 | 05:27 PM
Garcia-Racing's Avatar
T3/T4 sounds right and you should be able to pull about 400whp.
Old Jan 14, 2004 | 06:51 PM
Default Re: (TGARCIARACING)
since your gonna build your motor just get the 60-1 then. raise your rev etc get that extra power. Im guessing since you ask for our opinions that you already kinda wanted the 60-1. Do what your heart desires.
Old Jan 14, 2004 | 06:54 PM
Short Round's Avatar
Default Re: (InTeGrA B18b1)
just remember
when i gave u a ride
that was 12.5 psi........
not even close to maxing out the t3/t4e....
no offense but i dont think u realize how fast 400 whp is... it will be plenty... do what i told u to do
Old Jan 14, 2004 | 07:02 PM
Default Re: (Short Round)
^^^ none taken, but yes i do remember hehe.
thank you for all the helpful advice guys, the t3/t4 i think will suit my set up better
Old Jan 14, 2004 | 08:39 PM
ekb18c's Avatar
Default Re: (nY's FiNeSt)
t3/t4 with a 60-1 wheel... How about that? (2.5 inch inlet on the compressor)
I believe turbonetics calls it the hi-fi.
boostincoupe
Feb 6, 2006 02:31 PM
pjhatchin
Jul 25, 2005 08:11 AM
speedy108
Aug 19, 2004 11:39 AM
93B17A
Jul 1, 2002 08:23 AM
