Which engine Takes more Boost??????
Old Apr 26, 2002 | 07:48 PM
YellowCivic95's Avatar
Default Which engine Takes more Boost??????
Which engine takes more boost, teh B18C spec R, or the B18C1???????
Thanx
Old Apr 26, 2002 | 07:50 PM
kitkatR's Avatar
Default Re: Which engine Takes more Boost?????? (YellowCivic95)
they both could take the same
know witch ones goes first is the question
Old Apr 26, 2002 | 08:00 PM
Krow's Avatar
Default Re: Which engine Takes more Boost?????? (kitkatR)
I would go with the b18c1, unless you can afford the c5.
Old Apr 27, 2002 | 12:30 AM
Ramocheese's Avatar
If you're talking about stock blocks, I'd go with the C1 over the C5. The C5 has way too high compression for boost (even the C1 is high). If I were you, I'd pick up an LS block and resleeve it and o-ring it, then put some good pistons/rods in and a good head gasket. That should make a strong motor, and as long as you don't detonate, you should then be able to run as much boost as you want.
VTEC_PRODUCTION
Mar 29, 2007 07:16 PM
BaGGed HoNDa
Jun 29, 2004 09:54 PM
speed
Nov 23, 2002 05:18 PM
YellowCivic95
Apr 30, 2002 05:04 AM
YellowCivic95
Apr 27, 2002 07:59 AM
