inline fuel pump question
Old Jun 20, 2005 | 07:06 PM
Blue-EM1's Avatar
Default inline fuel pump question
On my 00 Si, do i need to run two fuel pumps; one intank and the other out for the Drag turbo kit or can i just run one 255 walbro pump in the tank? im only looking to run like max 8 pounds.
Old Jun 20, 2005 | 07:20 PM
non-VTEC's Avatar
Default Re: inline fuel pump question (RetardedSi)
yes ditch the inline pump and just run the one walbro intank pump.....
just make sure you have the proper engine managment to supply fuel to the engine.....
Old Jun 20, 2005 | 07:39 PM
s2kdre's Avatar
Default Re: inline fuel pump question (non-VTEC)
inline pump has got to go
Old Jun 22, 2005 | 04:45 AM
Blue-EM1's Avatar
ok but im just bolting the kit on, so i have no engine management as of now. The only thing i have is the fmu that is 12:1. And i talked around and some said to run two because for the high demand the fmu puts out?
Old Jun 22, 2005 | 04:57 AM
bubs's Avatar
If you're running an FMU, you should definitely run the inline pump. The intank walbro won't be able to handle the high fuel pressure by itself.
Old Jun 22, 2005 | 05:03 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: inline fuel pump question (bubs)
Keep the INLINE if you still have FMU, like others had said. If you go hondata or something like that you can run larger injectors and take out the inline. Untill then KEEP IT IN!
Old Jun 22, 2005 | 06:31 AM
notoriousB's Avatar
Default Re: inline fuel pump question (Arturbo)
agreed, keep the inline pump, if you don't you can blame the first couple of replies to this thread for your blown motor.
Old Jun 22, 2005 | 12:48 PM
Carlito Brigante's Avatar
Default Re: inline fuel pump question (notoriousB)
Walbro 255HP will work fine with the 12:1 FMU. 255 regular would be a tad insufficient.
Drag/Revhard sent the inline pumps because most people that buy there kits will use the oem pump in the tank.
Ricky
Old Jun 22, 2005 | 01:59 PM
boostedcivicsir's Avatar
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">yes ditch the inline pump and just run the one walbro intank pump.....
UM NO
If you are running the FMU you will need the extra volume the inline pump provides. the walbro is almost enough but is it worth melting the engine? NO.
if you go with stand alone the walbro will be enough.
Old Jun 22, 2005 | 03:31 PM
Blue-EM1's Avatar
Default Re: inline fuel pump question (boostedcivicsir)
the fuel pump is a 255lph-hp. it is supposed to up out more than the regular lph."at 80 PSI the standard 255 lph pump will flow around 132 liters (35 gallons) per hour. At that same 80 PSI the equivalent HP (high pressure) fuel pump will flow over 210 liters (50 gallons) per hour."- thats what nolimitmotorsports say about it. will this be fine or do i for real need the two of them. And the # on it says Gss317, i beleive its a prelude not civic, will it fit?
Old Jun 22, 2005 | 03:58 PM
Mr. Badwrench
me personally, i ran mine at 7psi without, but i think it contributed to my engines demise. i would run the 2 but thats my o.o2.
Old Jun 22, 2005 | 04:07 PM
Blue-EM1's Avatar
did u have any problems with one on 7psi. i have no engine management , no injectors, fpr, fuel rail or ecu. its all stock.
Old Jun 22, 2005 | 05:37 PM
Mr. Badwrench
i wouldnt do it man. run 2. it wont hurt.
Old Jun 23, 2005 | 04:48 AM
Blue-EM1's Avatar
Got ya. Thanks man.
Old Jun 23, 2005 | 07:01 AM
sent you a pm Ben.
Ricky
Old Jun 23, 2005 | 08:26 PM
Blue-EM1's Avatar
Default Re: inline fuel pump question (WIRED RICKY)
got ya. sent you one back
kpjo4
Jun 4, 2010 05:19 AM
YellowPhoenix095
May 14, 2007 06:30 AM
vietxdragon
Sep 25, 2006 06:24 PM
TOP*SECRET
Apr 21, 2005 08:37 PM
KrispyKreme
Apr 20, 2005 03:52 PM
