Best Value Head Work
Old May 21, 2003 | 09:38 PM
  #376
EFIGUY's Avatar
Default Re: B18 - (Woofer)
I have seen the set-up that woofer uses and it's very cool.................when you are there you kinda feel like you are in the batcave or something!
I've seen his work and he definately does good stuff!
Old May 22, 2003 | 04:01 AM
  #377
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: B18 - (EFIGUY)
Sorry to kinda go back on the flow bench thing, but I read a really good article by David Reher of Reher-Morrision. Since I recently had the pleasure of going to Reher-Morrision thanks to Larry from Endyn I started to read his tech articles. I think what he says below is pretty cool:
I am not against flow benches; in fact, we use computerized flow benches daily at Reher-Morrison Racing Engines. What I am against is over reliance on flow numbers as the primary measurement of a cylinder head's performance. A flow bench is a valuable tool that can help a racer fine tune a combination - but it is not the ultimate authority.
you can read the entire article here: http://www.rehermorrison.com/techTalk/16.htm
Curtis, nice talking to you the other day. It was way cool! Ignore the idiots that I will soon get rid of.
art
Old May 22, 2003 | 05:05 AM
  #378
ENDYN's Avatar
The Old One
Default Re: B18 - (Arturbo)
David's remarks underline my statements regarding the "quality" measurements (in the chart above) being more important than CFM any way you look at it. The fact that our heads bang big numbers is "great", but I don't use those numbers in head development at all.
Old May 22, 2003 | 08:19 AM
  #379
EFIGUY's Avatar
I have had the pleasure of taloking to Woofer about his heads and techniques on sevearl occasions, and I was thrilled to learn about the things he had to say............he was very open and shared lots of invaluable information with me...........some of which was truthfully over my head
I was definately inspired and it only makes me love what I do that much more when knowledgeable people can come together and help each other out......
Old May 22, 2003 | 08:21 AM
  #380
CHEETAH's Avatar
Default Re: B18 - (HEAD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HEAD &raquo;</TD></TR><TR><TD CLASS="quote">wow I didn't think they would use a cam that big-I stand corrected, considering the toda Dspec cam I would flow it to .550 to
what kind of duration are we looking at with these cams</TD></TR></TABLE>
the spec D cams are too big especially for the flow numbers that Larry's heads produce ... case-and-point my head which had almost the same flow as that posted, I originally told Larry to port for killer cam combination (305/12.5 I; 295/11.5 E) but changed cams about 5 times later ... all ranging from stock ITR to skunk2 to JUN 3 and to Toda Ds to see which worked best ... unfortunately when we use any big cams, whether the killer, spec D or even skunk 3 the motor fell flat on its face, Larry recommending a much smaller cam or at least a combination of smaller cams and we got her alot better.
One thing is for certain, many of the Endyn heads produce tremendous torque numbers ... the trick is to find the right combination of cams or at least grind your own per Larry's specs.
Sometimes its also difficult to explain to people that big cams don;t always produce the results one would expect, especially when going with stock displacement motors.
Greg
Old May 22, 2003 | 11:47 AM
  #381
ImportReview
Guest
Posts: n/a
Default Re: B18 -
One thing that has confused me about this entire thread, and maybe somebody has said it, but I have not seen it.
All this talk about flow numbers....
Did anyone check NASCAR to verify that the cars that run the fastest on the track, indeed don't have the heads that flowed the most?
Old May 22, 2003 | 01:17 PM
  #382
Curtis Boggs's Avatar
Woofer,
While on this subjet I'd like to get an older (older then me)opinion of some flow numbers.
The head is this Ford 1600 kent that I spend so much time with. ( SCCA Formula Ford )
2 bl. Weber carb, .. stock cam, . . header. Head has round ports and a flat deck with no chamber.
28" h2o
Lift --- Int. --- Ex. -- %
.100 -- 52.6 --- 46 -- 87.5
.150 -- 76.6 --- 75 -- 97.9
.200 -- 100.2 -- 96.3 -- 96.2
.250 -- 124.7 -- 112 -- 89.8
.300 -- 143.4 --118.9 -- 82.9
.350 -- 160.8 -- 123.7 -- 77
.400 -- 171.5 -- 125.7 -- 73
What do you think about the exhaust flow ratio?, .. .. I've tried to keep numbers around 80% and have tried boosting the low lift numbers over 80% and found some HP gain?
