Piston Ring Gap Questions/feedback
Old Mar 22, 2012 | 06:27 PM
  #101
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: PISTON RING GAP QUESTIONS
You don't read very well... Everything you listed confirms EXACTLY what I said. Also, If you gap the rings according to piston size you could have problems. Read everythig very slowly on your paper and then what I wrote and you will see the fine line that seperates the information.
Old Mar 22, 2012 | 06:32 PM
  #102
Spawne32's Avatar
Nah thats ok, im fighting off bad gas from dinner tonight.
Old Mar 23, 2012 | 06:26 AM
  #103
Muckman's Avatar
Moderator in Chief
The rings have outward tension. They are loose around the inside diameter of the piston. If the piston expansion affected the ring, the ring gap would contract as the piston heated. That is not true. The rings have tension on the outside diameter of the bore. As the rings conduct heat they expand and the gaps close.
Old Mar 23, 2012 | 07:11 AM
  #104
Spawne32's Avatar
You make an interesting point sir.
Old Mar 23, 2012 | 07:18 AM
  #105
rich7777's Avatar
Damn, so i was right in what i first said. To be honest it did leave me thinking for a bit yesterday. I was pretty sure that the piston to wall and the ring gap clearances were not related. But then what Spawn said made me see it from a different angle... O well, i guess we're all constantly learning
Old Mar 23, 2012 | 07:23 AM
  #106
Spawne32's Avatar
Theres like 8 different ways you can interpret it according to some of the information posted. lol
Old Mar 23, 2012 | 02:34 PM
  #107
DO IT ON ALL FOURS
Thank you for "dumbing" down what I said for them. (No offense to those offended. )
Old Mar 23, 2012 | 02:47 PM
  #108
Dc4LsTeG's Avatar
EK9
Wow a lot posted. So the piston expansion doesn't have an effect on ring gaps its just the heat that has an effect on the gap? Sorry guys I just want to be able to understand everything correctly and there's a bunch of diff. info in this thread. Like I said I just want to know how everything works as this is my first build
Thanks again guys for all the good info and discussion
Old Mar 23, 2012 | 03:50 PM
  #109
DO IT ON ALL FOURS
Just read what I posted and if that goes over your head then read what "Muckman" posted. It's really that simple... Also, haven't I been saying this since page one!?!?!?!
Old Mar 23, 2012 | 03:58 PM
  #110
rich7777's Avatar
Nope, the piston expansion has nothing to do with it. Its the actual temp of the rings what need to be considered (or power output of the engine).When they get hot they close up. Just gap them on the loose side of what ever Supertech recommend. Don't over think things to much or you'll lose your head and have to smoke that medical canabis for the rest of your life. You'll be fine, have some confidence in your self
Old Mar 23, 2012 | 04:05 PM
  #111
DO IT ON ALL FOURS
Are you talking to me "rich7777"?
Old Mar 23, 2012 | 04:11 PM
  #112
rich7777's Avatar
Ha,ha, no,no... You posted whilst i was typing up my message. Now how could i possible lecture YOU out of all people...
Old Mar 23, 2012 | 04:20 PM
  #113
DO IT ON ALL FOURS
Haha - OK, ok... I was about to turn into your avatar on your butt!!!
Old Mar 23, 2012 | 04:29 PM
  #114
Dc4LsTeG's Avatar
EK9
Lol thanks. I'm prob overthinking everything on this build that's why its taking so long. Like I said I'm only 19 and this is my first build I want everything to be correct. I dont have money for a rebuild if this motor messes up
Lol. Thanks for clearing those things up about the ring gaps, and thanks for the links they were good reads
Old Mar 24, 2012 | 12:33 AM
  #115
rich7777's Avatar
Lol, i guess i'll consider myself "blessed" on this occasion
Its ok man we've ALL been there once (and i mean ALL when i say it). Remember that no one is born with knowledge, its something you gain over time.. Just take your time with it and keep reading up, you'll get there.
BTW, your 19 !!!! no i mean your 19 and will be cruising around in 400bhp+ turbo Honda !! **** thats crazy... I don't know anyone over here that can let alone get insured on a stock EK9 at that age lol (My insurance is £1400 and i've been driving for years now with no claims what so ever). You do have something called "insurance" over there don't you ? or do you just personally sue that crap out of one on other after a crash lol (like what you American are best at... ARRRRR MY NECK, ARRRR MY BACK... GRRRR I CAN'T SLEEEP... WHERE'S MY LAWYER !!!! j/k).
Old Mar 24, 2012 | 01:20 AM
  #116
Dc4LsTeG's Avatar
EK9
LOL! Yea we have insurance. Mine is around $2400 a year but its only cuz my car is registeredvunder a special construction vehicle so on the insurance it says its a yr 2010, and cuz having full coverage
Old May 15, 2012 | 11:46 AM
  #117
Steeve_Civic's Avatar
Hello,
So what are your last gap?
Top: 0.019?
Second?
oil ring: 0.0035
What are the gap on CP spec sheet?
Thks
Old Apr 5, 2018 | 03:38 PM
  #118
James Reed's Avatar
Can anyone help me out I’m looking for ring gap specs for a b18c1 with 81.5mm bore I’m going all motor on pump gas and trying to get over 200hp
Old Apr 6, 2018 | 02:00 PM
  #119
TheShodan's Avatar
Moderator
You need to contact your aftermarket piston manufacturer. If OEM, go to OEM spec
Old Sep 27, 2024 | 03:35 PM
  #120
canito4dreg's Avatar
Default Re: Piston Ring Gap Questions/feedback
So I'm getting ready to gap my rings on my b18c5. I have supertech pistons w/ p2w at .004" and I'm looking to make between 4-500hp it WILL be a DD pump gas. Now I have the spec sheet from supertech on their sugggested piston ring gap calculations.
Now they say for top ring multiply bore by .005" for moderate turbo and .0065 for turbo race only
When doing the calculation I use the total bore right with my p2w clearence which is 3.21"?
Ok so when doing the math for moderate turbo I end up at
Top ring: .016"
Second ring: .02"
Now my question is I should be calculating for moderate turbo correct?and not race only?
Next do those numbers for my rings look good at those numbers? I don't really want it smoking on start ups.
TIA
I would gap those rings a lil more
Old Sep 27, 2024 | 08:56 PM
  #121
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
That member posted over twelve years ago... I am confident that the engine isn't STILL being assembled.
Johnoolo
Engine Machining & Assembly
Jan 16, 2018 08:52 PM
eg:R
Jan 30, 2011 04:08 AM
DulinDragons
Mar 23, 2009 08:41 AM
Yambor
Apr 29, 2005 10:55 PM
crxhybrid1320
Jan 6, 2003 07:02 PM
