Engine bogs down at heavy acceleration
Old Jan 26, 2014 | 02:12 PM
existanzcivicb20's Avatar
Icon6 Engine bogs down at heavy acceleration
Hello all im in need of some help. I have a 1997 civic and i recently dropped an B18 into it the car runs great when its cold but when the engine gets warms up and i hit the accelerator the engine bogs down and almost dies after a couple of seconds the RPMs shoot up like normal.
And after i turn off the car it will not start back up unless i hold the throttle wide open
Things that i have replaced so far
plugs
injectors
fuel pressure regulator
distributor, cap, rotor
i did test the TPS tested out fine
what else should i look for
also i do have a walbro fuel pump on the car would that cause an issue?
I have posted a video of the issue on Youtube
https://www.youtube.com/watch?v=52ZP...ature=youtu.be
the check engine light is on due to both O2 sensors heating units
Old Jan 26, 2014 | 02:32 PM
tollickj's Avatar
Default Re: Engine bogs down at heavy acceleration
fuel filter sounds like its the issue.
Old Jan 26, 2014 | 03:34 PM
fcm's Avatar
fcm
Old Fart
Sounds more like an ECT sensor problem, engine is running rich when warm.
Symptoms of a bad ECT switch
1- Starts and runs OK when cold.
2- Hard starting when warm and runs like crap.
3- Poor gas milage.
Although the fuel filter may also be a problem, [symptoms do not match exactly] so if you do not know how old it is, replace it, it can't hurt.
Have you checked fuel pressure?
Have you confirmed valve and ign. timing? 94
Old Jan 26, 2014 | 06:42 PM
Timming is good and fuel filter is good, and the car runs great when cold or warm but I just keeps havin that issue I will try to test fuel pressure and also how do I test the ECT sensor?
Old Jan 29, 2014 | 06:03 AM
Bump
Old Jan 29, 2014 | 08:44 AM
tamboo's Avatar
10 Year Member
http://112.imagebam.com/download/V0t...8/page1232.jpg
http://www.spooledupracing.com/downl...dfbd31fb819d41
Old Jan 29, 2014 | 09:16 AM
KILLAB17VTEC's Avatar
Genetically Gay
Timing is off.
Old Jan 30, 2014 | 07:04 AM
Originally Posted by KILLAB17VTEC
Timing is off.
Can the car run and start fine with no missfires when cold with the timming off???
also when the car is at idel when hot it does idel fine and the car runs great after the initial bogging I just dont see how this can be a timming issue.
would having my timming belt too tight cause an issue?
Old Jan 30, 2014 | 11:23 AM
fcm's Avatar
fcm
Old Fart
If it runs "great after the initial bogging" I can't see it being a timing issue either.
It will be fuel or spark, the PGM-FI Main Relay, fuel pump and coil are all suseptable to heat failure and can be intermittent...
http://techauto.tripod.com/mainrelay.htm
http://techauto.awardspace.com/ignitionswitch.html 94
Old Jan 31, 2014 | 05:34 AM
Ok so I replaced my fuel filter again and it seems that the bogging got worse... Any Ideas?
Old Jan 31, 2014 | 06:47 AM
fcm's Avatar
fcm
Old Fart
Just because, redo the main grounds, batt./batt. to chassis and chassis to engine, also do the VC ground and thermostat housing grounds, DO NOT just eyeball them, disconnect/clean/reconnect.
Also still need to know what fuel pressure is when engine is "bogging".
I would also test the TPS to make sure it has no "dead" spots. 94
Old Jan 31, 2014 | 03:22 PM
redid all grounds, also changed my walbro fuel pump to a stock fuel pump and no change...
also i am getting code P0112 and i just dont know what the readings are supposed to be to the plug (volts and resistance) If someone can help me out with this?
Old Feb 1, 2014 | 09:56 AM
tamboo's Avatar
10 Year Member
http://troubleshootmyvehicle.com/hon...e-P0112-page-1
Old Feb 5, 2014 | 05:51 PM
will get a fuel pressure tester tomorrow and i will post the results
Old Feb 13, 2014 | 04:12 AM
fuel pressure test was a bust. the kit didnt have the fittings that i needed to test the pressure at the fuel rail but im not sure i may be able to test it before the filter (the filter is 2weeks old) but i will check for sure after work.
Old Feb 13, 2014 | 04:15 AM
also i did change my walbro fuel pump back to stock and no change. After the car is warm it still bogs down for a split second when i hit the accelerator and if the engine is turned off its hard to start back up unless I have the engine at WOT (wide open throttle). its like it floods its self when i turn it off.
Old Feb 13, 2014 | 04:25 AM
Old Feb 13, 2014 | 04:38 AM
AZ_CIVIC's Avatar
I say at this point before you going spending a ton of money keep replacing whatever people are telling you. Take it to a shop and let them have a look.. By the time you are done replacing everything that is ok it will cost more, just saying...
Old Feb 13, 2014 | 08:58 AM
thanks for the input but the only thing a shop has that i dont have is time. and everything that i have been replacing is stuff that i already own so its not costing me anything to at least try. I just want more ideas because im out of probable causes
Old Feb 14, 2014 | 05:47 PM
so i did more testing with the TPS and i noticed and i tried it with 3 different TPS that when i spin the sensor ( as if it was on the throttle body ) the voltage goes up fine until about 3 to 3.2 volts at that point voltage drops off and then comes back... and basically i have no idea why
I also posted a video on youtube take a look and let me know what you think and sorry for the music lol
Old Feb 15, 2014 | 07:13 AM
tamboo's Avatar
10 Year Member
there's a lot of bogus tp sensors out there,
looks like you need a new one. whenever the topic comes up
i cant wait to bash blox again for failing to stand by their craptastic
products- eff you blox! 8( grab a dorman, mine's doing great so far.
http://www.ebay.com/itm/Dorman-911-753-Throttle-Position-Sensor-/310873480279?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AIntegra&hash=item486180dc57&vxp=mtr
Old Feb 18, 2014 | 05:55 AM
ill repost when it comes in
paranemertes
May 11, 2015 09:46 PM
existanzcivicb20
28
Feb 18, 2014 05:54 AM
GT500FTW
Oct 5, 2012 02:26 PM
rewhipple
11
Nov 15, 2006 01:04 PM
bikeboy80
Oct 4, 2002 07:02 AM