Do you think this is going too far?????? And of course if you have any ideas for dealing with a round port, .. please share. The exhaust port tries to shove the flow through the roof at high lift, .. and shows very low velocity along the floor. The intake port velocity map is VERY even.
BTW, .. I used to work at Sonny's doing the big inch IHRA Pro Stock stuff, .. .. 80's, .. did we ever run into each other at the track???
Curtis
Modified by Curtis Boggs at 5:28 PM 5/22/2003
Modified by Curtis Boggs at 5:46 PM 5/22/2003
Old May 22, 2003 | 01:22 PM
  #383
Default Re: B18 - (ImportReview)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImportReview &raquo;</TD></TR><TR><TD CLASS="quote">One thing that has confused me about this entire thread, and maybe somebody has said it, but I have not seen it.
Jeff,
We've discussed many things in this thread. Peak flow numbers are just one of them and are not the only thing we deal with. Port velocity, wet flow, .. the flow curve and the relationship between intake and exhaust flow all are just as important as flow numbers.
I'm sure the NASCAR teams understand this and ballence those things as well. I know that they have "short track engines, .. long track engines and plate engines" each require a different approach to the cylinder head and entire air flow of the engine.
Curtis
Old May 22, 2003 | 01:36 PM
  #384
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFIGUY &raquo;</TD></TR><TR><TD CLASS="quote">I have had the pleasure of taloking to Woofer about his heads and techniques on sevearl occasions, and I was thrilled to learn about the things he had to say............he was very open and shared lots of invaluable information with me...........some of which was truthfully over my head
I was definately inspired and it only makes me love what I do that much more when knowledgeable people can come together and help each other out......</TD></TR></TABLE>
Awwww, .. .. I think this calls for a group hug, ......... .. .. .. .. ..
While on this subject, .. I too have been inspired. Ben and I have had a few phone conversations along with our threads here that have made me think in a different way, .. I've since found some power on a few race projects!
Ahhh the power of sharing and team work!
Now I'm going back to work, ..
Curtis
Old May 22, 2003 | 02:10 PM
  #385
CHEETAH's Avatar
Jeff, besides what Curtis said, you can;t simply look at flow numbers, I remember someone saying (I beleive its John Grudynski that told me this once), apparently there were regulations passed years ago in NASCAR about allowing so much porting in the heads as well as that much displacement in motors, restrictor plates were mandated for the intake, so the route everyone then followed was to increase their rod ratio in the motors which solved both problems, 1) lowering displacement 2) less demand for more airflow in the head
So, once again airflow means nothing, or at least not as important as some may think.
Greg
Old May 22, 2003 | 02:27 PM
  #386
ImportReview
Guest
Posts: n/a
Default Re: B18 - (CHEETAH)
I will continue to buy heads from the guys who have the quickest cars. Luckilly, both of them have flow benches.
They should all have a contest, see who has the most CFM @28 inches.
Some dude shoudl get a bunch of heads together and make a comparision, like the header test last year that SMSP won.
Talk is fine, but real world performance is paramount.
Old May 22, 2003 | 04:11 PM
  #387
jeff,
This is just a guess, .. .. but I asume you didn't read ANYTHING that was posted in respons to your flow question.
What would a CFM contest prove??
Curtis
Old May 22, 2003 | 04:58 PM
  #388
ENDYN's Avatar
The Old One
Default Re: B18 - (Curtis Boggs)
If CFM was "everything", engine builders would strap the heads with the biggest valves and ports available on engines. Unfortunately, while such a combination (could) make a lot of top-end power, the engine wouldn't have enough torque to ever get there.
Any good engine builder can tell you that ports (and flow rates) have to be precisely tailored to the application at hand, and yes, there's certainly such a thing as too much air flow. If you've never had the opportunity to travel back and forth from the grinding/flow bench to the dyno so you can "quantify" numbers and their effects on one another's performance, it's only natural that understanding the relationships in the process would be difficult.....and if you don't understand it, I recommend that become all eyes and ears......
Old May 22, 2003 | 05:12 PM
  #389
ImportReview
Guest
Posts: n/a
just for fun, like a dyno contest, or a drag race contest.
Why are you all uptite man? Who the hell cares?
Dont enter then.
