How to run alternatorless?
Old Jan 4, 2003 | 11:15 AM
paulzy's Avatar
Default How to run alternatorless?
How do you set it up? is it just a regular battery, then you charge it after each pass or what?
what battery?
Will a regular car charger be ok?
Old Jan 4, 2003 | 11:35 AM
bambooluv's Avatar
Default Re: How to run alternatorless? (1320development)
Go to jegs.com and look for a turbostart battery and the charger .Its a 16v system which youll need thats all I can think of anyone else wanna shed some liught on this? Tyler, tony ,earl ?-pdang
Old Jan 4, 2003 | 12:20 PM
hondaswaper's Avatar
Default Re: How to run alternatorless? (bambooluv)
you need to buy a TurboStart 16V 2 post battery from Jegs or summit
the TurboStart 16v battery charger from Jegs or summit
you have to buy the Acid for the Battery Local
Sell your alternator on Honda-tech
Old Jan 4, 2003 | 02:14 PM
paulzy's Avatar
Default Re: How to run alternatorless? (hondaswaper)
is that it? I thought it was more complicated than that...thanks
Old Jan 4, 2003 | 03:38 PM
TREVER's Avatar
make sure your batt holds 13.5 volts
Old Jan 4, 2003 | 05:09 PM
earl's Avatar
Default Re: How to run alternatorless? (TREVER)
Here's another thought. Run the alternator but put a switch cutting the larger black with yellow stripe wire coming off the alternator. This shuts off any resistance in the alternator that would rob most of the horsepower. You can re-instate it after the run and use the alternator on the way back to the pits. I did this but never had the guts to try it on a run
Old Jan 4, 2003 | 06:08 PM
tony1's Avatar
Default Re: How to run alternatorless? (earl)
The main problem is that during a run a stock charging system will usually fall to less than 13 volts which slows fuel and water pumps down. The 16 volt battery will never drop below 14.5v and usually stays around 15 or so during a pass. It is a big benefit to methanol cars since we are pushing the fuel pumps so hard. Most fuel pumps will put out considerably more fuel at 15v than at 13v. Plus you don't have to deal with alternator belts trying to leave the engine bay at 10k rpm!
Old Jan 4, 2003 | 11:22 PM
FULLTHROTTLE's Avatar
Default Re: How to run alternatorless? (tony1)
If you are equipped to charge the battery between runs then by all means ditch the weight and get yourself a good race battery.
Old Jan 4, 2003 | 11:27 PM
earl's Avatar
Tony, that's the exact reason we never tried a pass with the alternator shut off.
The only time we ever used it was when tech wanted to test our rear kill switch
Old Jan 5, 2003 | 05:32 PM
paulzy's Avatar
tahnks guys...
so all I would need is teh battery and the charger huh?
Old Jan 5, 2003 | 05:37 PM
and the remote charging Posts........
Old Jan 5, 2003 | 08:46 PM
paulzy's Avatar
check
Old Jan 6, 2003 | 11:11 AM
KS-R's Avatar
Or how embarassed you'll be when the staging guy knocks at your window with your belt in his hand...
Old Jan 6, 2003 | 02:18 PM
bambooluv's Avatar
a little on topic...how can you modify your charging unit to where the plugs are male and the terminals are female anyone?-thnx pdang
Old Jan 6, 2003 | 05:27 PM
bambooluv's Avatar
Anyone?
Old Jan 6, 2003 | 09:27 PM
tony1's Avatar
I think you can buy the connections from Jerry Bickel.
Old Jan 7, 2003 | 06:51 PM
paulzy's Avatar
Default Re: How to run alternatorless? (hndarcr)
So could I just unplug the altenator before a run Or is it better to remove the belt??
this mod is not reccomended for street vehicles...I'm only doing it because I need the room for a large turbo and custom header.
Old Jan 9, 2003 | 12:06 AM
paulzy's Avatar
look at what tony said a couple posts up
Old Jan 9, 2003 | 05:34 PM
MackSpeed-616's Avatar
lets say you fully charge the battery... how long will the typical charge last? reason i ask is b/c there is just so much dicking around in the staging lanes once you leave the pits. sometimes you have to start the car 4 or more times while waiting (assuming you arent using a tow vehicle) how many starts is a full charge good for and still be able to power all the vehicle systems while running?
Old Jan 10, 2003 | 04:11 PM
ttt
Old Jan 10, 2003 | 06:40 PM
turbohonda's Avatar
Default Re: How to run alternatorless? (BustaNutt-616)
It depends on how many amps your car uses while running.
Old Jan 12, 2003 | 10:19 AM
Default Re: How to run alternatorless? (turbohonda)
what is typical for a car with all standard systems running? minus comforts like radio and a/c. how many amps will a fully charged battery be able to support?
Old Jan 12, 2003 | 11:21 AM
SlowTeg's Avatar
Probably not nearly long enough... Hell, when my alternator belt broke once on my car the voltage dropped 2volts w/in about 1 minute, and I'm sure starting the motor would drain it alot..
-Mike
ALLDAY-24
18
May 3, 2011 08:25 AM
hondaracer13
Jul 19, 2007 07:45 PM
idewson
Aug 31, 2006 11:45 AM
bluegoo
Nov 17, 2002 09:39 PM
Fatty_1775
Oct 23, 2002 02:33 AM
