how often do you do u start your engine.
Old Mar 7, 2010 | 04:43 PM
95dxsir2's Avatar
Default how often do you do u start your engine.
my car sets for a couple months at a time. how often do u start it up and let the enigne get to operating temp.? once a week?
Old Mar 7, 2010 | 04:50 PM
underpressure02's Avatar
Default Re: how often do you do u start your engine.
When I put my cars away for the winter I winterize them. For the race car I drain all the water and fill it with 50/50 anti freeze/water and then start it and get it up to operating temp. I shut it down and put marvel mystery oil in all the cylinders. Put the plugs back in crank it a few times to make sure it coats the cylinders and then spray more in. I drain all the race fuel if it is in the garage i put it up on jack stands and disconnect the battery and remove from the car and bring it inside and put it in the basement on a piece of wood. I do the same for my other cars I just don't drain the fuel. I put stablizer in them.
Old Mar 7, 2010 | 05:27 PM
SPOOLINmatt's Avatar
i just park it and drain the water and fuel.
Old Mar 7, 2010 | 09:21 PM
ef_cowboy's Avatar
not the oil...mine sat for 2 months and i drained the oil, put fuel stabilize...when it came time i flushed the motor with 3 quarts of oil then filled it up to level then i started it up again.i didnt think about the water,maybe thats y my water pump is makeing a noise.
Old Mar 8, 2010 | 06:26 AM
95dxsir2's Avatar
i just start mine up at least once a week and let it warm up from idle.
why are guys draining the water? sub zero temps.? i'll be changing the oil after each time i take it to the track. temps in the winter stay around 50's so the track is always open.
Old Mar 8, 2010 | 06:29 AM
we had 2 weeks or more of highs in the 20's and lows in the low teens, my water would have froze and busted something. I run strait water in race cars.
Old Mar 8, 2010 | 10:21 AM
95dxsir2's Avatar
thanx for the info all.
Atheist
Dec 1, 2015 07:07 PM
BrownProdigy
Jan 1, 2015 05:43 AM
TravisCadello
12
Nov 11, 2008 04:55 PM
EKris
Mar 4, 2007 08:37 AM
SJR
15
Dec 28, 2004 05:08 AM
