MSD 3 step hookup
Old Sep 15, 2004 | 12:02 PM
SPOOLINmatt's Avatar
Default MSD 3 step hookup
i got the msd soft touch 3 step rev control. its bad *** cause i can get my launch rpm exact every time and its sounds kool as **** sitting at the line holding it. but anyways....i tried to wire it where when the clutch is in it would make it active. I have to tap it in to a wire that supplies 12v when clutch is pressed in so i tried hooking it at the clutch start switch that is activated when clutch is pushed in....didnt work so i was forced to wire it on a switch for temporary(which sucks). anyone know where this wire is i need for 12v when clutch pushed in. under hood anywhere?
Old Sep 15, 2004 | 12:15 PM
12.sec.HB's Avatar
Default Re: MSD 3 step hookup (arsenic57)
Other than installing it, How does it work? Will it get 60fts lower?
Old Sep 17, 2004 | 10:08 AM
Default Re: MSD 3 step hookup (12.sec.HB)
creates a rev limiter that you pre determine...so when your at the line, you can hold the clutch in...floor it...and it rev limits at say 3000...so you can floor it off the line...its builds my boost up to about 2lbs....which is awesome off the line...could really improve my 60footer...but i have it on a hand switch right now...not the clutch pedal which i dont like at all.
Old Sep 17, 2004 | 10:22 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
maybe this thread will be helpful to you, The 2step is the same as the three step, only with one extra wire for he oe extra switch
https://honda-tech.com/zerothread?id=450056
Old Sep 17, 2004 | 10:40 AM
civickiller's Avatar
Default Re: MSD 3 step hookup (SIXTYdashONE)
do you need an msd box to run this, like the msd 6a or al ?
Old Sep 17, 2004 | 10:42 AM
HT's Biggest Loser
Default Re: MSD 3 step hookup (civickiller)
You need a MSD 6AL..
An MSD 6A will NOT accept a 2/3 Step Module
underpressure02
Apr 5, 2004 01:02 PM
underpressure02
Dec 22, 2003 04:11 PM
white_98_gsr
Nov 30, 2003 06:12 PM
Lei Siew Long
Aug 5, 2003 03:02 AM
fastludeh22
Apr 22, 2003 01:31 PM
