NOV FS thread
Old Nov 22, 2012 | 11:18 AM
  #101
1QwIkEf's Avatar
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
Default Re: NOV FS thread
G-force dog box for sale. Used 1 season. Will come as a complete transmission. Gsr quaife and all case modifications done by dynamic performance. Trans with be torn down inspected and all parts that my be damaged will be changed before sale. Trans will %100 ready to use when received.
1st2.92
2nd 1.88
3rd 1.40
4th.. 1.9
Final drive 4.3
$4600. + shipping and PayPal fees.
Best way to contact is text 240-217-0647
i have 2 tial mvs 38mm gates for sale used for mock up. one black and one silver. $225 each. shipped
Also have a set of super tech Nitrided coated std size flat face valves.$160 shipped
Old Nov 23, 2012 | 11:29 AM
  #102
vtechjunkie's Avatar
pm'd
Old Nov 23, 2012 | 01:22 PM
  #103
MrParks's Avatar
autometer pro comp silver water temp mechanical 2" used 20.00
autometer oil pressure mechanical black 2" used comes with -3 an teflon high pressure hose 30.00
FCSRace pro series battery tray tank comes with -8feed -6 return fits 92-01 civic int. deletes battery tray and bolts up to the fuse panel location. 300.00
AFX Air-Fuel Ratio Monitor Kit -Displays Air/Fuel ratios from 9.00 to 16.00 -Accurate to within 0.1 A/F point
comes with ntk sensor, very fast reliable and can be wired straight into your hondata or any exsisting ecu that has logging. sensor is like new and still in warranty
250.00
M&W pro-10 ignition with msd 7 series hvc2 coil in mint condition comes with everything. oem distributor modified by motec. uses all exsisting factory units pick up must be used from a cam sensor or you will need to add your oem pick ups back in the system. comes with msd cap rotor and ngk wires. m&w will have plug and pins not shown for easy install. best ignition you can get for single coil. 500.00 for everything.
msd 6 series coil like new condition. comes with mounts etc. 100.00
accufab 90mm tb with vi-ton o ringed 4" band and tb cable modified for oem Honda throttle cable. comes with new gasket, decal and oem box. 250.00 if you want the 4" vband clamp and other side it is additional 25.00
jacobs pro ignition box new. makes great starter ignition for hondata. s series models. 100.00 take it off my hands.
aebs head studs b series used in great condition 60.00
energy suspension poly trailing arm kit for 90-01 civic integra. new in box 40.00
aem fuel pressure regulator new in black oem box all the fittings direction booklet etc 100.00
place racing b series 88-91 civic mounts for ef chassis. great condition. 100.00
Old Nov 23, 2012 | 08:34 PM
  #104
dschenke's Avatar
damn old school mounts jay^^
Old Nov 24, 2012 | 10:23 AM
  #105
dturbocivic's Avatar
Default JM Fabrication GSR Intake manifold
JM fabrication GSR intake manifold 535.00 shipped
12 injector bungs. + throttle body flange is mustang (105mm)
Old Nov 24, 2012 | 11:13 AM
  #106
rayray24's Avatar
Hondata traction control
BNIB
$575 firm
Lsvtec4life@yahoo.com
BNIB Nlr ams1000 boost controller
$800obo
Old Nov 24, 2012 | 06:41 PM
  #107
mint's Avatar
Sold
Old Nov 25, 2012 | 12:39 PM
  #108
hondacivic946's Avatar
Blox tuners stage 3s b seriers cams $350 shipped plus paypal fees
k tuned rdx 410cc injectors with pigtells $150 shipped plus paypal fee
Both items have tops of 500-600 miles on them
Any questions feel free to msg me 724-984-7382
Thanks Floyd
Old Nov 25, 2012 | 03:37 PM
  #109
JDM JEFFREY's Avatar
Lithium pros c680-16 volt battery and charger
the battery Im selling is new in box summit racing sells the battery and charger for $999.99
Comes with bolt in eg battery box
And fast connect plug for battery to charger
I paid 1000.00 shipped
Will sell for 650.00
Old Nov 27, 2012 | 01:52 PM
  #110
ChokeOnMySmoke's Avatar
774 888 7219
Strada 3 piece front eg 600.00
Liberty trans with billet bel housing 5500.00
Cf doors eg 1200.00
Old Nov 28, 2012 | 06:53 AM
  #111
T76U13ALT's Avatar
M&H 24x3.6x15 skinny tires with only 2 track passes on them, no holes or patches. $230 shipped OBO in the USA.
SOLD!!
Old Nov 28, 2012 | 07:45 AM
  #112
stevieriot's Avatar
For Sale:
ASP Headers 5 gallon fuel tank. Fits OEM location, uses OEM filler. -10an and -6an return. $300 firm.
Competition Clutch twin disc. B series. Used 2 seasons. still great life left. $600 firm,
OEM JDM SiR Ferio 92-95 Civic Sedan flush mount spoiler. Black, 9/10. $300 firm.
DC Integra rear disc setup with cables and lcas. No rotors or pads, comes with ARP extended studs. $150 firm.
