3AN or 4AN ... much of a differeence?
Old Mar 27, 2005 | 07:23 AM
turboH22Aakkord's Avatar
Default 3AN or 4AN ... much of a differeence?
hi, does everyone primarily run 3AN oil lines for the oil feed? does anyone run 4AN... would it hurt it if the 4 AN was used? the reson i ask is ... im looking at a oil sandwhich right now.. but it has 3/8 fittings and i cant seem to find a 3/8 3AN fitting.. but i found 3/8 4AN fittings... thanks!!
Old Mar 27, 2005 | 09:28 AM
leadfoot78's Avatar
Default Re: 3AN or 4AN ... much of a differeence? (turboH22Aakkord)
3AN or a 4AN with a restrictior, I run a 3AN with a restrictor, got the idea?
Old Mar 27, 2005 | 10:38 AM
buck02's Avatar
Default Re: 3AN or 4AN ... much of a differeence? (leadfoot78)
i run -3 on my car now but i have -4 lines for sle made and ready to run with earls fittens on them
i spoke to rod from prcision and he said he wanted people to run -4 lines on there turbo so u make the decision
Old Mar 27, 2005 | 12:16 PM
y7turbo's Avatar
Default Re: 3AN or 4AN ... much of a differeence? (buck02)
i run a -3 line with a .055 restrictor.. works fine for me
Old Mar 27, 2005 | 12:21 PM
SSBPGSR's Avatar
Default Re: 3AN or 4AN ... much of a differeence? (konigturbocivic)
-3an feed -10an return
Old Mar 27, 2005 | 01:29 PM
BoOsTiN Dc2's Avatar
Default Re: 3AN or 4AN ... much of a differeence? (SSBPGSR)
-4an feed -10return
Old Mar 27, 2005 | 01:35 PM
SSBPGSR's Avatar
Default Re: 3AN or 4AN ... much of a differeence? (tRaCeBuStAbUsTeR)
i personally think -4 is to big. but thats just me. all the line kits on HT that are sold use 3an and 10an lines. not 4
Old Mar 27, 2005 | 02:00 PM
s2kdre's Avatar
theres no difference at all i've been using a 4 an for 2 years now. Theres no pressure difference at all.
Old Mar 27, 2005 | 02:12 PM
SSBPGSR's Avatar
Default Re: 3AN or 4AN ... much of a differeence? (jdmhonda)
there wouldnt be a pressure difference, but with the same pressure going through a bigger tube, more oil would be supplied into the turbo. hence my reason for a 3AN line. everyone on this board will have a diff opinion. 3 or 4 is up to you, i personally always have and always will use a -3AN
Old Mar 27, 2005 | 04:52 PM
awesome.. thanks for all the responses!!! helped alot
Old Mar 27, 2005 | 04:53 PM
xenocron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SSBPGSR &raquo;</TD></TR><TR><TD CLASS="quote">-3an feed -10an return </TD></TR></TABLE>
Ditto here
Modified by xenocron at 10:58 PM 3/27/2005
Old Mar 27, 2005 | 05:55 PM
Wideopentuning's Avatar
Default Re: 3AN or 4AN ... much of a differeence? (xenocron)
-4 with restrictor.
gooberguy31
Feb 25, 2009 12:09 PM
Nextelbuddy
Dec 21, 2006 10:34 PM
ghettocrxsi
Aug 11, 2006 09:34 PM
Del_Slowest
Nov 27, 2003 09:07 AM
igo4bmx
May 1, 2003 01:08 PM
