Feb FS Thread
Old Feb 20, 2013 | 12:14 PM
  #76
gt35rdanny's Avatar
Default Re: Feb FS Thread
Sold
Old Feb 20, 2013 | 12:38 PM
  #77
EJ1_Ex's Avatar
SOLD
Old Feb 20, 2013 | 02:56 PM
  #78
mint's Avatar
For B series bottom mount divided t4 with 2 38mm waste gates.
I used a BW SX400 67mm with no clearance issues.
$700+shipping OBO
Before the waste gates were put on.
Call or text
612-7O3-2OO1
Old Feb 20, 2013 | 03:30 PM
  #79
nonvtecallmotor's Avatar
Garret Ball Bearing Billet 72mm Custom made proven 170+mph in SFWD trim. Used 5 passes. Its in perfect shape. Cost over $3500. FIRM $2800
Weldon 2015 used only 5 passes since new. 1000whp on gas. $400
MSD 7531 Very little use Works perfect SOLD!
Cam gears New only used for mock up never ran $100
BDL 70mm Throttle body NEW mock up only. Includes map and tps $175
AMS-1000 works perfect comes as pictured. Ready to wire. $675
Old Feb 20, 2013 | 04:27 PM
  #80
jdm_ef9's Avatar
F/S: Supertech K-Series Pistons
Brand new!
9.0:1cr (K20) Comes with rings and pins
$350 shipped.
Old Feb 21, 2013 | 07:18 AM
  #81
jdmboostedek99's Avatar
Gt4202r
128 A/R
60 A/R
CHRA: 451888-5011
price:1600$
I have a Gt4202r in good condition zero shaft play, its been rebuild and has 0 miles since.
I will like to trade for something smaller T4 so lmk wat u got.
Old Feb 23, 2013 | 04:05 AM
  #82
BsmoothR's Avatar
Pending
Old Feb 24, 2013 | 11:01 PM
  #83
team1320_k26eg's Avatar
K-series rywire milspec harness w/ Aem twin fire ignition and Aem CDI pencil coils. Harness is wired for optional 8 injectors. $1500 obo for the whole set up.
Old Feb 25, 2013 | 07:57 PM
  #84
209lsr_ly's Avatar
Quaife gsr LSD
comes with two bearings
used only for 4 dyno pulls and 3 1/4 runs
600 shipped obo plus paypal fee
Old Feb 26, 2013 | 01:44 PM
  #85
T76U13ALT's Avatar
Please delete..
  #86
T76U13ALT's Avatar
Up for sale is a pair of 13x8 Bogart wheels, they in pretty good shape no dents or rash on them. I'm asking $420 shipped in the USA for these..
13x8
5x114.3
5" back spacing
Old Feb 26, 2013 | 02:48 PM
  #87
Birdley42008's Avatar
Sad day...
She has to go I have bigger and better things to put my time towards.
Pictures don't say much.
Located in NH. Will ship USPS Flat rate or Cheapest carrier. Paypal for payment.
Here's what I got:
97 Honda civic hb vsm. body good condition interior gutted w roll cage, lightweight battery, lower function 7 lca and yonaka coilovers, fully gutted with staging brake, innovative motor mounts 355lph fuel pump shift light $2500 Obo... OBO!
Yonaka radiator w mishimoto silicone lines $280
Eagle rods std length $300
Wiseco 75.5mm Dseries pistons w pins 9.5:1 comp $500
75.5mm Cnc werx CSS d16z6 short block brand new $280
2.5" charge piping $260
Dseries top mount $650
Up pipe w dump tube welded in $270
Godspeed t66 $150
Mint Dseries dizzy w wires and spare coil $120
00 ex tranny $180
Competition clutch stage 5 clutch $200
flywheel comp clutch 12lb $120
Oil sandwich plate $20
D15b jdm head w cam and vtec solenoid $160
Spare z6 few plugs cut believe dizzy and vss$30
Misc part box, cranks heads w damage etc. just ask!
