Mis-Shift/Rev Limiter Ect.....
Old Jan 2, 2005 | 06:28 PM
digital sol's Avatar
Default Mis-Shift/Rev Limiter Ect.....
i know that if you shift from second to third and accidentally put it in first there is no way to stop the rpm's from going through the roof, however isnt your rev limiter supose to cut off the rpms if you mis from third to fourth or 1st to second? My redline is currently set at 9k rpm, "yea i know i need to get it changed, i never drive it that high anways". I went from third to fourth and missded/grinded a little and of course it rev'd up. Check engine light flickered on when it got around 9k, i believe it stopped right around 9k, thats where my hondata rev limiter is set. Does hondata throw a code when yuo hit off the limiter? Car drives fine and everything runs perfect, it did the same thing after it was tuned on the drive home when i was around 9k.
ps: im getting my rev limiter set back to 8400 next week, i didnt want it that high, the tuner just set it that way
Old Jan 2, 2005 | 06:37 PM
RTW DC2R's Avatar
u might want to learn how to shift.
the rev limiter is not a mechanical device in your motor/trans that magically stops the motor from revving that high.
Old Jan 2, 2005 | 06:43 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
Default Re: (RTW DC2)
Cant you set the CEL as the shift light with hawndater?
Maybe the tuner thought u wanted 9k as the shift indicator
Old Jan 2, 2005 | 06:49 PM
SoCal ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">the rev limiter is not a mechanical device in your motor/trans that magically stops the motor from revving that high. </TD></TR></TABLE>
Word. The rev limiter stops gas from getting to the motor I believe, but if you enguage 1st at 60, nothing's gonna stop it from going through the roof.
Old Jan 2, 2005 | 06:51 PM
1Quikgsr's Avatar
Default Re: (v-attack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v-attack &raquo;</TD></TR><TR><TD CLASS="quote">Cant you set the CEL as the shift light with hawndater?
Maybe the tuner thought u wanted 9k as the shift indicator </TD></TR></TABLE>
LMFAO
Old Jan 2, 2005 | 06:54 PM
vtec.dc2's Avatar
Default Re: Mis-Shift/Rev Limiter Ect..... (digital sol)
it doesn't throw a code..
Old Jan 2, 2005 | 08:49 PM
1GreyTeg's Avatar
Default Re: Mis-Shift/Rev Limiter Ect..... (vtec.dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">it doesn't throw a code.. </TD></TR></TABLE>
That was a statement or a question?
04Sispeed
Apr 25, 2005 04:10 AM
digital sol
Nov 16, 2004 08:11 PM
done
Jun 8, 2004 09:00 PM
