***The Official Nitrous Thread***
#1126
![Default](https://honda-tech.com/forums/images/icons/icon1.gif)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC-2uned »</TD></TR><TR><TD CLASS="quote">There is no exact number of runs for any shot/bottle size because there are too many variables (bottle pressure, how many rpms it's on for, how many gears it is used in, etc) which is why mac gave you the 6-8 run estimate for a 100 shot.</TD></TR></TABLE>
![](https://honda-tech.com/forums/images/smilies/emthup.gif)
If you were running a 12-25 HP shot on a 15 lb bottle.. Man, you'd have ALOT of nitrous to play with
![](https://honda-tech.com/forums/images/smilies/emsmilep.gif)
#1128
Noob question!
1. im runnin a .040 nitrous jet and .022 fuel jet, this is a 70 shot right!
2. do i need the blow down tube?
3. do you guys squeeze in 1st gear, or 2nd and up?
4. what shot would you guys reccomend on a jdm d15?
thanks for all the help. i plan on goin to the tracks tonight, last time i ran a 17.2 with 35psi in my tires, i had mad hop ... im hopin for 16s and 15s with the bottle!
#1130
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrx »</TD></TR><TR><TD CLASS="quote">thanks, yes it's just for spoolup improvement... thanks so far for the info</TD></TR></TABLE>
whats ur setup
whats ur setup
#1133
a blow down tube is required to run at the track. 70 shot is fine on the d15, run atleast premium, retard the dist 3 degrees, and you better run 14's on street tires
#1134
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1BADEGDC2 »</TD></TR><TR><TD CLASS="quote">Noob question!
thanks for all the help. i plan on goin to the tracks tonight, last time i ran a 17.2 with 35psi in my tires, i had mad hop ... im hopin for 16s and 15s with the bottle!</TD></TR></TABLE>
1. use this for jet sizing http://www.robietherobot.com/N...r.htm
2. dunno, iam not useing one on my 75 shot
3. yes, atleast i do
4. if your new at this start small and work your way up.
![](https://honda-tech.com/forums/images/smilies/emcocktl.gif)
#1136
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garage 808 Hatch »</TD></TR><TR><TD CLASS="quote">a blow down tube is required to run at the track. 70 shot is fine on the d15, run atleast premium, retard the dist 3 degrees, and you better run 14's on street tires</TD></TR></TABLE>
the track here doesnt require us to have one.......i've ran without one every time i go to the track....
#1137
1. http://www.robietherobot.com/N...r.htm
2. at some tracks yes
3. out the hole no other way
4. spray it till it blows up after all its a d series $150-300 u got a new one
![](https://honda-tech.com/forums/images/smilies/emwink.gif)
#1138
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ghostofnyc »</TD></TR><TR><TD CLASS="quote">
#1140
so i didnt retard my timing, i dont know how, i did a 75 shot and on drag radials i ran a 15.5 ... i sprayed in all gears too! i also ran some ngk plugs, they werent cold plugs, i think i did alright. on the 1st run i bogged, i didnt launch high enough, and same thing on the 2nd exept i did a lil better, but still bogged, i only got 2 runs in 3.5 hours, it sucks! but i think i can get it in the 14s with a lil more practice and tuning!
#1141
so on the way home i raced another car, and when i was racing i noticed when i hit the nitrous it seemed like if i was pushing the button on and off, kinda like if it was stuttering, the car would pull, then kinda slow down, then pull again, anyone know what this is? i pulled the bottle off for now, thanks for all the help
#1144
yea i still havent checked the plugs, and i havent used the bottle since! and when i bogged i didnt use nitrouse, i was just the motor! but what could the power comin and goin be? thanks for the help!
#1145
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1BADEGDC2 »</TD></TR><TR><TD CLASS="quote">yea i still havent checked the plugs, and i havent used the bottle since! and when i bogged i didnt use nitrouse, i was just the motor! but what could the power comin and goin be? thanks for the help!</TD></TR></TABLE>
did you do a compression test on your motor before you sprayed it?
#1146
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1BADEGDC2 »</TD></TR><TR><TD CLASS="quote">so on the way home i raced another car, and when i was racing i noticed when i hit the nitrous it seemed like if i was pushing the button on and off, kinda like if it was stuttering, the car would pull, then kinda slow down, then pull again, anyone know what this is? i pulled the bottle off for now, thanks for all the help
![](https://honda-tech.com/forums/images/smilies/emhammer.gif)
Why would you install nitrous and not take the proper precautions, such as retarding the timing and running colder plugs?
#1147
i have a few nitrous questions if anyone can help me.right now im running a b18a1 with b18b1 head, crower 402-a cams, crower valve springs and retainers, blox intake manifold, blox 70mm throttle body, jdm 4-1 header 2.5 collector, cold air intake, xenocron 255 fuel pump, fpr, golden eagle fuel rail, stock injectors, 12 lb flywheel, and b16 tranny. i have a zex dry 75 shot kit installed on the car my question is the 75 shot ok to run if i change the stock pr4 pistons for a set or pr3 pistons? that will be bumping my compression from 9.2 to 10.9 with my setup.also what should i retard the timing to? zex says retard the timing 4*,also i have a friend who has a set of flat top pistons, and i was just wondering if they would be better or the pr3 pistons for nitrous. any help would be appreciated
#1149
ive been reading through it just havent really seen anything on people using cast pistons to forged pistons. just trying to make sure my setup will be ok
#1150
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bertsb18hatch »</TD></TR><TR><TD CLASS="quote">ive been reading through it just havent really seen anything on people using cast pistons to forged pistons. just trying to make sure my setup will be ok</TD></TR></TABLE>
From experience... My 302 was built with uber cheap (like $7.00 a piece) Badger hypereutectic pistons (non forged)
It was sprayed for YEARS with a 100 shot and was fine. Kinked fuel line and 150 shot got piston #1.. otherwise it would have continued to work just fine.
BUT, it was tuned properly and had the proper components (MSD Ignition, colder plugs, had 2 fuel pumps in line, ect)
SO, from that... People run 75 shots all day long with stock engines. you'rs is obviously not stock, but with the proper precautions, I don't see where you'd have any problems.
My .02
![](https://honda-tech.com/forums/images/smilies/emdgust.gif)
My .02