Old Feb 26, 2013 | 03:06 PM
  #88
DxTrix's Avatar
Located in Cali all prices do not include paypal and shipping unless agreed
-Arias h22 brand new 89mm piston set 16.5:1 h23 crank or 15.5:1 h22 crank $550
-Cp h22 brand new 87mm turbo pistons set $425
-Fresh polished h23 crank $250
-used h22 eagle rods in good condition no spun bearings $225
-109 h22 stroker setup 50mm mains 109mm stroke, 90mm ross 15:1 pistons, cunningham rods $1200
-h22 Hytech turbo manifold t4 divided with egt bungs $900
-h22 sleeved block $800 needs to be honed/cleaned
-h23a1 block with crank, vtec oil and water pumpwith mains no pistons or rods $250
-pwr barrel 6x10 liquid to air intercooler 3in inlet and outlet, waterpump and ice tank $600
Old Feb 27, 2013 | 06:31 AM
  #89
FIST321's Avatar
I have a used s372 1.25 its in perfect condition other then the compressor cover was rubbing my hood and I didn't know it. It has about 15 dyno pulls and around 500 miles on it 800 shipped plus PayPal fees. 3013319910
Old Feb 27, 2013 | 09:32 AM
  #90
blo0d's Avatar
JDM OBD2A DC2 Type R P73-003 ECU: 200 Shipped within USA
JDM DC5 Type R PRC-013 ECU: 450 Shipped
Apexi AVCR w/everything: 350 Shipped
GARRETT 3071R BallBearing Turbo... LikeNEW 10Miles: 900 Shipped
I'm attempting to take better pix:
Specs:
56Trim (53.1 mm Ind. 77.0 mm Exd.)
0.60 A/R Compressor
0.63 A/R T3 V-Band Exhaust Housing
Items in Charlotte, NC PM if pickup is desired
Old Feb 27, 2013 | 02:38 PM
  #91
xxjonxx4's Avatar
Looking to sell my Scat 92mm crank never installed or used. Scat cranks are superior in quality as they are machined and inspected in U.S. and they source there forged steel from the U.K. not china . Sad to let it go , but things came upand priorities change .I also have the original box if you have any questions please ask. Asking 550 OBO
PLEASE NOTE THAT THE BROWN HAZY STUFF ON THE JOURNALS AND CRANK IS FROM FACTORY AND IT COMES OFF , I ASSUME ITS USED TO PREVENT ANY SURFACE RUST FROM FORMING DURING STORAGE AND HANDLING.
Text 760-936-2053
Old Feb 28, 2013 | 06:26 AM
  #92
allvtec's Avatar
weighted front traction bar filled with lead pellets. the lower bar is around 75lbs and the top 35lbs.top $250 + shipping
Text or call Raul @ 480-205-1906
Old Feb 28, 2013 | 07:05 AM
  #93
XREDLINE2's Avatar
F/S email for fastest response xredline2@aol.com
4 Inch custom hood exit downpipe stainless steel. was made using full-race k series sidewinder. im sure it will fit others. 4 inch v-band small 8 in section has not been welded yet in case you want to change the angle asking $250 + shipping that just about covers the material need it gone..
0 miles never used
aeromotive eliminator pump used for the end of season only a few runs on it just flow tested it all perfect (also have eliminator filter if interested) asking $275 +shipping
Old Feb 28, 2013 | 08:04 AM
  #94
Mr.Sw20's Avatar
2 sets of Precision 880cc low impedence, very low miles
225$ for each set.
Precision 1600cc low Impedence with FJO Injector driver
Recently Refreshed by Rc Engineering.
350$
MSD Digital 6 With Blaster HVC 2 Coil
350$
MSD HVC 2 Coil
100$
Tial Polished 38mm Wastegate Slightly Scratched. 14lb Spring
160$
Old Feb 28, 2013 | 08:33 AM
  #95
GHOSTFACE EG's Avatar
Selling CCC racing Aluminum street wing for EG hatch back
Primered ready to paint. Still needs to be wet sanded down.
Comes ready to bolt on to car.
Located in SOCAL- Asking 180 plus shipping.. Great deal
Please PM me offers..
Old Mar 2, 2013 | 09:14 PM
  #96
joedirte's Avatar
cleaning up a bit...
all parts were utilized during the 2012 race season and were just recently removed from the cars.
