2step BOost Launch>?!?!?
Old Aug 22, 2006 | 12:17 AM
1SickHb's Avatar
Default 2step BOost Launch>?!?!?
wat up ht,
when u use ur 2 step and u build boOst,,....wat makes it charge lbs?!?!?!,........for example.....i;ll have my 2step at 5500 rpms, and it'll charge to like 3lbs, wat can i do to make it come outa the whole at like 5.to 8 lbs?
Old Aug 22, 2006 | 12:21 AM
komat's Avatar
Default Re: 2step BOost Launch>?!?!? (1SickHb)
at 7000rpm 15 or more(boost is set at 15psi) with sc61
neptune 3 step
Old Aug 22, 2006 | 01:36 AM
1SickHb's Avatar
Default Re: 2step BOost Launch>?!?!? (komat)
dats wasup
but i still dont understand wat makes it increase the charge?!?!
Old Aug 22, 2006 | 01:54 AM
UNKNOWN_MEMBER's Avatar
more air flow coming out the exhaust ports. raise your 2step rev limiter to build more boost.
Old Aug 22, 2006 | 02:30 AM
1SickHb's Avatar
Default Re: 2step BOost Launch>?!?!? (UNKNOWN_MEMBER)
ohhhh aight, makes sence bout how would u make it increase then?? timing, cams??
Old Aug 22, 2006 | 03:40 AM
riase you revlimiter
b00sted EK
Oct 10, 2009 03:43 PM
ACrite3404
Sep 23, 2007 01:28 PM
RTW DC2R
Nov 17, 2006 03:19 PM
HotRodTeg
Sep 9, 2003 10:52 AM
EE_Chris
Jun 28, 2002 08:25 AM
