3 bar map sensor
Old Mar 3, 2009 | 07:03 PM
insaneconceptz's Avatar
Default 3 bar map sensor
i am hearing some confusing things about how many pounds a 3 bar will hold.. i am currently a 27 psi and am wondering how much longer my map sensor will hold up if i turn up the boost..... some people say the 3bar is only good to 28 psi, even thought 3bar is like 43.5 psi. please clarify this for me cause i am contimplating the 3.5 and the 5 from aem.... what are your thoughts?
Old Mar 3, 2009 | 07:07 PM
95dc2teg's Avatar
Default Re: 3 bar map sensor
i believe it is in fact only good to 28lbs, although i have no idea why it is called the 3 bar when clearly 28lbs is not 3 bars. I would go with a omni power or hondata 4 bar, i believe it reads to 43lbs and fits in stock location for a cleaner look.
cockerkid008's Avatar
Its 28 psi since you have to take out the 14.7psi just for the atmosphere
Old Mar 3, 2009 | 07:21 PM
that make more since i forgot about the atmosphere pressure i have a gm style map sensor. just trying to figure out what to do
Old Mar 3, 2009 | 08:19 PM
mtber's Avatar
If you plan on turning up the boost anymore, look into a 4-5 bar map sensor.
Old Mar 4, 2009 | 05:35 AM
blaze the chemi's Avatar
If you want to be technical since this is honda-TECH:
3 bar x 14.5psi/bar = 43.5 psi
43.5psi - 14.5psi (for atmosphere) = 29psi is the max a 3 bar could get to, but remember the atmosphere fluctuates in pressure so go to 28 for error. Happy boosting.
laziebun
Jan 14, 2008 04:58 AM
roydogg
Jan 20, 2004 12:53 PM
Beer
Jun 19, 2002 11:44 PM
0-60n4
May 22, 2002 07:39 AM
Pro-Lude
Aug 29, 2001 04:26 AM
