My setup
Old Apr 24, 2003 | 07:12 AM
Dorikamu's Avatar
Default My setup
I am in the process of rebuilding my motor, and this is my setup
how much boost can I run on this sucker (it's a daily driven car and it needs to last 3 yrs at least).. Please also point out if there is something that I have missed.
Darton Stage 2 sleeves (from vsracing)
JE Pro Series 9.2:1 CR Forged Pistons
Bored 0.020 over to 81.5mm
Eagle ESP Forged Connecting Rods
ARP Rod Bolts
ARP Head Studs
Turbonetics T3/T04E Turbocharger (0.63 A/R Stage 3
turbine w/ 57 trim 0.60 A/R compressor)
Spearco Front Mount Intercooler
Drag Turbo Manifold
Drag Generation 3 Piping
HKS Super Sequential Blow Off Valve
Walboro 255 fuel pump
Hondata S100b
RC Engineering 440cc Saturated Injectors
Missing Link MAP Sensor Bypass
Crower 63402 Turbo Camshafts
Crower Valve Springs
AEM Tru-Time Cam Gears
Balanced/Micropolished Crank
3 Angle Valve Job
Swirl Polished Valves
C&R Dual Core Radiator
SPAL 1000CFM Thin Fan
Old Apr 24, 2003 | 07:17 AM
DR. ON POINT's Avatar
Banned
Default Re: My setup (chusai)
3 yrs? HAHHAHAHAHAHAHAH good luck
Old Apr 24, 2003 | 07:27 AM
Dorikamu's Avatar
is that impossible? where is the weak point?
I believe it's possible, I mean if I run 5 psi on it, it should be very reliable for years to come (some maintainence, but shouldn't need a engine rebuild).
so I guess the question what about of boost can I run and still be safe for 3 yrs.
I am taking a different approach than most FI pple (not most power, but most power in a long run). So some pointers pls.
thanks
Old Apr 24, 2003 | 10:54 AM
Slick GS-R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chusai &raquo;</TD></TR><TR><TD CLASS="quote">is that impossible? where is the weak point?
thanks</TD></TR></TABLE>
bump ...
Old Apr 24, 2003 | 11:11 AM
DC2R714's Avatar
Default Re: My setup (Slick_GS-R)
First off you don't need a missing link with hondata. Second, if you want to run more boost than 11psi you'll need a 3bar map sensor. Third, your injectors will be the deciding factor of how much boost you can run on that setup (Those 440's will tap out before you see any crazy boost levels). Lastly with a tuned hondata and reasonable boost levels for the street I think the motor could last three years. good luck
Old Apr 24, 2003 | 12:46 PM
Dorikamu's Avatar
Default Re: My setup (DC2R714)
so if I get hondata tuned, this setup should run 11psi with no problem theoritically?
Honestly, I don't think I will even need to drive on 11psi. I should be running 5-7psi most of the time.. I just wanna know what's the upper limit and get it tuned on 11psi.
Old Apr 24, 2003 | 01:17 PM
Mr. Softee's Avatar
that is a rock solid setup. at 10psi i bet it would last for a long time... you could easily hit 25psi with good tuning and better injectors... but your turbo's efficiency is going to start sucking past 15psi or so. That turbo is real small for your setup, although you are looking for a long lasting motor so for low boost its good.
Old Apr 24, 2003 | 01:40 PM
smallttocs's Avatar
Default Re: My setup (94goldjungsr)
you wont have problems.
Old Apr 24, 2003 | 01:42 PM
smallttocs's Avatar
Default Re: My setup (smallttocs)
and to be honest w/ you, Crower Turbo Camshafts wont make that big of a difference. stock cams are great. use the money towards something else.
Old Apr 24, 2003 | 01:48 PM
sIcWiTiT's Avatar
sounds like a sweet setup to me! goodluck
Old Apr 24, 2003 | 03:51 PM
ekb18c's Avatar
At 5psi and conservative driving it should last a while with maintenance offcourse.
If you are going to stay at 5-10 psi, I would suggest you go with higher compression pistons such as 10:1.
fyi- you don't need the missing link with hondata.
Old Apr 24, 2003 | 04:51 PM
mamaboy's Avatar
With such a beefed up setup why are you only wanting to run 5-8psi? and 9.2:1 compression isn't going to help you either. get yourself some 10.1:1 compression pistions and run 5-8psi. Compression helps spool your engine. Stock WRX's run 15psi of boost on their car...and if i remember correctly their compression is 8.8:1 or something along that line....9.2:1 RUN MORE BOOST....your engine can take it....and go to a tuner with the proper lambda meter and you'll be safe in the 8-15psi zone. and get the 3bar map sensor just in case ou spike and your map sensor just bugs out!....well that is if you go with more boost
Old Apr 25, 2003 | 08:04 AM
Dorikamu's Avatar
Default Re: My setup (mamaboy)
thanks for all the input. This is really helpful. Coz' most of the answer I got had been, "3 years, hahaha good luck"..
About the 5psi, I am just throwing it out there. I mean if it's safe enuf to run 10-15psi, I am more than happy to. But it sounds like anything beyond 15 psi is more $$. And I dont have budget for that.
Therefore I may just get the car tunned at 15psi.
Thanks folks.
Old Apr 25, 2003 | 08:22 AM
T-Blaze's Avatar
I think that's over kill for 5psi !!!!!!! Get that baby tuned to 15psi and it will still last u years...
Old Apr 25, 2003 | 09:36 AM
mamaboy's Avatar
look at your stock pistons and look at the your 9.2:1 pistons....look at where your rings sit...lower on stock correct......you will be fine with aftermarket pistons.....remember the H22 problem with ringlands always cracking....tune tune tune.....and boost boost boost....10-15psi...with 3bar map sensor...you'll be fine.....just don't downshift from 5th to 2nd too much will yah! ...one thing I noticed...you might max out your duty cycle on your 440s
Old Apr 25, 2003 | 10:48 AM
Dorikamu's Avatar
o.. it's a b18b, but thanks for the reminder anyways
mrkal
Jan 8, 2007 04:56 AM
Dorikamu
May 14, 2003 10:44 AM
95c1v1cs1
Feb 10, 2003 06:04 PM
shamoo
Nov 3, 2002 03:13 PM
