Will this battery be enough juice?
Old Jan 10, 2008 | 07:46 PM
alacard's Avatar
Default Will this battery be enough juice?
Planning on getting a smaller-type battery. The car is a 99 hatch with a GSR engine. I'm pretty sure that the battery will be enough to start the engine. But I will also have a mild audio setup with 1 amp powering some speakers (no subs). Just want to make sure It will be good before I buy one.
http://www.odysseybatteries.co...s.htm
Also, does anyone know if I would need the metal jacket one?
Old Jan 11, 2008 | 04:04 PM
alacard's Avatar
Can anyone help me out?
Old Jan 11, 2008 | 04:45 PM
JSPECSIR's Avatar
Default Re: (alacard)
I HAVE NO IDEA if it will work or not, but most people on here use the 680 if that helps.
Old Jan 11, 2008 | 04:54 PM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Will this battery be enough juice? (alacard)
The metal jacket battery comes with a removal metal sleeve/case to go around the battery. You would only need this if the battery was going to be close to an exhaust manifold or something. I have seen them used as mounting soulations as well.
While the car is on the battery will be charging, the alternator will power the entire car as well as charge the battery. You just won't be able to power other accessories for extended periods of time with the car off.
A battery that small should really only be used on a race car.May I ask why you want a smaller battery?
Old Jan 11, 2008 | 07:03 PM
alacard's Avatar
Default Re: Will this battery be enough juice? (White Smoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">I have seen them used as mounting soulations as well.</TD></TR></TABLE>
As in...a way to mount it other than using the stock battery holder/bracket?? Or what do you mean?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">A battery that small should really only be used on a race car.May I ask why you want a smaller battery?</TD></TR></TABLE>
The car is not a race car. I need a new battery and I'm trying to clean up my engine bay. I like the look of a smaller battery. What do you suggest rather than the 545?
Old Jan 12, 2008 | 05:39 PM
i my honda
Global Mod
I would stick with a factory sized battery. The smaller batteries do not last as long and are hardly a great weight savings. Even the more common PC680 will not last long. After it dies a few times it wont hold a charge.
pimpassride99
Audio / Security / Video
20
Jun 17, 2007 08:04 PM
lil'ek
Mar 22, 2006 06:21 AM
MooreBoost
Jan 27, 2005 03:53 AM
BlackThorN
15
Jun 27, 2004 01:31 PM
Speedyturtle
Jun 16, 2002 07:12 PM
