b20 vs b18 fuel map?
Old Jun 23, 2010 | 12:18 AM
rexracer626's Avatar
Default b20 vs b18 fuel map?
if im running a b20 with an ls ecu...will the fuel be sufficient for the b20?
Old Jun 23, 2010 | 06:27 AM
Scott_Tucker's Avatar
Default Re: b20 vs b18 fuel map?
Are you asking if you need to tune it? Yes, you do.
Old Jun 23, 2010 | 11:11 PM
not if i neeed to tune but more if i run a stock ecu will i run too lean? since its a bigger motor
Old Jun 24, 2010 | 05:45 AM
d1ck's Avatar
A stock, untuned B18B ECU will not have enough fuel for a b20. You might be able to run it temporarily by increasing the fuel pressure, butI can't say for sure because I've never done it before.
Old Jun 24, 2010 | 06:28 AM
No, you will not run lean if it is tuned right. I think I understand what you are asking. The ECU can control larger injectors required with a larger engine so it is not a problem.
efkilla
Aug 28, 2014 10:09 AM
crazyhondahead
Aug 12, 2011 10:47 PM
iloveb16
Mar 28, 2007 08:04 PM
blufke
Jun 19, 2002 10:20 AM
11secdx
Dec 26, 2001 08:20 AM
