** The E85 Thread **
Old Apr 18, 2009 | 10:16 PM
  #376
jdm602's Avatar
Default Re: ** The E85 Thread **
dang that sucks for some of you with winter blends. gas stations around me dont think its cold enough for it so, they just stay with the e85 blend. no e70 winter blends or anything here.
and yes that brad penn oil is the ****. still rockin the oem filter too.
Old Aug 27, 2009 | 01:54 PM
  #377
COMplex.'s Avatar
Sorry to bump an older thread, but I just came across your post and wanted to correct you so that others don't get the wrong idea.
The only state that uses Class 1 E85 (79-85% ethanol) is Hawaii. Every other state varies between class 1, 2, and 3 throughout the seasons.
Seasonally Adjusted Blends
The amount of alcohol in the fuel ethanol blend depends on the geographical region and the season. In cold weather, more gasoline is added to the blend to ensure proper starting. A minimum of 70% by volume of alcohol is permitted in the winter blend by the ASTM fuel standard. This seasonal blending from 15% to 30% gasoline limits concerns about winter cold starting and are similar to seasonal adjustments of volatility (vapor pressure) used in gasoline blending throughout the United States.
ASTM volatility classes and their ethanol contents
Class #: Ethanol, plus higher alcohols (minimum volume %) / Hydrocarbons (including denaturant) (volume %)
Class 1: minimum 79% ethanol / 17-21% hydrocarbons
Class 2: minimum 74% ethanol / 17-26% hydrocarbons
Class 3: minimum 70% ethanol / 17-30% hydrocarbons
Volatility class by month/location in Washington
PHP Code:
Washington, US >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>|
                    | Jan | Feb | Mar | Apr | May | Jun | Jul | Aug | Sep | Oct | Nov | Dec |
East of -122° lon.: |  3  |  3  | 3/2 |  2  |  2  | 2/1 |  1  |  1  | 1/2 | 2/3 |  3  |  3  |
West of -122° lon.: |  3  | 3/2 |  2  |  2  |  2  | 2/1 |  1  |  1  | 1/2 |  2  |  2  | 2/3 |
Volatility class by month/location in Colorado
PHP Code:
Colorado, US >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>|
East of -105° lon.: |  3  |  3  |  3  | 3/2 |  2  | 2/1 |  1  |  1  | 1/2 | 2/3 |  3  |  3  |
West of -105° lon.: |  3  |  3  |  3  |  3  | 3/2 |  2  | 2/1 | 1/2 | 2/3 |  3  |  3  |  3  |
In case you ever want to field test e85 in your area yourself:
The following summary describes a “field test” procedure to determine the levels of hydrocarbon and alcohol in E85.
The following equipment is available from VWR Scientific, 800-932-5000. Reference numbers are those used by VWR. Other equipment suppliers are available.
50 mL pipettes - Cat. #52966-217
Safety bulb - Cat. #53497-202
100 mL cylinders - Cat. #24762-117
Procedure for Determining Hydrocarbon Percent of Ethanol Fuel Samples
1. Using the suction bulb, pipette exactly 50 mL of fuel sample into the graduated cylinder.
2. Add about 48 mL of water to make the total liquid volume just under 100 mL.
3. Place the stopper in the cylinder and shake vigorously for about 15 seconds.
4. Carefully loosen the stopper to release any accumulated pressure; do not remove the stopper.
5. Close the stopper again and place the cylinder upright on a level surface. Allow the mixture to sit for about 15 minutes.
6. Record the total volume of liquid by reading the lowest part of the upper meniscus (the curved interface between the liquid and air).
7. Record the total volume of the alcohol/water layer by reading the lowest part of the lower meniscus (the curved interface between the two liquid layers).
Calculation
• The hydrocarbon percent is calculated by: 2.1 + 1.94*(total volume - alcohol/water volume)
• Assuming the sample was an ethanol/hydrocarbon mixture, the ethanol percent is 100 minus the hydrocarbon percent.
Source: US Dept. of Energy
Old Aug 27, 2009 | 03:06 PM
  #378
jdm602's Avatar
cool info.
well i got a really bad batch of ethanol lately. it was like e50. afrs would dip well below 10. cruising would be like 11-12 on the gauge. normally there around 16-17. i could smell the difference and it was very noticeable that it was more potent with gas than ethanol. anyways, now im back to the station that i know only gets e85 and the numbers are good!
Old Aug 27, 2009 | 03:22 PM
  #379
COMplex.'s Avatar
cool info.
Hmm strange. I would expect e50 or similar would cause lean conditions.
I'm around 10.9 under boost and 12-14 cruising. e85 likes running rich it seems. I made more power on the dyno by increasing fuel.
Old Aug 27, 2009 | 04:15 PM
  #380
jdm602's Avatar
well the more gasoline added to the mix youll be using more fuel and itll run more rich compared to e85. but with my tune right now its about 11.9-12.0 wot and about 16-17 cruising for good mileage. but yea on that last batch it was running really pig rich cause it had more gasoline in it. sucked for a while til i used all the shitty gas up. seems like your running a bit on the rich/conservative side on your tune.
