100 and 104 octane
Old Jun 14, 2003 | 08:17 PM
aforstboost's Avatar
Default 100 and 104 octane
Hey I am in the processing of building a h22 for boost 9.5:1 compression JE pistons 89 bore goldeneagle sleeves swain tech coatings etc. I plan on running 10lbs of boost JRSC. AEM standalone 550 injectors. Hondata intake gasket fluidyne radiator, engine oil cooler. With out the luxory of an intercooler I am looking to run either 101 or 104 octane unleaded. Any ideas on how much timing I will be able to run. I know for pump gas 91-93octane hondata uses the generic .75 deg of retard per pound of boost for their boost tables. What about for 101/104 octanes. Thanks in advance
Old Jun 14, 2003 | 08:20 PM
liam821's Avatar
25 Year Member
Default Re: 100 and 104 octane (aforstboost)
Id think with the good fuel management, you could run 10psi on a 9.5:1 on 91 octane..maybe not as much timing as you like tho but it should run strong.
liam
InTeGrA B18b1
Dec 12, 2004 06:06 PM
Boost2NA
Sep 30, 2003 02:55 AM
untitled
Mar 31, 2003 07:34 AM
hybrid901
Sep 11, 2002 05:33 PM
slowcivic
Dec 14, 2001 10:12 AM
