Turbo Rings
Old Jan 5, 2003 | 07:22 AM
crxhybrid1320's Avatar
Default Turbo Rings
Wanted to see what type of rings everyone is using on there turbo engines. Right now im running the JE rings and pistons, just wanted to know everyones opion.
Old Jan 5, 2003 | 08:27 AM
b16 matt's Avatar
Default Re: Turbo Rings (crxhybrid1320)
oH YEAH JE DYKES AND JE PISTONS THATS WHAT I AM RUNNING......
Old Jan 5, 2003 | 09:05 AM
Jared's Avatar
I'm running arias pistons and the rings that came with them. Never had any problems with JE or Arias.
Old Jan 5, 2003 | 12:36 PM
2000TypeSh's Avatar
I'm also using JE Pistons and the rings that came witht hem.
Old Jan 5, 2003 | 07:27 PM
Default Re: Turbo Rings (2000TypeSh)
JE or Total Seal?
There probably made by the same company with a different name. Mine smokes at start up but i think its from the turbo large ring gap. Im going to redue it with not so much gap.
Old Jan 5, 2003 | 07:44 PM
V-SPEC 1's Avatar
As for ring gap is concern, is there any particular gap size for primary,secondary and oil rings are? or just use the standard honda spec?
Old Jan 5, 2003 | 07:55 PM
Default Re: Turbo Rings (boostedb20vtec)
Yes there is a spec depending on the piston size in inches times the spec for application you are running. When you get your rings it will have a spec chart and explain it pretty good. I did it like it said though and rounded the numbers up and it smokes at startup.
Example for My TURBO application rings:
Piston size in inches" X application running(NA or Turbo) for the two top rings.
Mine was 3.184 X .006 = My top ring gap.
Then 3.184 X .005 = MySecondary ring gap.
Lastly .015 for the oil ring gap should not need to gap these.
Im going to re-ring it and round the numbers down slightly and re-hone the cylinders.
[Modified by crxhybrid1320, 8:56 PM 1/5/2003]
Old Jan 5, 2003 | 08:15 PM
Evil EG's Avatar
Whats the difference in total seal and regular rings cause it seems that they are pushing total seal rings in magazine adds ALOT. Im going with what ever comes from JE but im curious to know why they are pushing these rings when alot of people say they are bad.
Old Jan 6, 2003 | 06:48 PM
Default Re: Turbo Rings (BVM)
JE pistons comes with JE rings.
Instuctions are included with the package.
Old Jan 6, 2003 | 07:02 PM
speedworks's Avatar
total seal,total ****. biggest joke there has ever been for a set of rings in imports.
DulinDragons
Mar 23, 2009 08:41 AM
crex23
Feb 2, 2006 05:41 PM
SPOOLINmatt
Mar 10, 2005 08:56 PM
ssr_h22
Sep 6, 2004 09:21 AM
B19CivicHB
Jun 19, 2003 04:15 PM
