How much whp to run low 11's possibly 10's??
Old May 31, 2006 | 07:42 AM
TurboEM1's Avatar
Default How much whp to run low 11's possibly 10's??
Hey guys I am building a turbo b16a and would like some input. I am looking to run low to mid 11's. 10's would be awsome but im not sure if its doable for me. Chassis is a stock weight 1991 CRX Si minus a couple of things (probably about 2150lbs + Driver). Engine will be converted to OBD1 and tuned.
As of now I am getting/have a Full Race Stage 1 kit, Thermal 3" exhaust, RC 750cc injectors, walbro 255 lph hp fuel pump, arp headstuds, gsr cams, skunk 2 intake manifold, 62mm throttle body, adjustable cam gears, fuel rail, FPR, traction bar and some other little things.
Now I am considering building the engine more to withstand 350+whp but before i do i would like a general idea of what I am looking at.
1. How much whp will be needed for my car to break into the 11's (11.7-11.99)?
2. How much whp will be needed for low 11's (11.0-11.3)?
3. How much whp will be needed for anything 10.xx)?
NO LSD (possibly down the road if its a huge help), on slicks
Thanks.
Old May 31, 2006 | 09:10 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: How much whp to run low 11's possibly 10's?? (TurboEM1)
with me still learning on how to drive, in SFWD trim, actually 240 lbs over the min weight,(min is 2400 w/driver, i am 2650) 520whp got me to 10.96. we added 4* timming and got to a 10.72. i am an 84mm b16 t3t67 ho.
Old May 31, 2006 | 09:22 AM
beaver's Avatar
Default Re: How much whp to run low 11's possibly 10's?? (boostedcivicsir)
I ran 11.30@126 with 387whp. B16 in a 94 coupe that weighs 2660 with me in it.
Old May 31, 2006 | 09:33 AM
TurboJesse
Guest
Posts: n/a
Default Re: How much whp to run low 11's possibly 10's?? (beaver)
250-300whp for 11.'s
350-375 for low 11's
400 for high 10's
Old May 31, 2006 | 09:43 AM
TurboEM1's Avatar
Default Re: How much whp to run low 11's possibly 10's?? (TurboJesse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboJesse &raquo;</TD></TR><TR><TD CLASS="quote">250-300whp for 11.'s
400 for high 10's
This seems to be the average for most cars which seems pretty good. So with my current setup (should be about 285whp) i should see 11.xx.
Now for a b16a to handle 350-375whp what needs to be done?
Crank, pistons, rods, sleeves, valves, valve springs, retainers???
Old May 31, 2006 | 10:22 AM
ringgold's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEM1 &raquo;</TD></TR><TR><TD CLASS="quote">
Crank, pistons, rods, sleeves, valves, valve springs, retainers??? </TD></TR></TABLE>
For a B16 to handle that 350-375whp all you need is a good tune. Now if you are looking for a little more life out of the engine you could upgrade the rods/pistons and get a good tune. There were those guys on here not to long ago that made a ton of power out of a bone stock B16 and ran 10's on it with a hurt engine. It finally threw a rod during the burnout but still from what I remember reading it was beat to death at that point and they were expecting it to blow at any minute
Old May 31, 2006 | 11:20 AM
nonvtecallmotor's Avatar
400 for high 10's
</TD></TR></TABLE> sounds about right. I ran 11.0 @ 126 on 375whp in a 2400# car w/ driver
Old May 31, 2006 | 11:52 AM
TurboEM1's Avatar
Default Re: How much whp to run low 11's possibly 10's?? (ringgold)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ringgold &raquo;</TD></TR><TR><TD CLASS="quote">
For a B16 to handle that 350-375whp all you need is a good tune. Now if you are looking for a little more life out of the engine you could upgrade the rods/pistons and get a good tune. There were those guys on here not to long ago that made a ton of power out of a bone stock B16 and ran 10's on it with a hurt engine. It finally threw a rod during the burnout but still from what I remember reading it was beat to death at that point and they were expecting it to blow at any minute </TD></TR></TABLE>
I will be going to Jeff Evans who I have heard great things about so I am not worried about that.
