2bar map sensor?
Old Dec 3, 2001 | 11:28 PM
paulzy's Avatar
Default 2bar map sensor?
What's the rating for a 2bar map before it starts seeing boost?
Old Dec 4, 2001 | 12:08 AM
liam821's Avatar
Default Re: 2bar map sensor? (Slow_ass_4dr)
depends on what altitude you are at. If you are at 5400 feet its going to read different then if you were at sea level.
liam
Old Dec 4, 2001 | 12:34 AM
paulzy's Avatar
Default Re: 2bar map sensor? (liam821)
well, the nearest track to me is at 720 ft above sea level...so let's take that into consideration
Old Dec 4, 2001 | 05:28 AM
rtype11's Avatar
might go to 23-24psi, who makes it is it GM??
Old Dec 4, 2001 | 09:58 AM
DirtyLude's Avatar
Default Re: 2bar map sensor? (rtype11)
What are you talking about?
Do you mean what voltage does it give at atmospheric, or do you want to know the voltage range for -1bar to atmospheric?
Old Dec 4, 2001 | 11:58 AM
paulzy's Avatar
Default Re: 2bar map sensor? (DirtyLude)
it's an AC Delco...
what I wanna know is what the max boost you can run before the 2bar maps start sensing boost(like the stock honda ones)...
Old Dec 4, 2001 | 12:15 PM
DirtyLude's Avatar
Okay, I'm still not following you. The 2 bar map sensor can see 1 bar of vacuum and 1 bar of boost pressure. So at 0psi up it senses boost. That answer seems too simple, but I'm still not certain what your lookiing for. It can see up to 1bar (about 15psi) before it can't see anymore.
Old Dec 4, 2001 | 02:01 PM
chri5's Avatar
Is your plan to replace the factory MAP with a 2bar? Then run without any check valves, since the sclae of the voltage:boost ratio will be different? I think I am missing the point if that is what you are trying to do.
Old Dec 4, 2001 | 02:41 PM
paulzy's Avatar
Default Re: 2bar map sensor? (Strng1dah)
okay, here's the deal....I was sent a 2bar map sensor instead of the 3bar map that I was promised when my haltech came in...I'm planning to boost around 18-20psi's...should the 2bar map be good enough or will I need a 3bar map?
Old Dec 4, 2001 | 04:45 PM
TurboSedan's Avatar
New User
The 2 Bar should be fine dude. At sea level it is good to 29 lbs of boost. I am not sure the correction factor at your eleveation, but it should not be too much for the 2 Bar sensor.
Old Dec 4, 2001 | 04:48 PM
liam821's Avatar
Default Re: 2bar map sensor? (97CivicFerio)
incorrect!!! 2bar = boost to 14.7 psi. 3bar goes to 30psi. A 2 bar map sensor reads 1bar in vacuum and 1bar in boost (at sea level) ie 2bar. The stock honda MAP sensor is a 2bar.
You need a 3bar sensor to read boost over 14.7psi (at sea level). The 3bar reads 1bar in vacuum and 2bar in boost.
liam
Old Dec 4, 2001 | 05:06 PM
TurboSedan's Avatar
New User
**** I was not aware of that!! Hondata say right on their website the stock Honda MAP sensor reads only up to 11PSI. Is this wrong? Also, I thought that a 2 Bar sensor read up to 2 Bar of boost pressure. Why is vacuum included in the spec?
Old Dec 4, 2001 | 05:14 PM
liam821's Avatar
because its just airpressure. Vacuum/boost makes no difference to a map sensor...It just reads pressure. You need vacuum because when the throttle body is closed you are around -13psi of air pressure inside the intake manifold.
Hondata 11psi stock is a safe level i am guessing. I have got my stock honda map sensor to read 14psi above sealevel pressure without problem.
liam
Old Dec 4, 2001 | 05:34 PM
Dee's Avatar
Dee
The stock Honda map sensor is a 2 bar but is only capable of reading 11psi before taking a crap. The GM 3bar is a good choice for people who want to go over 11psi.
Old Dec 4, 2001 | 06:34 PM
liam821's Avatar
Default Re: 2bar map sensor? (drealgsr)
i dont agree...i have boosted to 16-17psi at 5400 feet which is around 13-14psi over sea level..and my honda map sensor worked fine. My afc showed ~14psi boost reading (after converting that from hg/km2 or something).
liam
Old Dec 4, 2001 | 06:47 PM
DirtyLude's Avatar
Hondata is saying that the stock MAP can read 2 bar, but has a chance of breaking over 11psi. If you're running 14psi, well then, according to them your lucky it hasn't broken, yet.
Like everyone else is saying; you'll need the 3 bar for anything over 14.7psi.
Old Dec 4, 2001 | 09:05 PM
liam821's Avatar
haha..i just bought a 3bar sensor...so i am going to convert to using that. Althought he honda works great for low boost work!!
liam
Old Dec 4, 2001 | 10:23 PM
paulzy's Avatar
how much did you get your map sensor for and from where? How much does GM charge for it and what' the GM part number?
Old Dec 4, 2001 | 11:19 PM
liam821's Avatar
i bought a MSD 3bar sensor. I think i paid like $40 for it. You can buy it from anywhere that sells MSD stuff (although it was a special order item).
If you goto GM its like $105 for the 3bar sensor. GM only used that sensor on one car for only one year...its the 89 Turbo Trans AM. GM part #16040749
liam
Old Dec 5, 2001 | 04:33 AM
DirtyLude's Avatar
Great tip!
The MSD has the same voltage specs as the GM 3bar? I need to toss my 2bar sensor for a 3bar soon.
Old Dec 5, 2001 | 08:52 AM
paulzy's Avatar
thanks liam
Old Dec 5, 2001 | 09:18 AM
liam821's Avatar
The MSD 3bar its the same voltage as the GM 3bar...it even looks the same. Notice that the part number on the sensor is the *same* GM part number???
(i took some pictures for ya guys..)
liam
[Modified by liam821, 10:19 AM 12/5/2001]
Old Dec 5, 2001 | 09:47 AM
TurboSedan's Avatar
New User
$40 for a 3bar sensor!! Liam, U dam man!!!!
Old Dec 5, 2001 | 10:04 AM
rtype11's Avatar
MSD, WELLS, CRANE all use the GM 466 map sensor, they just repackage it.
krugozor
Feb 21, 2011 08:38 PM
Ldo
Oct 9, 2010 03:35 PM
ashb82
Engine Management and Tuning
Sep 3, 2009 03:29 AM
rdssk8rcs1
Oct 10, 2006 06:43 AM
KoRE
Nov 3, 2002 01:15 PM
