Precision core vs competitor, pics inside!!
Old Apr 30, 2012 | 09:11 AM
ChrisMillerRacing's Avatar
Default Precision core vs competitor, pics inside!!
We're a huge supporter of Precision products as well as their intercoolers. I had another intercooler come in so I had a chance to take a pic showing the fin density of each. I just wanted to show that not all bar and plate intercoolers are the same. Precision core have a higher fin density which does make a difference in cooling the intake charge.
This is a Precision 750hp AS1026 core looking in from the end tank
This is a competitor's core used by many shops around the country in multiple different markets. These cores are cheaper than precision or garret cores and while they still work well, they are not the same
*EDIT
more info from ETS
The first thing you want to check out is the fin pack design. An offset and staggered fin design will be your best bet in dissipating heat. The straight through fin design will pass the air right through like a tunnel, the offset and staggered fin pack breaks up the air molecules and forces the air to come in contact with multiple fins creating a denser charge air.
ETS staggered fin pack
ETS Core
** Ebay Core (Notice how the air flows directly through the intercooler and not off the fins)
-Steve
Old Apr 30, 2012 | 09:38 AM
ESP.net's Avatar
Default Re: Precision core vs competitor, pics inside!!
Precision intercoolers always been top notch... you can get exactly the power they are rated for out of them with no issues...
Cheaper intercoolers have always had to up the size to compensate...
Old Apr 30, 2012 | 09:45 AM
Zer0_SpeedWorks's Avatar
Been using precision cooler for several years nothing bad to say about it.
Though now im using a garrett core due to size.
Old Apr 30, 2012 | 05:53 PM
h2.4's Avatar
be nice to see some air temps going in and out in a controlled environment and boost pressures in and out, to compare rather than pics of "fin density"
Old Apr 30, 2012 | 09:53 PM
turbo_rsx's Avatar
Old May 1, 2012 | 06:37 AM
So please conduct this test and post the results up.
Old May 1, 2012 | 11:51 AM
h2.4's Avatar
I'm not the one selling precision products or posting pics of stuff and why it's better. So please conduct this test and post the results up.
Old May 1, 2012 | 03:40 PM
gringotegra's Avatar
Is the "competitor's" core an ETS core?
Old May 1, 2012 | 03:42 PM
From ETS:
The next would be the intercooler core design. We prefer a bar and plate core. This core does an amazing job at being efficient.
** ETS Core VS Garrett (We do something a little different here by changing the size of the charge row to give us more heat transfer plates. If we have an extra 4 charge rows over the competitor core in the same area we get 8 extra heat transfer plates. This is the top and bottom plate of the charge row. By doing this we can loosen up the internal charge rows which gives us less pressure drop and more external heat transfer area.
Here is a picture of the Garrett core that we cut in half to make a smaller SRT-4 intercooler. The internal results of the Garrett core were a bit disturbing. The core doesn't look like it would flow too well.
** Garrett Core On Top / ETS Core On Bottom
** ETS Intercooler Core Components
Old May 1, 2012 | 07:12 PM
tony1's Avatar
You can argue that a Garrett Intercooler doesn't look like it would flow well, but you can't argue with the FACT that they work damn good.
Old May 1, 2012 | 10:26 PM
hussain-vtec's Avatar
Good Info ......
Old May 4, 2012 | 07:45 PM
Yea I was thinking the same thing
-Steve
Old May 5, 2012 | 02:18 PM
jj07's Avatar
OG Fabricator
anybody use the Bell intercooler cores curious how they look and work
Old May 6, 2012 | 09:17 AM
No it is not
-Steve
Old May 7, 2012 | 10:15 AM
speeddave's Avatar
Nice comparison, I've always been a fan of the precision intercoolers(I currently have the 600hp version)
A little OT, but I am wondering if anybody has pusted the 750hp version much past the advertised rating before the IAT's got out of hand?
Old May 8, 2012 | 08:29 AM
we have ; ) but not far.
miniboarder1
Mar 24, 2008 08:56 PM
.RTErnie
Oct 8, 2005 05:16 PM
Loco Honkey
May 25, 2005 01:30 PM
memphiss13
Sep 24, 2004 02:18 AM
legendboy
Feb 8, 2003 05:14 AM
