engine mangament ???
Old Oct 11, 2009 | 07:11 PM
  #101
96 GSR-T's Avatar
Default Re: engine mangament ???
I just stopped using Neptune 10 months ago, have not restarted the car since.... no bad taste I got to know James very well, good guy and there is nothing wrong with the program, just wasnt for me anymore......
Old Oct 11, 2009 | 07:12 PM
  #102
swapit's Avatar
Originally Posted by 96 GSR-T
I got my new style small frame AEM Box with UEGO and an EPM for $1250 BNIB.... FYI
I was a Neptune RTP owner for several years for starters, and before that I had an S300 and before that a hack. I was happy with Neptune but found myself wanting alot more from my ECU real quick.
Neptune is fine for street cars but it has huge downfalls (S300 as well) if you want to try and go fast and do it consistently, the lack of complete timing control, no COP capability, no in-depth tables and not to mention all the OEM ECU's are at a minimum of what now 14yrs old.
I had a hot start issue that could not be tuned out running Neptune, every time I shut my car off hot and restart it would run extremely lean for 30sec to a minute(checked everything), if I would of had AEM there is a table that can fix that... but with the OEM **** you just have to deal with it. there are alot of stupid querks with the OEM **** that made me want to spend the money to do it right...
i ran neptune from the time jeff first started tuning i think i was the 2nd or 3rd car he did but as time went on he was sayin the same thing and had me switch...but for my everyday car it worked great.
Old Oct 11, 2009 | 07:13 PM
  #103
DDTECH's Avatar
Well, just for your own sake, the program has come a long way in the last 10 months....
Old Oct 11, 2009 | 07:14 PM
  #104
DDTECH's Avatar
  #105
DDTECH's Avatar
These are the types of replies the thread needs, not cheap e-trash talk replies.
Old Oct 11, 2009 | 07:15 PM
  #106
96 GSR-T's Avatar
Lol.... If it cant run COP, doesnt have enough tables to swim in, and not be run through a processor on an ECU board thats 14yrs old at the minimum.... it has not come far enough
I have been following the progress.... always have.
Old Oct 11, 2009 | 07:17 PM
  #107
DDTECH's Avatar
I can see your point, i concur..
Old Oct 11, 2009 | 07:20 PM
  #108
nonvtecallmotor's Avatar
You dont deserve a real reply with that junk your pushing in your 104mph whip.
  #109
swapit's Avatar
wait till you get your hands on a series2 box from aem from what jeff was tellin me they are 100times better to use then the series1
  #110
DRIVENRacing's Avatar
lol... i just read this whole thread... comparing crome,ectune or neptune to any ems is like comparing oranges to apples... 2800$ for aem?? i just bought 2 boxes at 500$ each.. one was brand new one was bareley used... s300 is around 600 bux plus you need an ecu.. you cant run in excess of 10+ injectors on any honda ecu, you dont have boost comp tables, true anti lag, trac. control, etc.. i will agree, for 250$ crome or ectune is def worth it for something mild with stock ignition setups... ive tuned many cars over 500+ whp on stock honda ecu based programs. (ie.crome,hondata, ectune) but when people start going over excess of 45+ psi on bigger turbos, there is nothing like using the benefits of a full stand alone... just my 2 cents :thumbsup:
Old Oct 11, 2009 | 07:21 PM
  #111
uglyasscivic's Avatar
Oh, as for NepTune. I was one of the first to have the software and it has changed A LOT over the years. There has been some issues over the years but as it sits right now it works great. 100% of the cars I have done are just running on a chip with no RTP but they are mostly 300hp daily drivers or 200hp all motor cars that dont need any adjustments. I will be doing some RTP Demon tuning soon. Overall NepTune get a good vote.
Old Oct 11, 2009 | 07:22 PM
  #112
PyroProblem's Avatar
For some, factory based ecus do everything they need it too. For others that need more, there are the standalones...
If the factory based ecus could do it all, there wouldnt be a need for more sophisticated ecus, BUT they CANT do it all. Thats where AEM/MOTEC/ETC come into play...
There have been many cases where changing to a standalone that can read hall effect sensors (T1 trigger/aem epm) have gained HP due to the fact the cam/crank signals are much cleaner than the factory sensors in the distributor resulting in more precise timing control...
This is another reason I plan on using AEM over factory ecu based tuning options...
  #113
DDTECH's Avatar
what..? I hope you didn't fail to read that was a stock block itr with minimal work ..
i have a fully built motor now that will surely be 110+ traps and on top of that, i have the dope on the side..
I really hope one day you can grow up bro and stop with the immature responses.
Old Oct 11, 2009 | 07:23 PM
  #114
96 GSR-T's Avatar
I am thinking about selling the box I got now to buy one I have always been hesitant towards newly released AEM Electronics though.
Old Oct 11, 2009 | 07:24 PM
  #115
DDTECH's Avatar
You'll be on k series?
Because bseries doesn't have CAM Angle sensors.
I do agree with the above stated tho..
Old Oct 11, 2009 | 07:25 PM
  #116
DDTECH's Avatar
I Beta all that stuff before it goes out from craig that has to do with honda/acura tuning.. The demon has been in the works for over 2 years.. and is finally getting released.. Its well worth the wait tho..
1 cable for everything.. dont need all those wires anymore. I have some people who need to switch over but non the less yes.
Old Oct 11, 2009 | 07:27 PM
  #117
DDTECH's Avatar
More or less my arguement was for daily driven - sub 30psi setups..
I'd believe if you were boosting 45psi .. then yes, you'd want to get as close to your points of tuning as you would need too, with that amount of boost the smallest error could be .. failure.
Old Oct 11, 2009 | 07:29 PM
  #118
therealpoorboy's Avatar
you sure?
Old Oct 11, 2009 | 07:33 PM
  #119
DDTECH's Avatar
Originally Posted by therealpoorboy
you sure?
B series has cam angle sensor? it does not.
Are you talking about the "Crank angle sensor " thats not on OBDI cars?
Are you sure? heheheh
Old Oct 11, 2009 | 07:39 PM
  #120
I guess ive been wrong all these years, there is no cam sensor inside the ditributor...
Thanks for informing me all motor!!!
  #121
swapit's Avatar
they are having some issues we had a car at jeffs to test the obd2 boxes and it had some issues and i now felix was having some issues with his obd1 box but what jeff has told me they are being worked out asap..
Old Oct 11, 2009 | 07:40 PM
  #122
DDTECH's Avatar
oh no you silly goof.
Old Oct 11, 2009 | 07:42 PM
  #123
DDTECH's Avatar
whats a price on a haltech system.. now and days.. isn't there a new system that just came out?
Old Oct 11, 2009 | 07:50 PM
  #124
DDTECH's Avatar
Welp good discussion i'ma go to bed guys see ya.
Old Oct 12, 2009 | 01:46 PM
  #125
Puma909's Avatar
If you'll search my other alias.. you realize
i did 104 on a stock block itr, with a built head and other minor bolt ons. Oh, and street tires as well.. that was all motor, i hardly consider that "weak" in a full interior integra.
Do you have any vids to back up your "facts"?
