BOOST + 2 Step
Old Sep 8, 2003 | 05:32 PM
HotRodTeg's Avatar
Default BOOST + 2 Step
I was wondering how much boost do you guys have when your on the 2 step?
We were having problems with ducs car launching cause it didnt have that much boost. any ideas what we could do to get more boost off the line? the help would be alsome. We were pitted next to JJ olsen and he said that he was getting 15 psi of boost off the 2 step. we are only getting 3-4 pounds.
Old Sep 8, 2003 | 05:52 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: BOOST + 2 Step (streetracer)
My 2step is set at 6k. My boost was set at 17psi, and i was seeing about 9psi on the 2step.
Old Sep 8, 2003 | 06:17 PM
boostedh22a's Avatar
Take timing away at lauch, then boost will come up.
We have been between 4 and 12 psi of boost, all adjusted through timing. Is there a stand alone on the car?
Old Sep 8, 2003 | 06:27 PM
FULLTHROTTLE's Avatar
Default Re: (boostedh22a)
Im supercharged (my car is anyway) so the 2step basically gives me full boost at launch.
Old Sep 8, 2003 | 06:31 PM
Default Re: (FULLTHROTTLE)
What kind of boost are you running, if you lauch at full boost?
Break any driveline parts?
Old Sep 8, 2003 | 06:39 PM
turbotypeR@SPEC's Avatar
25 Year Member
mine makes about 8psi
Old Sep 8, 2003 | 06:41 PM
GRTechnologies's Avatar
if you cant tale any timing out put a higher rpm chip in
Old Sep 8, 2003 | 06:42 PM
Default Re: BOOST + 2 Step (turbotypeR)
wow!! we turn it back down to about 5psi cause we were just lighten up on the line. 1.4's 60'
Old Sep 8, 2003 | 06:43 PM
Default Re: (GR)
unfortunately putting a higher RPM chip in doesn't raise the boost levels, it will just help from bogging.
Personally if you dont have strong driveline parts, I would launch with more RPM and less boost.
My 2 cents
Old Sep 8, 2003 | 08:22 PM
BoostedED9's Avatar
i had mine set at around 7000 and only saw approx 4-7psi..... does anyone make a box that will retard timing just for launching and is not a standalone???
Old Sep 8, 2003 | 08:26 PM
I believe MSD does, but Im not sure. We use the F.A.S.T. system to do it.
Old Sep 8, 2003 | 10:48 PM
HotRodTeg's Avatar
yeah have the FAST standalone on the car also. so taking away timing at the point were the 2 step is set at will give us more boost?
Old Sep 8, 2003 | 10:52 PM
TurboDANDEE's Avatar
Default Re: (streetracer)
Im also running FAST system, how exactly do yall guys do it?
Im launching around 6k rpm and building about 7psi off the line, but im not using FAST to do it. Im running an MSD digital 7 programable and it allows me to retard up to 20 deg. of timing with it. i have it set to 15 deg. of retard, but how should i set my FAST timing along with the MSD?
Old Sep 9, 2003 | 07:03 AM
DLB1994's Avatar
Default Re: (TurboDANDEE)
i get about 7psi @ 4700 rpm pill
Old Sep 9, 2003 | 07:10 AM
HotRodTeg's Avatar
Default Re: (DLB1994)
man all you guys have way more boost on the 2 step then i do i only have 3-5 psi with a 7000 rpm pill.
Old Sep 9, 2003 | 09:40 AM
H22uner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetracer &raquo;</TD></TR><TR><TD CLASS="quote">yeah have the FAST standalone on the car also. so taking away timing at the point were the 2 step is set at will give us more boost?</TD></TR></TABLE>
Tat is correct! but it is hard on internal parts and your ears !
Old Sep 9, 2003 | 10:52 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedh22a &raquo;</TD></TR><TR><TD CLASS="quote">What kind of boost are you running, if you lauch at full boost?
Break any driveline parts? </TD></TR></TABLE>
9 psi and yes. I have had to change my launch strategy.
aalb1
Nov 15, 2005 02:09 PM
twenty
Jun 13, 2005 04:07 PM
nigel
Mar 24, 2004 05:29 PM
