450cc dsm injectors
Old Oct 10, 2002 | 04:54 PM
nerdsports's Avatar
Default 450cc dsm injectors
imma mount em on my d15b7. (95' civic dx). i just turbo'd it and i need some fuel.... i need new seals. one is missing a seal so i need new ones anyway..... what seals do i use??? im speaking of the seals that are on the bottom of the injector, not the O-ring.
Old Oct 10, 2002 | 05:33 PM
pelotudo's Avatar
Default Re: 450cc dsm injectors (nerdsports)
Stock injector seals for your car (Get from dealership). You'll have to either:
A. Dremel them out a little bit for the DSM 450cc's to fit in them and seal correctly.
B. Put them on the fuel rail, and tighten the hell out of them and hope they seal.
jB
Old Oct 10, 2002 | 07:25 PM
inspyral's Avatar
Default Re: 450cc dsm injectors (PelowisheshewascoolTudo)
fits perfectly, if a little snug in my Y8 manifold.
[Modified by inspyral, 8:26 PM 10/10/2002]
Old Oct 18, 2002 | 03:03 PM
thermal's Avatar
Default Re: 450cc dsm injectors (inspyral)
hey inspyral, i have a Y8 too. how did you wire the resistor pack? thanks
Old Oct 18, 2002 | 03:29 PM
M.A.R.C.'s Avatar
damnit tony... do u need me to help u with it... sheesh. just get the lower seals from honda and use the upper ones from ur old injectors. jam the injectors into the fuel rail, put the lower seals into the manifold. then line them all up and tighten it from side to side (like 2 turns one side then 2 turns on the other side). if you really need help, i'm bored i WILL drive the 30+ miles to help... i like workin on cars . especially when I done did it (and snapped my fuel rail bolt). oh yah... don't overtighten hehe.
Old Oct 18, 2002 | 04:37 PM
inspyral's Avatar
Default Re: 450cc dsm injectors (thermalfi'd16)
I took all the power wires to the injectors and combined them and ran them to the red wire fromt he resister pack, and then the black wires from the resistor pack go back to the injectors.
Old Oct 18, 2002 | 05:44 PM
senpai's Avatar
I used faucet washers from Menard's. Works fine for me and cost $0.59 compared to that $3-4 **** that Honda will charge you. I've been there.
Old Oct 18, 2002 | 09:01 PM
NateDawgCRX's Avatar
sounds like you should buy my friends 450cc injectors that he took out of his eagle talon tsi all wheel drive for 55 shipped
Old Oct 18, 2002 | 10:35 PM
skunk2unerz's Avatar
good info, thanks.....
Old Oct 19, 2002 | 02:15 PM
nerdsports's Avatar
one of the injectors was missing a lil seal. do u ned those???
also. here is one with the honda seals. are they placed correctly??
never done this. and none of my friends either. only civicryda2k, but i never see the guy... so i need help..........
Old Oct 19, 2002 | 02:26 PM
MikePalm's Avatar
The injector will be fine without the pintile cap. Just don't drop it. You'll probably need to bore out the inside of the honda seal there so it will fit into the honda manifold.
Old Oct 19, 2002 | 07:02 PM
M.A.R.C.'s Avatar
Default Re: 450cc dsm injectors (MikePalm)
you dont have to bored them out. i asked liam821 the other day when I was putting mine in. just put the injectors in the rail and line them up, then put the seals in the manifold, lube the injector bodies up w/ a lil vaseline and then line up the whole rail/injector assembly, and gradually tighten in down (a few turns on one side, then a few turns on the other, back n forth... don't tighted one whole side down at a time). worked for me.
delinquent
Mar 22, 2010 11:17 AM
martial
Feb 21, 2010 08:34 AM
ridnmyhonda
Mar 18, 2003 06:24 AM
LEON
May 10, 2002 02:57 PM