Old Aug 27, 2009 | 04:40 PM
  #381
COMplex.'s Avatar
Oh that makes sense. I forgot about the added fuel thing. duh! haha
I am running a bit on the rich side, but that is where we found the most power. Leaning it out actually lost power. Surprised me, but hey whatever works.
Old Sep 8, 2009 | 06:54 AM
  #382
alpha's Avatar
Great thread. A lot of good information. A few E85 cars I tuned a week or two ago. 2JZ-GTE's but still E85
And a friend's car also switched to E85
Old Sep 16, 2009 | 07:02 PM
  #383
StolenTeg's Avatar
Is 500whp possible on e85 with 100% oem fuel system with the exception of 1000cc injector and 255lp walbro pump?
Old Sep 17, 2009 | 04:05 AM
  #384
96 GSR-T's Avatar
Hardwire the pump with a relay to the battery, might need a reg to bump up the pressure some...... but your fuel system should be maxed out at 500whp.
Old Sep 20, 2009 | 03:02 PM
  #385
hotdoghogie's Avatar
Just a quickie... Say my car is having a hard time passing emissions, would e85 with a tune/ or no tune make it more able to pass OBD1 emissions here in Texas?
Old Sep 20, 2009 | 03:41 PM
  #386
96 GSR-T's Avatar
No
Old Oct 11, 2009 | 12:37 PM
  #387
alpha's Avatar
Originally Posted by alpha
This car just went 201 miles per hour in the standing mile on pump E85 Very happy
Old Oct 13, 2009 | 08:56 AM
  #388
ctr32's Avatar
hey guys got a ? Im tuned on e85 right now..my question is when they switch it over will it mess up my tune? or will it just make it rich?
Old Oct 13, 2009 | 10:19 AM
  #389
gringotegra's Avatar
So you are on e85 right now? and you want to know that if you switch it over to gas will it mess up your tune...?
Well the answer is yes... if you dont touch your tune it will be a **** load richer and it will instantly run like ****.. ive seen cars instantly foul the plugs because it is so rich... figure you are going to instantly add 30% or more fuel into the car... so say the car was tuned for 11.50 AFR's if you add 30% more fuel you will be at 8.0 AFR's or so ...
Old Oct 13, 2009 | 01:32 PM
  #390
ctr32's Avatar
nooo i mean switch as in when they add more gas to the e85 when it gets colder out.. my bad
Old Oct 13, 2009 | 04:57 PM
  #391
haha ok ok..
Well if you have a wideband in your car... you will notice quite quickly if the E85 has changed to something else...
Old Oct 13, 2009 | 06:22 PM
  #392
ctr32's Avatar
yeah i have a wideband...jw if its gonna throw the tune off ?its gonna be stored in the winter but will take it out on some nice days!
haha ok ok..
Old Oct 15, 2009 | 05:17 AM
  #393
Silvertc's Avatar
Ok, i have read through almost all this thread. I have a few questions if anyone can seriously help me out. ill start with my set up
*MOTOR* B16A2 ERL block with Dart sleeves.
-Bored to 82.5mm
-CP pistons
-Scat Rods w/ARP rod bolts
-balanced rotating assembly
*HEAD* B16A2
-Full Supertech valvetrain, springs retainers valves.
*FUEL*
Precision Injectors 1000cc's
Walbro 255 fuel pump
All stock oem fuel lines from stock tank.
I do have an inline fuel filter in the bay with braided line going to fuel rail.
********EDIT********-forgot to add Goals of 450-500HP
What exactly more do i need to run E85 or what do i need to exactly change to run E85?
Old Oct 15, 2009 | 06:53 AM
  #394
96 GSR-T's Avatar
yes its definately going to throw the tune off, and you will notice it on the wideband it will be noticeably richer going from E85 to E70
Old Oct 15, 2009 | 06:54 AM
  #395
96 GSR-T's Avatar
-Bored to 82.5mm
-CP pistons
*HEAD* B16A2
*FUEL*
Just tune it, you could add lines but thats just a personal preference IMO
Old Oct 15, 2009 | 07:33 AM
  #396
Silvertc's Avatar
just tune it? really...the person im going to have tune it said i might have to add 1600cc injectors and possible dual fuel pumps? i forget to ADD, goals are 450-500HP...
Old Oct 15, 2009 | 07:36 AM
  #397
TehGhett0P1mp's Avatar
I dont think so..500whp would be the limit with that fuel though, if you want insurance adding another pump or one inline would help but I dont think it is NECESSARY..
Old Oct 15, 2009 | 08:41 AM
  #398
96 GSR-T's Avatar
If your car is a street car 1600's suck, and 1600's with dual 255's Intanks will get you over 700whp with E85, not needed for your goals.
A 255hp and non-ID1000's should get you around 500whp on a DynoJet +/- 25whp, as just stated above adding another inline 255hp would help some because you dont want to be running around with a maxed out fuel system.
A better planned fuel system for 500whp on E85 is an Intank 255hp to a Bosch 044 Inline to ID1000's, that will give you around 600whp with E85.
Old Oct 15, 2009 | 08:42 AM
  #399
ctr32's Avatar
ok thanks
Old Oct 16, 2009 | 07:11 AM
  #400
Silvertc's Avatar
ok thanks for input man
