Need P28 ECU help
Need P28 ECU help
Hey guys. Fried this component in my ecu and need to know what it is so I can order up another and get it fixed.
Any help guys would be appreciated.
It's impossible to tell by looking at it in the pictures.. no part number is visible. All we know is that it's a small transistor or IC inside a 3-pin package. The only way you'd be able to find a replacement is to open up a working ECU and read the part number off of the component.
Then the uestion comes - did it cook itself? or did something cook it?
Re: (kstokes)
the transistor is a D1780, looks like a honda specific piece. Its a fairly common tranistor that fails on the OBDI ecus. even when replaced it seems to get blown to pieces more times then non. take a look at the ecu and look for any shorts on the ecu first before replecement.
http://www.ee.washington.edu/c....html
Re: (Gregus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gregus »</TD></TR><TR><TD CLASS="quote">Do you know what type of transistor it is or a suitable part number that I can use for replacement?
Thanks,
Greg</TD></TR></TABLE>
http://www.necel.com/discrete/...9.pdf
I probably have a couple of these I can pull from an ECU I am parting out. Let me know if you still need one.
Thanks,
