450cc ject install
Old Dec 7, 2003 | 11:06 AM
shortyz's Avatar
Default 450cc ject install
guys ive searched and everyone is using stock seals..
now i have been told u have to use the Z6 seals because they are taller and the tip length will be to long if you dont use those seals.. is this true???
everyone tells me something different every day..
i need a straight answer..
Old Dec 7, 2003 | 11:07 AM
Johnyquest's Avatar
Default Re: 450cc ject install (shortyz)
Just lube them up with some vasaline (top o ring and bottom), put them in place, and tighten them down. They will slide right in, don't worry about it, it's not an exact science, they just have to be in the holes.
Old Dec 7, 2003 | 11:28 AM
legendboy's Avatar
Default Re: 450cc ject install (Johnyquest)
use a hammer
Old Dec 7, 2003 | 11:34 AM
shortyz's Avatar
Default Re: 450cc ject install (legendboy)
i am asking about how much the tip of the injector pokes out.. its quite important..
use a hammer? wtf are you smoking ill use a hammer on you
Old Dec 7, 2003 | 12:30 PM
Cruiser G's Avatar
I just used the stock seals on my d16y8 and it works great. But for them to fit right you should bore out the seals just a little. I just bored a little, then test fitted, then bored a little more, etc.
shortyz's Avatar
Default Re: 450cc ject install (Cruiser G)
yeah i know the bore out part.
Old Dec 7, 2003 | 12:46 PM
rocket256's Avatar
Hey bro. I dont know if this will help you out but check it out!
http://homemadeturbo.com/tech_....html
Old Dec 8, 2003 | 12:39 PM
legendboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyz &raquo;</TD></TR><TR><TD CLASS="quote">
use a hammer? wtf are you smoking ill use a hammer on you </TD></TR></TABLE>
hahaha as long as the injectors are seating and there all about the same hight they shouldn't leak. I have seen dsm's only pressed in a bit and there fine. So it's not really that critical.
Zaridar
Nov 16, 2018 08:31 PM
CAM0FLAG3
Paint and Body
Jan 14, 2009 06:45 PM
W O T
Mar 30, 2005 05:59 PM
huntarrr
Jan 22, 2005 07:10 PM
pelotudo
Sep 27, 2002 01:48 AM
