Black Smoke????
Old Jun 29, 2011 | 05:34 PM
sgnlab's Avatar
Default Black Smoke????
Have you guys ever seen black smoke come out of the exhaust on a turbo car??
Old Jun 29, 2011 | 05:42 PM
MR.johnson's Avatar
Default Re: Black Smoke????
most of the time that means its running rich.
Old Jun 29, 2011 | 05:52 PM
sgnlab's Avatar
I think this guys wideband is ****! I will change it in the am! Just never really seen it this dark! Then again its coming through the hood!
Old Jun 29, 2011 | 05:54 PM
boosted92snatch's Avatar
^x2 yeah not unusual to see black smoke from a turbo car thats tuned a lil rich, its the white or blue smoke u need to worry about.
Old Jun 29, 2011 | 05:55 PM
sgnlab's Avatar
Precisionfab1.com, Stickerguytuning.com, And RJT Machine...
Old Jun 29, 2011 | 05:57 PM
hello1320's Avatar
what do the plugs look like?
Old Jun 29, 2011 | 05:58 PM
sgnlab's Avatar
They are rich! I just never seen it so dark like that!
Old Jun 29, 2011 | 06:00 PM
hello1320's Avatar
seeing it right infront of your face is why it seems sooo dark...
Old Jun 29, 2011 | 06:04 PM
sgnlab's Avatar
this is what I am thinking! I am going to sleep now its to late!
Old Jun 29, 2011 | 06:22 PM
redboost10's Avatar
way off topic, but thought you might be interested in these for your catchcan lines...maybe you are already aware of these.
http://www.jegs.com/p/JEGS-Performan...47409/10002/-1
Old Jun 29, 2011 | 09:25 PM
Boosted_B_Series's Avatar
Also your wideband could be reading lean depending on your 02 sensor placement with such a short up pipe.
You shouldn't use or trust a customers wideband for tuning. Doesn't matter what they say about it, use your own.
Get an otoscope, one of these can save you a whole lot of hassle. Tune it safe with the wideband, verify the plugs with the otoscope, then start cranking on it. The plugs tell a lot, I normally go threw 2-4 boxes of plugs per tune.
Old Jun 30, 2011 | 01:48 PM
sgnlab's Avatar
Made some great power @ 32psi hazing 4th gear on the dyno!
Old Jun 30, 2011 | 02:13 PM
turbo-2nr's Avatar
specs on setup?
joehonda1129
Nov 29, 2007 02:35 PM
john d ftw
Oct 9, 2006 11:36 AM
suckanut
10
May 14, 2005 04:10 PM
Sinner
Oct 27, 2003 12:48 PM
Lsubball99
Aug 10, 2002 01:07 PM
