3 bar map?
Old Apr 25, 2005 | 11:01 AM
  #26
jBj's Avatar
jBj
Default Re: (rmcdaniels)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">
You should be able to see if you are still using the stock MAP sensor. Look and see if it's plugged in. It sits on top of the throttle body, here's a pic of mine:
Yea i checked and mine is plugged in. It reads: Sensor Assy. Map / Denso / 079800-3000 / 5v PS-30. Does that mean anything to you? stock?
Also about what 'HiProfile' wrote, would it be wiser to get a GM 2bar if i only plan to run a max of 15pounds? My motor is built though but i wouldnt imagine i would boost more than that, but ya never know i guess ...thoughts?
thanks for all the info guys
Old Apr 26, 2005 | 02:21 PM
  #27
jBj's Avatar
jBj
Default Re: (jBj)
Old Apr 26, 2005 | 02:31 PM
  #28
mattssi's Avatar
hondas come with a 2 bar map sensor? I'm i'm not mistaken. Because they also read vacuum. If my memory serves me thet read from -18.5 to 11psi.
Old Apr 26, 2005 | 06:50 PM
  #29
jBj's Avatar
jBj
Default Re: (mattssi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattssi &raquo;</TD></TR><TR><TD CLASS="quote">hondas come with a 2 bar map sensor? I'm i'm not mistaken. Because they also read vacuum. If my memory serves me thet read from -18.5 to 11psi. </TD></TR></TABLE>
yes i beleive they read up to 11psi
So can I just go to any auto store to get the GM3bar? anything more specific to ask for? And regarding the original question of this thread, is it possible disconnect the stock Mapsensor and use the same plug?
Old Apr 27, 2005 | 04:06 AM
  #30
rmcdaniels's Avatar
Default Re: (jBj)
You will need a connector for it, the Honda connector won't fit. Here's the part numbers:
GM 3 BAR MAP sensor - 12223861
Connector - 15305891
Pin A -- Ground
Pin B -- Sensor output
Pin C -- +5 volts
Old Apr 27, 2005 | 04:34 AM
  #31
juka's Avatar
Default Re: (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">Just wondering about people's thoughts on using the GM 2bar MAP sensor if you won't be going above 15psi? My thought is that a 3bar map on anything but a fully built motor handling 15+ psi is sorta useless (compaired to a 2bar), since you have much less resolution for the 0-15psi range (half the columns in your ems). From what I've seen over at the uberdata forums, a 3bar map also has a shitty non-linear curve in vacuum, and needs a complete retune for vacuum since nobody has the curve for it.
My guess is that above 20psi on a GM you'll have to do what you do for vacuum - retune every column. If it reads 22psi when it's really 27psi (and say 20psi when it's really 22psi), if you tune it starting w/lower boost, and tune it after every 1-3 psi increase in the wastegate, you'll be good. Based on the fact most people pusing 20psi+ are dyno ******, it'd be cheaper to go AEM 3bar than multiple dyno runs, I'd assume.</TD></TR></TABLE>
Yes, I have a 2-Bar GM (MSD) MAP for this same reason -- more resolution, and no intention of going over 15psi. I'm not sure, but I think the 2 bar has the same non-linear vaccuum issue as the 3 bar, so yes, complete retune needed -- but I'm waiting for Uberdata to get the Cut & Paste Lambda working to use my EzFuel (autotuning) script.
Don't know about your second paragraph tho.
Old Apr 29, 2005 | 04:17 PM
  #32
jBj's Avatar
jBj
Default Re: (jBj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jBj &raquo;</TD></TR><TR><TD CLASS="quote">
Old Apr 29, 2005 | 05:06 PM
  #33
spoolingb20's Avatar
Default Re: 3 bar map? (98B00STED)
i have the GM 3 bar map and i do belive you have to upgrade your EMS i went with Hondata and lovin it
Old Apr 30, 2005 | 10:56 AM
  #34
jBj's Avatar
jBj
Default Re: 3 bar map? (spoolingb20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolingb20 &raquo;</TD></TR><TR><TD CLASS="quote">i have the GM 3 bar map and i do belive you have to upgrade your EMS i went with Hondata and lovin it</TD></TR></TABLE> Yea like it says earlier in the thread ive got hondata as well, i like it but $$ wise i wish i woulda gone with uberdata..
still wondering about my map sensor:<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jBj &raquo;</TD></TR><TR><TD CLASS="quote">
Old Apr 30, 2005 | 08:07 PM
  #35
rioninja's Avatar
Default Re: 3 bar map? (jBj)
Your map sensor is stock.
SpoolnByYou
Dec 29, 2005 10:00 AM
redlseg
May 11, 2005 06:48 AM
BluntMan
Mar 4, 2004 07:05 AM
gsrt2c
Jun 8, 2003 05:35 AM
Turbo EG6
Aug 19, 2001 05:04 PM
