Sept FS Thread
Old Sep 6, 2016 | 04:51 PM
crazes's Avatar
Moderator
Default Sept FS Thread
Please read the rules for the new thread. At the end of each month this thread will be unstickied, and a new thread created in this one's place. If you haven't sold your parts, you may post them in the new month's thread. DO NOT BUMP THE OLD THREAD
1) This is for RaceCar parts ONLY. No body panels, fenders etc allowed, unless it is a full race front end. ABSOLUTELY NO useless OEM parts!
2) Do NOT repost your thread over and over hoping to get it on a new page. If your parts sell please remove them from your post. If you sell everything off of your list of parts, report your post to moderator by clicking on the just under your user name and we will delete it.
3)You are ONLY allowed ONE post in this thread. If you are found to have more than 1 post, in the FS sticky all of your posts in the sticky will be deleted, and you will be given an infraction. With enough infractions you will be banned
4) NO WTB ADS!
5) NO COMMERCIAL POSTS AT ALL THIS MEANS, IF YOU OWN A SHOP DO NOT POST BRAND NEW PARTS IN HERE
6) Please provide all pertinent information, including price, and try to return pm's.
We will delete any BS we feel does not belong in here
Please try and limit the size and # of pictures you post. using thumbnails would be fantastic.
From this point on, 3-7-2012, any edit mods have to make to these threads, will result in sanctions. if it persists, the stickies will disappear for good. THIS WILL BE ADHERED TO. No more warnings
EVERYTHING HAS TO HAVE PICS NO exceptions
Old Sep 6, 2016 | 05:44 PM
jdm inc's Avatar
Default Re: Sept FS Thread
Cp Pistons 9:1 81.5 sold
Sheepey ic $800 shipped
Borg Warner turbo 950 Obo
Dave fry wing $200 shipped
7l golden eagle intake manifold with Wilson 90mm tb and fuel rail $850 shipped will separate
Koyo rad with 13" spal fan and fan shroud $340 shipped
Super tech valves 1mm os missing two exhaust valves $160 shipped
Super tech valve guides $75 shipped
Repaired intercooler $250
text me at 316 308 four three six nine for fastest response.
Old Sep 8, 2016 | 07:51 AM
SlowReaction's Avatar
Nameeter
Text: 425-999-5555
JRZ double adjustable for eg/dc/ek control arm. Front have very little use, couple laps at the track. Not blown, no leaks and both adjustments are working. Rears are brand new never been mounted. Comes with set of brand new hyperco helper and 700lb spring you can use in front or rear. Karcepts sepherical top hats on both. I'm am close ton 3k in this setup, looking for 2600obo
Old Sep 8, 2016 | 05:28 PM
FRernesto's Avatar
- AEM infinity sub harness brand new for OBD1 vehicles plug and play to any of the Infinity 6,8H boxes. 225.00
- Locash dizzy delete cover for Hondata COP for the B18C, C1, and C5 style distributors 65.00
- Borg Warner S400 72mm type T4 turbin housing 1.10ar twin scroll brand new 100.00
Old Sep 11, 2016 | 02:46 PM
Miss PSI's Avatar
GT4294R $800
AEM ver1 ECU w/ Injector Driver $550
Aeromotive Eliminator Pump $250
Tilton Cerametalic Twin Disc Clutch $550
MSD Dis4 Plus $250
(4) MSD Blaster Coils $100
For more details and pictures check out this post
https://honda-tech.com/forums/sale-1...n-msd-3285063/
Fastest response via text 513.304.2363
Old Sep 11, 2016 | 08:30 PM
crxmanror's Avatar
Kinsler 62mm magnesium body Kseries ITB's currently setup to use Kseries TPS. Can aso be setup to use other TPS versions. -8an fuel rail fittings. Does NOT include injectors. Only Ran on car for dyno testing. Excellent condition. $2100 Shipped. Buyer to pay Paypal fee or send money using gift option. Any questions please send PM or email tsx_k24@comcast.net
Old Sep 18, 2016 | 07:34 PM
lsvtecracer's Avatar
Brand new motec m400 with t1 racedevelopment custom k swap harness Asking $2600 plus shipping
s2000 ap2 2.2 liters head Asking $1800 plus shipping
**has valve cover not pictures**
**id1000 injectors with inline pro fuel rail and aem pressure regulator**
**modified water outlet for an line**
k20z3 head with no intake manifold or coil $600 plus shiping
Most of these parts were brought for project that never was started or finish. Motec is brand new. I will part out as well and sell certinn parts seperate.
Text me at 225-205-5981 if you have any questions.
Old Sep 20, 2016 | 08:55 AM
EF'n Sedan's Avatar
Aim Strada MXL Dash with RS232 AEM Serial Connection setup with a deutsch connector (may also have the Kpro interface unit in storage somewhere if needed instead). Perfect working condition / can include the dash surround for an EK with 2 standard gauge holes.
$700 Shipped.
