tps code only comes on in vtec? help
Old Nov 15, 2008 | 05:15 AM
  #26
Turbogixxer's Avatar
Default Re: tps code only comes on in vtec? help (tealsvteceg)
If you go over 5v, the ECU will throw a code. You have to get your TPS WOT voltage under 5v, like turbo-charged said.
Old Dec 3, 2008 | 09:55 PM
  #27
z3r0's Avatar
Manage to fix it yet?
I lightly hammered down my throttle switch (thing that opens the butterfly valve in the throttle body) and my idling returned to normal. I have run it in vtec a couple of times and nothing has happened. Albeit i haven't run it until redline in every gear but everything seems to work..... *shrug*
Just to consolidate all the info...
WOT TPS voltage should read 4.5v?
Closed TPS voltage should read 0.45v?
Correct?
Old Dec 4, 2008 | 05:29 AM
  #28
mtber's Avatar
Correct?
Correct!
brandynEG
Engine Management and Tuning
13
Sep 27, 2013 04:51 AM
BIGef
Jul 22, 2013 10:01 AM
hotazztegra
Mar 7, 2008 07:15 AM
hotxcivic92
Jan 10, 2008 12:48 PM
94vtirozguy
Oct 10, 2006 02:18 AM
