What timing you guys run for boost? uberdata, hondata etc
My uberdata is 1 lb per boost and its really really conservative, i wonder how much im losing by it. what timing you guys run? oh yea my distributor is at stock 16. Let me know thanks
Re: (joek84)
i want to know too....
maybe we can start an official ignition advance thread...
but we need to know compression ratio and engine displacement too, to compare the different setups..
i for myself run B16A1 with stock compression (10,2:1), stock internals, with 8psi of boost and 0,9 degree per psi linear retard.
Greetings
Malte.
Greetings
Malte.
Re: (mrx)
The uberdata forums has some good info on this subject, right now im running .8 per lb, which is still a "safe" value.
Check out this post for a step-retard
http://www.ecimulti.org/uberda...15487
Re: (Combo)
i think thats not exactly what he means...
i think everyone knows allready that i.e. 1°/psi is save... what we want to know is how far other ppl go with their setups to get an idea of whats good and whats not good...
Re: (mrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrx »</TD></TR><TR><TD CLASS="quote">i think thats not exactly what he means...
i think everyone knows allready that i.e. 1°/psi is save... what we want to know is how far other ppl go with their setups to get an idea of whats good and whats not good...</TD></TR></TABLE>
1 degree per pound is way too conservative.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combo »</TD></TR><TR><TD CLASS="quote">The uberdata forums has some good info on this subject, right now im running .8 per lb, which is still a "safe" value.
http://www.ecimulti.org/uberda...15487</TD></TR></TABLE>
Step-retarding
Retard it less for earlier psi and then more when you reach your peak psi.
Step-retarding
Re: What timing you guys run for boost? uberdata, hondata etc (InTeGrA B18b1)
i want to know ok
Fuel mangement lbs per boost and Timing on distributor. thanks
uberdata 1 lb per boost timing 16
the reason is I am wondering how much timing will effect power, eg. compare .5 timing to .75 per lb.
Modified by InTeGrA B18b1 at 12:40 PM 12/11/2004
Re: (Tchleung)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung »</TD></TR><TR><TD CLASS="quote">I run .75 degree retard per PSI</TD></TR></TABLE>
Same here, no problems so far. Ran a 13 flat with MAD wheel hop! and a shitty 0-60 time ( 2.5 secs ) with 4.5psi of boost -
Stock GSR motor, with t3to4e, large front mount...etc etc...
Re: (bustug)
Its 0.7 retard per pound for 10:0:1 compression 0.6 RPP for 9:0:1 timming should be set by compression and octane value thats a good base value for 91 octane.