Yes you are correct. I have seen people push retarded numbers out of stock b16's but I am interested in keeping it reliable as it will be a daily driver AND driven to the track.
So what would be the next step for reliability after a full tune up and headstuds to handle 350-375whp?
Thanks
Old May 31, 2006 | 01:40 PM
fmfkid250's Avatar
https://honda-tech.com/zerothread?id=1460393 he is the middle of pa
Old Jun 1, 2006 | 07:18 AM
TurboEM1's Avatar
Default Re: (fmfkid250)
i looked him up hes a little to far (4 hours)
Old Jun 1, 2006 | 12:41 PM
vtecmissle's Avatar
Default Re: (TurboEM1)
Hes worth it and can send you a relatively safe basemap to run on if your chipped already to get you there.
Old Jun 2, 2006 | 08:16 AM
redboost10's Avatar
Default Re: (vtecmissle)
400 for high 10's
totally agree with this
360whp running constant 11.20's 2250 lb 97 cx
Old Jun 2, 2006 | 10:46 AM
atec's Avatar
how about 700whp on a 1800lbs car?
Modified by atec at 12:09 PM 6/2/2006
Old Jun 2, 2006 | 02:14 PM
SIred91's Avatar
Rainman
Default Re: (atec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atec &raquo;</TD></TR><TR><TD CLASS="quote">how about 700whp on a 1800lbs car?
Modified by atec at 12:09 PM 6/2/2006</TD></TR></TABLE>
that equals **** for traction...lol
Old Jun 2, 2006 | 02:28 PM
RICE POLICE SIP's Avatar
Default Re: (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">
that equals **** for traction...lol</TD></TR></TABLE>
LOL yup
Old Jun 2, 2006 | 03:50 PM
vaporboy12's Avatar
Default Re: (RICE POLICE SIP)
10.65 with about 500 hp in im guessing 2650 or so
Old Jun 2, 2006 | 09:05 PM
dester223's Avatar
Default Re: (vaporboy12)
Sounds about right.
I had a straight LS
92 LX 4 door civic,
10.89 @ 130 mph
right at 400 whp.
1.7X 60 foot.
Old Jun 3, 2006 | 08:35 AM
ringgold's Avatar
Default Re: (dester223)
This post is making me want to retune my car for more power!! Right now Im making about 315-330whp on 10psi. I want to run 10's on my setup and I believe it could be possible with more power. Not sure what my car weighs but man this post is making me want to go the 1/4 and try to run some low 11's.
Old Jun 3, 2006 | 09:51 AM
cuin9sec
Guest
Posts: n/a
Default Re: (ringgold)
11.80 @ 122 on stock gsr. 395whp...
Old Jun 4, 2006 | 01:02 PM
atec's Avatar
True, The traction is also an issue..
Old Jun 4, 2006 | 02:41 PM
unusual71's Avatar
what sort of horsepower and PSI boost are the stock B16 sleaves good to reliably if everything else is fully built? ive seen into the 500's at like 18-22 psi if i can recall correctly
Old Jun 4, 2006 | 06:59 PM
Rhythm's Avatar
400 for high 10's
What kind of trap speeds are you guys seeing with these times?
Old Jun 4, 2006 | 07:06 PM
TurboJesse
Guest
Posts: n/a
Default Re: How much whp to run low 11's possibly 10's?? (Rhythm)
400whp will trap ~130 in eg hatch
Old Jun 4, 2006 | 09:03 PM
reaction360's Avatar
reading this thread reminds me how much of a shitty driver I am ahha
Old Jun 5, 2006 | 03:15 AM
TurboEM1's Avatar
Default Re: (unusual71)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unusual71 &raquo;</TD></TR><TR><TD CLASS="quote">what sort of horsepower and PSI boost are the stock B16 sleaves good to reliably if everything else is fully built? ive seen into the 500's at like 18-22 psi if i can recall correctly</TD></TR></TABLE>
i would also like to know.
1998integrals
Apr 28, 2017 08:16 AM
TurboEM1
Feb 5, 2007 03:11 AM
dtb
Oct 25, 2006 02:20 PM
BoostedsiR
Apr 6, 2003 05:49 PM
