Aem 5 bar map with Crome Pro?
Old Feb 26, 2006 | 02:22 PM
Turbocivic94's Avatar
Default Aem 5 bar map with Crome Pro?
I'm running 5 bar map with Neptune. I cant get my car tuned for atleast for few months cause Jeff is booked. I want to mess around while I wait for my appointment.
Is anyone running 5 bar map with Crome pro?
Old Feb 26, 2006 | 02:33 PM
iBrandon's Avatar
Default Re: Aem 5 bar map with Crome Pro? (Turbocivic94)
how much psi are u planning to push?? i would just tune it so u can drive it around and push it here and there once in a while...tune it to like 18-20 psi or even lower (depends on how confident you are)...keep ur maps rich while tuning just in case, so u dont run lean...
but if ur running a 5 bar..u must be planning on sum serious power...just take caution til jeff can tune it...
but you should be able to run 5 bar on crome...theres an option when adding in the boost tables to custom put in your values for your map sensor...crack open that aem manual and look for the specs...
Old Feb 26, 2006 | 02:48 PM
2k.civic.si's Avatar
Default Re: Aem 5 bar map with Crome Pro? (iBrandon)
crome pro will work with any map sensor you just need to put in the correct settings when using boost tools
Old Feb 26, 2006 | 05:56 PM
Default Re: Aem 5 bar map with Crome Pro? (2k.civic.si)
I didnt see a option for 5 bar, just 3bar.
Old Feb 26, 2006 | 06:15 PM
Soccerking3000's Avatar
you need to setup the voltages not just select one...
Old Feb 26, 2006 | 07:09 PM
Default Re: Aem 5 bar map with Crome Pro? (Soccerking3000)
Can some explain how to change voltage on crome pro?
Old Feb 26, 2006 | 08:14 PM
grubere's Avatar
http://forum.pgmfi.org/viewforum.php?f=35
http://forum.pgmfi.org/viewtop...56804
Old Feb 27, 2006 | 07:39 AM
Default Re: Aem 5 bar map with Crome Pro? (grubere)
Thanks
Old Feb 27, 2006 | 09:11 AM
Si Shane's Avatar
I am ashamed to have seen this info spoon fed to anyone lol, good thing your not tuning the car yourself?
jthrasher1
Jun 6, 2010 01:27 PM
laziebun
Jan 14, 2008 04:58 AM
Boosteddb8
Jun 12, 2007 03:24 PM
turboeg77
Feb 26, 2006 04:18 PM
SPOOLINmatt
Jan 23, 2006 08:55 PM
