Piston Ring Gap Questions/feedback
Old Mar 21, 2012 | 05:43 PM
  #76
Dc4LsTeG's Avatar
EK9
Default Re: PISTON RING GAP QUESTIONS
Originally Posted by blackeg
tell me about it. the cost of my piston to wall being a bit too tight last year was my #3 piston which caught the black death at about 7800rpm on the dyno. ill be damned if that happens again, so this go around i went from .0035 to .0045
Yea I was scared about my p2w being to tight. But I think it will be perfect at .004"
Old Mar 21, 2012 | 05:44 PM
  #77
Spawne32's Avatar
Originally Posted by Muckman
Ive researched this just as much as you have. At this point I personally wouldn't go any tighter than a .006 multiplier for 4-500hp.
My last engine made 450whp, 84mm bore. I used .020" gap (.006 multiplier) and didnt observe any crazy amounts of blowby or low compression test results.
Spawne and I talked about this offline. His thoughts are to keep it tight if its a street car bc it wont see extended periods of load to heat the rings up and make them expand. But as soon as you go the track (and of course you will), it becomes a race car and will see just as much load & heat. So it makes sense than you build it for the most extreme condition the engine will see, not the everyday. Idealy we want as minimal ring gap as possible but at the end of the day it doesnt seem to matter THAT much and the cost of it being too tight is your motor.
The real question is...HOW much do they actually expand. All depends on the materials your working with i guess.
Old Mar 21, 2012 | 05:48 PM
  #78
Dc4LsTeG's Avatar
EK9
well mine are high silicone pistons so they shouldnt expand as much as something with low silicon. What do you guys think about stepping up the gap on the top ring from .017" to .019"?
Old Mar 22, 2012 | 08:00 AM
  #79
Dc4LsTeG's Avatar
EK9
Old Mar 22, 2012 | 08:09 AM
  #80
rich7777's Avatar
If it makes you feel beter then do it. Remember a little loose is ALWAYS better than a little tight. If there been no sign of the ring ends touching on the next tear down then you know you can gap them a little tighter.
Old Mar 22, 2012 | 08:11 AM
  #81
Dc4LsTeG's Avatar
EK9
Thanks for the info. So you don't think .019" would be to loose?
Old Mar 22, 2012 | 08:15 AM
  #82
rich7777's Avatar
Also the piston alloy has nothing to do with the ring gap clearance. The same way as the ring gap clearane has nothing to do with the piston to cylinder clearance.
Old Mar 22, 2012 | 08:17 AM
  #83
rich7777's Avatar
Personally I don't think so. If it eases your mind and your going to put the car through hell then do it. You'll just have slightly more blow by.
Old Mar 22, 2012 | 08:20 AM
  #84
Spawne32's Avatar
You are aware that the ring gap closes as the piston expands from heat correct?
Old Mar 22, 2012 | 08:21 AM
  #85
Dc4LsTeG's Avatar
EK9
I understand that. But don't if you have a piston that expands more when it gets hot the ring gap will differ then it would on a piston that doesn't expand so much?
Old Mar 22, 2012 | 08:22 AM
  #86
Dc4LsTeG's Avatar
EK9
See this is what I thought. So alloy would play a role correct?
Old Mar 22, 2012 | 08:23 AM
  #87
rich7777's Avatar
Nope, I thought the ring end gap closed from the rings getting hot ? ****, actually i think your right... sorry OP
Old Mar 22, 2012 | 08:24 AM
  #88
Spawne32's Avatar
Of course it would, as the piston expands the cylinder around it acts like a ring compressor.
Old Mar 22, 2012 | 08:25 AM
  #89
rich7777's Avatar
Yeah your right, I totally see it now.
Old Mar 22, 2012 | 08:26 AM
  #90
Spawne32's Avatar
You being straight with me or just sarcastic lol i can never tell.
Old Mar 22, 2012 | 08:27 AM
  #91
Dc4LsTeG's Avatar
EK9
That is what I believed. Thanks a lot spawne you've been a huge help. Would you think stepping up to a .019" gap instead of .017" would be better?
Old Mar 22, 2012 | 08:28 AM
  #92
Dc4LsTeG's Avatar
EK9
Pretty sure he's being straight not sarcastic
Old Mar 22, 2012 | 08:29 AM
  #93
Spawne32's Avatar
The decision has to be up to you, you have the facts laid out, you gotta decide whether or not what you have will actually expand enough to risk running .017. Remember, we are talking thousands of an inch here, both ways can end up in disaster.
Old Mar 22, 2012 | 08:31 AM
  #94
rich7777's Avatar
No lol, I'm been straight with you. I should of thought about it properly before sticking my dick in like that. You made a good point. Your right, I'm wrong.
Old Mar 22, 2012 | 08:32 AM
  #95
Spawne32's Avatar
lol that will get you in trouble in alot more then just cars
Old Mar 22, 2012 | 08:36 AM
  #96
Dc4LsTeG's Avatar
EK9
I know thats what makes it so difficult to decide. Thanks again spawne for being a big help I think I'm going to go to .019" on the top
Old Mar 22, 2012 | 08:37 AM
  #97
Spawne32's Avatar
Sounds good.
Old Mar 22, 2012 | 08:40 AM
  #98
Dc4LsTeG's Avatar
EK9
Thanks again to everyone that chimed in and helped me.
Old Mar 22, 2012 | 06:06 PM
  #99
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
This thread is still going? HAHA...
Piston expansion has absolutely nothing to do with ring end-gap. I get such a kick out of people talking about "how much more" a forged piston expands than a cast piston when they actually have no idea what they are talking about...
The coefficient of thermal expansion has absolutely nothing to do with how a piston is made. Forged or cast, it doesn't matter. The coefficient of thermal expansion is determined by the alloy used for the piston. A typical forged piston is made from low-silicon 2618 alloy. This alloy will expand about 13% more than a typical high-silicon (as much as 18%) hypereutectic piston. 13% of 2/1000's of an inch is only .0003".
Again, piston expansion has NOTHING to do with ring end-gap... How the piston transfers/absorbs the heat to the rings, as well as the ring placement, and cylinder pressures: YES! If you are having problems from piston exapansion and ring end-gap, you don't have proper backspacing to begin with.
Light Reading:
http://en.m.wikipedia.org/wiki/Piston_ring
In Depth Reading:
http://www.powermasters.com/heat_energy.html
http://www.enginebuildermag.com/Arti...orsepower.aspx
http://www.elstars.com.au/pdf/piston_rings_guide.pdf
Oil Loss From Ring Gaps:
http://www.kb-silvolite.com/article....n=read&A_id=56
Now I have just gone too far:
http://www.federalmogul.com/NR/rdonl...S200976080.pdf
Old Mar 22, 2012 | 06:16 PM
  #100
Spawne32's Avatar
Light Reading:
In Depth Reading:
Interesting, because the paperwork that i have sitting in front of me from supertech regarding piston ring gaps says you are to size it depending on the diameter, alloy, and type of forging of your pistons along with the application of use and operating conditions. So basically what your saying is supertech, the piston manufacturer, is wrong.
