lean at partial throttle w/engine management....ecu programers please help!
Old Aug 17, 2003 | 08:43 AM
VTgringo's Avatar
Default lean at partial throttle w/engine management....ecu programers please help!
I am running a turbo charged setup with 450cc injectors and a zdyne engine management. the tune that i have made is great for boost, it runs a little richer than stoich, my guess is around 12 to 1 or so. my problem comes when my throttle is below the 15% that i set for the computer to run in closed loop.
should i run my ecu in open loop at all times? could this cause any damage? is there any other way to run a closed loop program that wouldn't lean out?
thanks guys!
Old Aug 17, 2003 | 09:18 AM
VTgringo's Avatar
Default Re: lean at partial throttle w/engine management....ecu programers please help! (VTgringo)
bump
Old Aug 17, 2003 | 12:28 PM
VTgringo's Avatar
anyone?
Old Aug 17, 2003 | 04:58 PM
VTgringo's Avatar
i just fixed my vacuum leak so that shouldn't be effecting anything. I'm just going to set my car to run in open loop starting at 0% throttle unless someone tells me its bad. thanks.......i know there are smart people on this forum, this one just might take a little more action upstairs
Old Aug 17, 2003 | 07:15 PM
Teg4e's Avatar
you're guessing you're at 12:1 a/f, but you're not sure. are you getting this number from looking at a narrow band a/f guage? They're really not something to tune your engine with; it can only tell if you're rich or lean relative to stoich. i'd say get your car on a dyno + wideband a/f with a good tuner.
Old Aug 18, 2003 | 06:50 AM
legendboy's Avatar
Default Re: lean at partial throttle w/engine management....ecu programers please help! (Teg4e)
^^^ Good advice
gt35rSI
Mar 29, 2008 08:25 PM
pipes
May 5, 2005 10:09 PM
adeihl
May 12, 2004 07:14 PM
VTgringo
Aug 17, 2003 07:21 PM
