Lightweight battery for high compression engine
Old Apr 18, 2007 | 08:06 AM
CRXEE8's Avatar
Default Lightweight battery for high compression engine
I have a problem finding a lightweight battery that can start up my 16:1 engine. I tried using a Odyssey PC680 but that won't even turn the engine over. Right now I have to use a big 60 amp battery and that sucks big time. What light weight / drycell battery should be ok for my application?
Old Apr 18, 2007 | 08:43 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Lightweight battery for high compression engine (CRXEE8)
just thought of this as i am working on a chop saw,
do they make de-compression buttons he hee?
what about a gear reduction starter? i think there is one for a honda.
Old Apr 19, 2007 | 05:13 AM
jjspec's Avatar
Default Re: Lightweight battery for high compression engine (boostedcivicsir)
I use an Odyssey 0675-2028. It is small but not lightweight. 60 amps is very small. You need to use a sufficient size battery and put it where the weight will be beneficial. You may have other issues if your odyssey 680 is not working
Old Apr 19, 2007 | 06:22 AM
tony1's Avatar
Yeah, the PC 680 has 680 cranking amps, if it won't crank your engine, you have other problems.
Old Apr 19, 2007 | 06:32 AM
West Werks's Avatar
Default Re: Lightweight battery for high compression engine (tony1)
I have that EXACT battery and it turns over my 15.1 b-series with no issues at all.... Like Tony said, there is something else wrong.
Old Apr 19, 2007 | 06:37 AM
CRXEE8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, the PC 680 has 680 cranking amps, if it won't crank your engine, you have other problems.</TD></TR></TABLE>
I was thinking the same but when I use the 60 amp hours battery from a small truck it fires up right away. If a PC680 should be plenty for a 16:1 engine why are several pro allmotor cars using a big Powermaster battery? That thing weighs 33 lbs.
Mr. Badwrench
check your grounds. make sure the cables are enough to support the amperage needs of that strter.
Old Apr 19, 2007 | 06:58 AM
West Werks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXEE8 &raquo;</TD></TR><TR><TD CLASS="quote">
I was thinking the same but when I use the 60 amp hours battery from a small truck it fires up right away. If a PC680 should be plenty for a 16:1 engine why are several pro allmotor cars using a big Powermaster battery? That thing weighs 33 lbs. </TD></TR></TABLE>
No alternator...
Old Apr 19, 2007 | 07:04 AM
SpeedDreamz.com's Avatar
Default Re: Lightweight battery for high compression engine (West Werks)
How long is your positive cable? That really taxes the current ability of the battery
Old Apr 19, 2007 | 07:06 AM
jjspec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">.I was thinking the same but when I use the 60 amp hours battery from a small truck it fires up right away</TD></TR></TABLE>
I am thinking dead cell, sulfided plates, improper charge maybe. Sounds like you have an issue with your battery. You can take it to a Odyssey dealer to have it checked.
Old Apr 19, 2007 | 07:07 AM
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by West Werks &raquo;</TD></TR><TR><TD CLASS="quote">
No alternator...</TD></TR></TABLE>
and they are 16volts.
bigger fuel pumps like the higher voltage too.
Old Apr 19, 2007 | 08:30 AM
regamaster's Avatar
Look into Powermaster. They have release a new series of batteries.
They also have available the 16v batteries too in a standard and lightweight.
They also have a stock size Honda battery that has 800 Cranking amps.
We are using them in our drag car and have not had any issues and we are not running an alternator.
Old Apr 19, 2007 | 09:43 AM
CRXEE8's Avatar
Default Re: Lightweight battery for high compression engine (regamaster)
I'm using a stock RSX charging harness so that should not be the problem. The battery is brand new and I did check the voltage across it before it was installed. I will look into it tomorrow. Otherwise thanks for the suggestions
Modified by CRXEE8 at 1:14 PM 4/19/2007
Old Apr 20, 2007 | 11:26 AM
zCivic's Avatar
Check for the MR Gasket High Torque Starter on here. For my 12.5 (I know quite a bit less C/R) but it starts like stock with a PC680 while the stock starter died pretty quick. They say its good for 18:1 C/R.
schueytenten
Oct 23, 2010 03:45 AM
alacard
Audio / Security / Video
Jan 12, 2008 05:39 PM
smash fascism
Dec 3, 2005 07:58 PM
s2kkk
20
Apr 1, 2004 12:54 PM
tchet
10
Apr 17, 2003 10:27 AM