Beaks Tie Bar. Gold. Fits EG/DC. Scratches on bottom. $60 firm.
Fully built GSR head. DG machine port and polish for all motor drag setup. Head was milled. Supertech guides, supertech valves, supertech retainers, supertech valve stem seals. Rocker pads resurfaced for new skunk2 pro 2 cams. Skunk2 pro series valve springs. BDL adj cam gears. Comes with lsv kit and cometic 84.5mm headgasket. Victor x manifold and 76mm blox throttle body. Golden Eagle pro series fuel rail. speedfactory thermal intake manifold. dsm 450cc injectors. Comes with ASP catch can/breather with lines and fittings and battery and valve cover. dizzy, vtec, and other sensors included. Ran one season. $2000 firm.
M&h slicks. 8x22x13. mounted on bassett racing steelies, 13x8. 4x100 lug pattern. Used 3 passes. $350 firm.
local pickup tacoma wa only for now. email stevieriot@gmail.com
Old Nov 28, 2012 | 08:01 AM
  #113
kc03e46's Avatar
Default Parts for sale
I have a set of OBX GSR ITB'S for sale $350.00 shipped. Used for dyno testing only. The runners have been port matched. Hasport cable to hydro conversion $75.00. 88-91 hasport solid motor mounts $200.00 rear mount not shown in pic but is included. also have stock gsr cams 75.00 and complete stock gsr intake manifold with tb and fuel rail. 75.00
Old Nov 28, 2012 | 03:27 PM
  #114
turboed4dr's Avatar
Custom JDL Design intercooler
Powdercoated cast endtanks - 24x12x3.5 Garrett core (950hp)
Was used with full-race topmount on EK Civic
$600
Please feel free to text or call with any questions (.301.643.7975.)
Old Nov 28, 2012 | 06:33 PM
  #115
b-built's Avatar
couple parts
h22 obx diff $250
2 sets of h22 eagle rods $200 a set there fresh
90 mm 9.1 compression wesico piston less 200 miles on them $300
87mm mahale 11.5.1 compression $300
88mm sleeved closed deck block $400
90mm darton sleeved closed h22a1 block $700
h22 hasport eg/dc mounts $175
msd 6al box with ss blaster coil$90
h22 skunk2 intake manifold with 69mm tb complete$280
h22 skunk2 intake manifold with q4590mm tb $320
h22 arp headstuds torque once $60
i have many h22 parts just text me for pics or questions
516-403-7564
Old Nov 29, 2012 | 01:43 AM
  #116
jeff 16's Avatar
13 x 10 weld racing wheels 5" back space 4x100 lug pattern the wheel barrels have been powder coated flat black and already has rim screws on them. They will come with 24.5x9 Mickey Thompson slicks that have only 6 passes on them. $850 takes them I am located in New York give me a call if you are interested 917-847-7476.
Old Nov 29, 2012 | 11:41 AM
  #117
b18c1Monster's Avatar
Avid eg/dc mounts
in great shape.
$180
203-479-2274
Old Nov 29, 2012 | 07:53 PM
  #118
T76U13ALT's Avatar
I have a brand on light used Volk TE37 5x114.3 15x8 +45 offset. I bought these brand a few years and only used them one day @ the track and were never street drive. No bends or curb rash, very rare wheels in this size. I'm asking $550 shipped in the USA..
Slicks not included..
Old Nov 30, 2012 | 12:14 PM
  #119
tenthelementracing.com's Avatar
PCS Dash Logger D200 Pro Kit with extras, $1000 FIRM.
Part Number: DIS-9300
Suggested Retail is $2050.00 for the pro kit.
Here is some info on it:
The D200 Pro Kit is designed for the racer who wants all the components of a solid data acquisition foundation.
Base Items•D200 Dash Logger. Part Num DIS-2022
•8-Channel EGT Module. Part Num EGT-2000
•3-Axis Accelerometer. Part Num ACC-2000
•CAN Master Connection Kit. Part Num CON-5500
•CAN Add-On Connection Kit. Part Num CON-5501
This can do speed, pressure, temperature and EGT measurements. Has six sensors total, 4 EGT probes, and an extra harness for easy swapping from car to car. You can use this for a 4, 6, or 8 cylinder motor, and can add on more EGT probes. I purchased this for my dragster, but since then sold the dragster.
Pm me if interested.
Old Nov 30, 2012 | 06:28 PM
  #120
zuptidi's Avatar
I have a set of 4 RDX 410cc injectors. With about 5k miles, i'm moving to e85 so these need to go.
They come with the Rosko Racing Adapters so they fit snug in a H22/H23 manifold
http://www.preludepower.com/forums/s...27#post3021127
They also come with the Top adapter so they can fit stock h22/h23 Fuel rail. (the Green adapter)
also comes with the inj clips/plugs.
170$ shipped
crazes
Dec 27, 2015 09:10 AM
crazes
Nov 29, 2015 04:24 AM
crazes
Mar 31, 2015 06:04 AM
crazes
Mar 31, 2013 01:56 PM
ahobbs
Sep 1, 2012 07:23 AM
