1st turbo setup
Old 08-30-2007, 07:55 AM
sccivic's Avatar
Default 1st turbo setup
listen i got a honda d15b2 w/ a MPFI swap and i want to turbo it. my questions are what size turbo can i put on the motor without changing the internals?? i goin to change em but i want to see how it runs on turbo first. my second question is can i boost it B2 without switchin out the ecu? can i use the stock ecu??? i really only want about 6-8 lbs of boost. Can sum 1 help me please. i want turbo this motor as soon as possible
Old 08-30-2007, 08:29 AM
Man U FTW
Schister66's Avatar
What you need to do first is research. If you try to rush building a setup w/o any knowledge of turbo setups, you're going to encounter problem after problem. There are a lot of ways to go about turboing your D. As far as a realistic goal, dont think in terms of PSI, but rather in terms of horsepower. If you shoot to make 220whp or less, your D should be fine as a daily w/o too much concern
Old 08-31-2007, 11:37 AM
sccivic's Avatar
Default Re: (Schister66)
thanks for the info but you didnt answer the question bout the ecu. what do i have to do about that since im running such low boost numbers?
Old 08-31-2007, 12:30 PM
Mr. Badwrench
boostedcivicsir's Avatar
Default Re: 1st turbo setup (sccivic)
you can run a 45r if you keep it at about 3 psi.
it is the power level that kills the engine. a normal t3-t4 plenty or power can be made w ith that turbo. as far as the ecu, if you want any tunability, obd0 88-91 will work, but 92-95 will work better.
Old 08-31-2007, 07:40 PM
62ndsoldier's Avatar
you can do something like what im putting together this weekend for my d16y7, went out to the junkyard grab'd a turbo off a mitsu starion or a chrysler conquest, starion FMIC or side mount, DSM BOV, DSM 450cc injectors, a HF/STD (stock exhuast manifold on crx hf's and civic std's) machine up a adapter plate for it and a fab up a downpipe and your pretty much set, if ur gonna run low boost like me 5-8 psi as far as fuel managment cheapest is a FMU which is relatively safe at low boost lvl's but above that go a different route, I put together this whole setup for about $300 maybe
gosu08
03-02-2008 03:38 AM
XES
10-19-2005 05:50 PM
surftb15
01-04-2005 11:16 AM
E. Honda
06-18-2002 02:56 PM
itr501
09-28-2001 12:22 PM
Quick Reply: 1st turbo setup
