is this ecu chipped?
Re: is this ecu chipped?
It's chipped, but they soldered the chip in an it will be a pain to get it out. If you can snip the legs off the chip, it will be easier to remove the chip without damaging the board.
A couple of macro shots of the socket+chip area will help.
read more. moates.com and PGMFI.org if you want to read a lot more.
chipped is good if it's needed. but it can be just as bad as good if the data on chip (or the tune... or the basemap...) is crap. also in most cases the chip must be removed to be "burned" or reprogrammed.
