Cracked block
Old 04-22-2019, 10:10 PM
96accordsir's Avatar
Default Cracked block
So i was changing my head gasket the other day on my sleeved gsr, and when tightening down the head studs it cracked the block. it was leaking behind the oil dipstick. All the studs still torqued to 85 ft and we welded the block, and it doesnt leak water anymore. you think its still fine??
Old 04-22-2019, 10:13 PM
JRCivic1's Avatar
Default Re: Cracked block
Try it. You have nothing to lose.
Old 04-22-2019, 10:25 PM
hahaha, the motor only has 500 miles :....((
Old 05-07-2019, 03:36 PM
motoxxxman's Avatar
I did that once. Welded it back together and drove it for another 50k miles or so no problem.
The thing is, the whole reason it cracked is because my torque wrench was calibrated wrong. I thought I was torquing the head studs to 85. Turns out I was actually torquing them to 125. You might want to get your torque wrench checked out.
Old 05-09-2019, 05:53 AM
civichxtreme2's Avatar
With a good weld and no distortion to the cylinder itself (which I doubt happened due to the sleeves) you should be fine. Ive seen even crappy block welds last a long time.
horn12007
18
09-02-2010 04:21 PM
[ iLL ] iNt3GrA
11-16-2009 02:34 PM
absolut01gsr
06-04-2008 04:55 PM
sepulchral
06-09-2006 06:50 AM
80884
12-08-2004 04:09 PM
Quick Reply: Cracked block