Old Sep 21, 2016 | 10:18 PM
11SECEG's Avatar
Brand new Gato manifold (gsr head) 8 injector set up ...1000
2 sets of id2000 clean and flow tested by t1 .........650 each
mw pro10s with t1 harness..........................550
gforce shifter b series..................................900
fully built block
Gsr block
Ge 84mm
10.5 arias flat top
.0055 ptw
Upgraded wrist-pin
Manley turbo tuff rods
Oem bearings
Balance bottom end
Zero miles .............................................2500
Head :
Gsr head
Ported polish
Skunk2 lma
Supertech retainers
Supertech dual springs
Supertech valves inconel exh.............1000
skunk2 pro1 cams..............................500
B series gforce complete tranny
fully inspected and replaced all bad parts by dp perf with reciept
mfactory lsd
Speedfactory scha ( stock springs)
new reinforced casing by dp performance.............6k
Weldon 2345 pump.........750
10 lines
-10 return. And all fiitings n filters...........200
Weldon 2040 fpr ......200
Exedy twin plate ..................800 ( 4 passes )
Turbo kit :
7175bb
1000hp ic
44mm wg
Lovefab topmount
Up pipe
3" charge pipe........2500
hondata v2 ....................550
Ati race damper for b series slightly used......300
Text or call me at https://honda-tech.com/forums/"tel:510 415-0544"""]510 415-0544 for faster response.......
Old Sep 25, 2016 | 05:42 PM
bigislandc2's Avatar
For sale full blown walbro $200 -8&-6 return with or with pumps w/ pump $300 w/o $200
neptune. RD1 New only installed in cluster and check operation $250
Old Sep 29, 2016 | 06:04 AM
turbociv910's Avatar
hondata s300 v2 in vtec equivalent ECU
500 shipped
Old Sep 29, 2016 | 02:55 PM
slowesteg's Avatar
Skunk2 drag coilovers 10k fronts 18k rears. For eg/Dc but will fit ek with spacers and also will fit ef with eg/DC/ek front forks. Basically brand new. asking $500
Old Sep 30, 2016 | 04:38 AM
rmercado's Avatar
AEM FLUID PRESSURE SENSORS 30-2130-100 NEW IN BOXES ASKING $80 EACH FREE SHIPPING...
Old Sep 30, 2016 | 07:18 AM
AllMtrRex's Avatar
$2500 OBO
Email: allmotarex@yahoo.com
Phone (336)932-2023
This harness can be used in any year bare shell with no existing wiring. This harness was special ordered from Wireworx. It will eliminate the ignition switch/key and will be replaced by a push button start. This harness was designed for drag racing application and does not include wiper wiring, turn signal wiring, horn wiring, cruise control, any power options, or climate control options.The harness is complete, BRAND NEW IN BOX!! It has never been test fitted or placed in any car. Just took out of the box to verify everything was there. The harness weighs less than 15 pounds. I can take specific pictures for interested buyers if needed.ID injector clips (4)
Distributor OBD2A
Deutsch Detachable Injectors harness
Deutsch Detachable VSS harness
Deutsch Detachable Alternator harness
Optional User spare wires (6)
Ecu plugs (Obd1 Honda)
Fuel pump wiring routed for front of car (Can be extended)
Headlight wiring
Tailight wiring
Wiring fan SPAL VA10-AP9/C-25A 12V
Clutch switch wiring
(Switch Panel Singe DIN Fits in Factory Radio Location)
Push Button start
Starter Relay
Fan Relay
Water Pump Relay
Lights Relay
ECU Main Relay
Relay/Fuse Panel (Located at passenger side floor)
Starter Fuse-20 Amp
Empty
Fan Fuse-30 Amp
Empty
Water Pump Fuse-30 Amp
Ignition Fuse- 10 Amp
Lights Fuse- 25 Amp
Cluster Fuse- 10 Amp
Traction Control Fuse- 10 Amp
ECU Fuse- 20 Amp
Firewall Mil-spec plug to disconnect engine harness from chassis harness
Old Oct 3, 2016 | 01:58 PM
ninesecrx's Avatar
Hi guys,
I am selling this complete running 1988 Honda crx drag race car. It has lots of mods, fully built engine and a bunch of high end parts. Car will need to be tuned before raced. Engine was built to run on nitrous or turbo. Should still run hard if ran all motor if you like. Car ran 10.80s ET in the 1/4 mile
12 point cage
tin work
Autometer tach and gauges
Painless switch panel
cnc stage brake
simpson cam lock 5 point harness and window net
full lexan windows with fast release dzuz fasteners
straight rear single axle with torsion bar
Mugen body kit shaved in with great condition paint
Jazz race seat
MB fiberglass 1 piece front end
comes with a set of front racing slicks
1 gallon Jazz fuel cell
breather box
msd 6al ignition with blaster 2 coil
scatter shield for transmission
race clutch with aluminum flywheel
steel braided lines all over
B series motor mounts for swap
energy suspension bushings through out
bosch fuel pump
tokico 5 way struts
DC header
Skunk2 intake manifold
aem intake
magnacor spark plug wires
Neuspeed front strut tower bar
BDL throttle body
SX fuel filter and fuel pressure regulator
vortech fuel rail and fuel injectors
obd1 wiring
RC cam gears
Head has been port and polished, Crower cams, Crower dual springs and retainers, ARP head studs
Bottom end has Crower rods, JE pistons, Benson sleeved block
Clayton
Oct 25, 2017 12:43 AM
crazes
Feb 1, 2017 11:37 AM
crazes
Nov 18, 2016 05:52 AM
crazes
Oct 30, 2016 03:57 PM
crazes
Sep 5, 2016 02:16 PM
