install of MSD two step and microswitch
Old Aug 4, 2003 | 12:47 AM
Lei Siew Long's Avatar
Default install of MSD two step and microswitch
i want to retain the ability to start up my car by clutching in and want to add in a microswitch to do so.
how would i wire this up? would it be correct by wiring in a 12v source from the fusebox to one of the prongs on the microswitch and the other prong would go to one of the wires on the clutch switch? and the second wire from the clutch switch would go to the red wire of the two step?
Old Aug 4, 2003 | 12:14 PM
Default Re: install of MSD two step and microswitch (Hatch4urSnatch)
ttt
Old Aug 4, 2003 | 01:28 PM
someone has to know.
Old Aug 4, 2003 | 01:33 PM
hybridreams's Avatar
I've never heard of that.
How does installing an MSD 2 Step module/ignition box disable the need to engage your clutch when starting your car?
Old Aug 4, 2003 | 07:49 PM
Default Re: install of MSD two step and microswitch (hybridreams)
from what i've been told, it disables the function of the clutch when starting the car up because you have to short the clutch switch harness. feel free to correct me if i'm wrong.
Old Aug 4, 2003 | 10:45 PM
i know someone has the answer to this
Old Aug 5, 2003 | 12:32 AM
TurboDANDEE's Avatar
I have mine hooked up to my clutch pedal and i can start my car up. I forgot how exactly how i wired it cause it was a while back, but u can PM SIXTYdashONE because he's running the same set up as me and helped me out before.
Old Aug 5, 2003 | 03:02 AM
Default Re: (TurboDANDEE)
thank you
SPOOLINmatt
Sep 17, 2004 10:42 AM
underpressure02
Apr 5, 2004 01:02 PM
underpressure02
Dec 22, 2003 04:11 PM
white_98_gsr
Nov 30, 2003 06:12 PM
fastludeh22
Apr 22, 2003 01:31 PM
