Installing DSM 450cc's, WTF do I do!!??
Old Sep 26, 2002 | 05:54 PM
pelotudo's Avatar
Default Installing DSM 450cc's, WTF do I do!!??
What do I have to do to get these to plug in right? I know the clips will work, and I wont need resistor packs...but what do I do w/ the orings. What ones do I use (For like an 88-89 integra?), and then just dremel them out a little bit? Will they sit okay, and just tighten the hell out of the fuel rail and they'll be good?
jB
Old Sep 26, 2002 | 06:52 PM
MiraiZ's Avatar
Default Re: Installing DSM 450cc's, WTF do I do!!?? (PeloTudo AKA Gringo)
jB
get new rings and seals (stock ones should do) ...there are several approaches in getting the rings seated....most choose to bore out with a dremel, some use brute force, some sand down the injectors...while others by aftermarket seals with a larger bore. At any rate...just make sure that they are new...
[Modified by MiraiZ, 1:36 PM 9/27/2002]
Old Sep 26, 2002 | 06:54 PM
pelotudo's Avatar
Default Re: Installing DSM 450cc's, WTF do I do!!?? (MiraiZ)
Okay. Just ask Discount/Pep Boys for rings/seals for an 88 Civic H/B; and then dremel them out a little bit? How much to dremel, or will I know when I try to put them around the 450's?
I think I might like the brute force approach
jB
Old Sep 26, 2002 | 07:00 PM
inspyral's Avatar
Mine went right into my D16Y8. It was a tight squeeze, but I didn't do anything to the injector seals/o-rings. I just put the injectors in thea rail, lined em up and positioned them one-by-one, and tightened down the nuts on the rail gradually until they were all in and the rail was completely tightened down.
Old Sep 27, 2002 | 12:04 AM
ion_four's Avatar
jB
Just buy them at the dealer...this seems like the kind of part that a parts store would not have in stock. I think they are like $5 a piece, though...I bought new ones, then bored out my old ones...after I was sure they were working I just returned the unused new ones.
Old Sep 27, 2002 | 01:48 AM
liam821's Avatar
25 Year Member
Default Re: Installing DSM 450cc's, WTF do I do!!?? (ion_four)
jB
i personally just PUSHED LIKE A BITCH!!! Then i bolted the fuel rail down and screwed it tight...works great
liam
hxtasy
Oct 15, 2006 11:24 PM
turboteg2nv
Aug 27, 2004 01:19 PM
arjusmc
Jan 20, 2003 06:45 PM
RAWB
Dec 21, 2002 05:37 PM
