ID1000 o-rings. Are they necessary to use, or are there other options?
Not sure where to post this... My friend is putting ID 1000s in his 98 b18. What lower o rings/ injector seals do we need? It's a sloppy fit as is... Thanks
So there is a seal in there now. I suppose it's not really an o ring.. But they are loose on the 1000s. What's the PN for the ones u use. Maybe try are just worn/ streched??
Who is Mr Robot?
re: ID1000 o-rings. Are they necessary to use, or are there other options?
I know some people who use 1/2 copper tube to space out the id's to keep the o-ring/seal in place. sometimes the injector will slide down on the intake mani seal or it will be loose like yours is
I don't know the part number but there are two factory lower seals one is roughly 1/8" think and the other is closer to a 1/4". I have a set of the thinker ones and it seals fine. I do have a gsr with the skunk2 manifold too btw.
yeah no boost leaks when I checked with the leak down test, everything else was leaking like the throttle body lol.
I got the engine from an importer its a jdm b18c from a 97 gsr. I tried to buy more once from a 2000 civic si they were the small ones. Maybe its the gsr's that have the larger one.
The obd1 b series seals are thicker if I'm not mistaken. I used a concave washer on top of seal. I had came across a thread where people were having seal issues with high boost levels and the washer solved the issue.
hate to bump an old thread, but is it confirmed the lower cushion needed for id's is a obd1 gsr? part number 16472-P0H-A01
jdmspoonitr
09-07-2010 11:38 AM
