11+psi on stock map sensor?
Smarter than you
I was planning on boosting .7bar, just under 11psi.. and i was thinking what if I happened to spike over 11, what would happen? im not planning on doing it on purpose.. probably should get the 3bar just in case..
Umm, it won't have any maps past 11psi for fuel and ignition.
The MAP input is like from 0-5v. At 11psi it is putting out 5v. It can't go any higher (input to the sensor IS 5v, it's not goign to dream up extra voltage!).
11psi+ will run exactly as if the car was at 11psi.
Dustin
Dustin
Smarter than you
stock honda map sensor only recognize boost up to 11lbs
thanks dustin, thats what i thought, i just wanted to make sure..
Smarter than you
well dustin had the GM 3bar and it didnt work right, i want to keep things as simple as possible..
i went from the stock map to the 3 bar and it works perfectly no problems at all.
When you go over 11psi on the stock sensor you get fuel cut...feels like hitting a brick wall.
Tofurky
Feb 24, 2019 06:09 AM