Text with question for quickest response: 253-376-9083
Blox 70mm Throttle body $120.00
AEM digital wide and eugo gauge (black on black) $130.00
AEM digital boost gauge (black on black) $100.00
AEM digital oil pressure (black on black) $100.00
AEM 3 gauge package $300.00, comes w/O2 and oil pressure sending unit
Golden Eagle fuel rail (black) $75.00
ASP hood exit K series header (ceramic coated grey) $800.00
AEM v2 K-series $775.00
K-series BME Aluminum rods (brand new) $595.00
B-series BME Aluminum rods, LS length 827 wrist pin (10 hits) $500.00
M&H 26"x10.5"x15
MSD Ignition Slew Rate Box, MSD Power Grid Ignitin Box, MSD Can Bus Adpater, Racepak Magnetic Pickup and Custom Mid Shaft Adapter - $900
MSD small shift light - $50
Custom SF EK B Series engine harness - $250
SI rear spoiler $120
B16 port flow cylinder head, heads been completely gone through, valve job, valve seats have been cut, combustion chambers have been opened to 84mm. Like new $1,000 (can sell with brand new oem sized valves that have been lapped to the cylinder head at the machine shop.)
image illustrates grey ceramic coating
header prior to be ceramic coated
all shipping will need to be covered be the buyer, all items should be able to ship with in 24hrs of payment.
preferred method of payment: PayPal
Old Mar 3, 2013 | 07:03 PM
  #97
JDM346's Avatar
***Reduced prices***
- brand new in box Full-Race Twin Scroll Top Mount ProAM Turbo Manifold
1600 deg. black coating
comes with hardware and both exhaust gasket and turbo gasket
$1100
[IMG][/IMG]
-BNIB black Tial 50mm q edition BOV
$240 ***SOLD***
- 2 mint chrome Tial 044 wastegates
$200 each ****SOLD*****
-BNIB B series Aeromotive fuel rail
$160
[IMG][/IMG]
-mint BMC 6L intake manifold with matched 90mm Accufab throttle body attached
throttle body comes with TPS sensor
$1000
[IMG][/IMG]
-BNIB Borg Warner S400SX Billet 67mm
1.25 turbine housing
1600 black deg coating
$1500
[IMG][/IMG]
-BNIB Mishimoto half size 92-00 civic radiator
***SOLD***
[IMG][/IMG]
-WILLING TO TRADE FOR COMPLETE K SERIES SWAP KIT/PARTS FOR EG CIVIC or black rpf1's
for more pics and info my cell is 336 575 0563
more pics of parts coming soon
***im currently located in TN***
Old Mar 4, 2013 | 02:44 AM
  #98
Paul_VR6's Avatar
Weld Draglite set 13x8/15x4 with M&H 24.5x8.5 and 22x3.5 - 1200obo
The lightest 4x100 drag wheels ever made. Wheels are in good condition and come with extra hardware. One front slick has a small delaminated area but hasn't gotten worse in 20+ passes. Fronts come with tubes installed.
Delaminated area
Lots of meat on the skinnies
1200obo
PM me or email kandpperformance@gmail.com
Old Mar 4, 2013 | 06:11 AM
  #99
vtecace23's Avatar
Exospeed 3pc Front for EK, Mounted but has not been painted yet. $700 obo
Old Mar 4, 2013 | 07:03 AM
  #100
Garage786's Avatar
G-FORCE DOG GEARSET FOR B-SERIES
Heres your chance to own a good dog gear set, for a steal of a price. Has had under 15passes at 800whp. Ive had the set inspected by a few people and everyone says the same thing. There like new and unused. There are no signs of stress at all, there ready to be installed.
Price drop to $2800 (SuperCheap), located in Tampa.
Gear ratios:
1st- 2.92
2nd- 1.88
3rd- 1.35
4th- 1.00
You get two final drives, ones for 24.5 tyre and the other 26". They are 4.0 and 4.7.
crazes
Mar 2, 2016 09:50 PM
crazes
Mar 1, 2015 01:19 PM
crazes
Aug 31, 2014 09:17 AM
crazes
Mar 2, 2014 10:15 AM
Clayton
Sep 4, 2013 05:27 PM