Jeff
Old May 22, 2003 | 09:34 PM
  #390
EFIGUY's Avatar
It would be pretty funny just to see who would join the contest..............all the real head porters who are in the know wouldn't even bother and the wannabe guys with no bench and one carbide burr and a rat tailed file would be flaunting their best stuff for all to see.........
I think it would be wonderful!
stupidity screams, however
Ipso Facto Posse
Old May 22, 2003 | 09:48 PM
  #391
Suprdave's Avatar
Does a Hawaiian-shirt, Dremel tool and a 3-pack of trojans with 2 gone qualify me for this contest?
Suprdave
Old May 22, 2003 | 09:55 PM
  #392
EFIGUY's Avatar
Default Re: (Suprdave)
qualify? Hell sounds to me like you could WIN! Be sure to use the last trojan to cover up your tool though!
Old May 22, 2003 | 09:56 PM
  #393
ImportReview
Guest
Posts: n/a
Default Re: (efiguy)
lol I liked your post. So true.
Personally, I think so many people are scared to put their work (their neck) on the chopping block, that come time for the tournament contest, nobody would show up!
haha.
I would even conduct this contest in a totally unbiased manner. I would love to do that for everyone and post it up. The only problem would be getting a head from Woofer. I don't think he would send me one to test...but he has nothing to worry about....I hope he does well, and I won't bias the test at all, we have used his heads before and they work just fine.
so who would like to participate? I have 2 flowbenches at my disposal anytime I like, I will flow them all at 28 inches....
Jeff
Old May 22, 2003 | 10:02 PM
  #394
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: (ImportReview)
So what does your "non biased" test prove. I think what I would do is pull out my dremel and make huge ports to make the flow look good. Would I win if I have the most flow?
art
Old May 22, 2003 | 11:19 PM
  #395
DohcVtecCrx's Avatar
Default Re: (Arturbo)
Nice article you posted up on the previous page. I saw it a few days ago and wanted to post it up on this thread. Looks like you beat me to it!.
As for the contest why not have say 84 mm bore motor with say probe rods and IMO the best honda piston (IB spec wiseco), jun 3 cams, skunk2 intake mani and a good header and run each head on the dyno in the same car on the same motor. Have like a $150 entry fee. For the time.
Old May 23, 2003 | 05:35 AM
  #396
ENDYN's Avatar
The Old One
Default Re: (DohcVtecCrx)
Sounds unbiased to me.
.....and the winner would receive??
Lessons in part's swapping and religion perhaps?
Modified by Woofer at 3:00 PM 5/23/2003
Old May 23, 2003 | 06:21 AM
  #397
b19coupe's Avatar
Default Re: (Woofer)
Come on guys lets keep it technical. No personal grudges please. There is a lot of good info in this thread, lets not let it degenerate into something else.
I have a technical head porting type question:
GSR engine with 84mm bore-12.5:1 pistons-Intake cam w/12.9mm lift 305 degrees advertised duration, exhaust cam w/11.9mm lift & 315 degrees advertised duration, free flowing exhaust, ITR intake manifold, PR3 (B16) head casting.Looking for max torque/hp at 6,000 to 10,000 rpm. What would the ideal port configuration/valve to seat angle etc. be? Exhaust guides ground down or no? Intake guides-teardrop/ground down/untouched?
Old May 23, 2003 | 06:25 AM
  #398
MAX_CFM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImportReview &raquo;</TD></TR><TR><TD CLASS="quote">just for fun, like a dyno contest, or a drag race contest.
Dont enter then.
Jeff</TD></TR></TABLE>
Instead of a FLOW contest
How about a engine
MAX hp and max torque contest that would be fun
and do the test on a engine dyno
every body bring a 2.0
with there specs no rules
run what ya brung
any compression
any cams header,ect
that would weed out the wana bees
real quick
Old May 23, 2003 | 07:12 AM
  #399
EFIGUY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ImportReview &raquo;</TD></TR><TR><TD CLASS="quote">lol I liked your post. So true.
Ummm, dude...........I was being sarcastic.
Old May 23, 2003 | 07:14 AM
  #400
EFIGUY's Avatar
Default Re: B18 - (MAX_CFM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAX_CFM &raquo;</TD></TR><TR><TD CLASS="quote">
How about a engine
run what ya brung
any compression
any cams header,ect
real quick</TD></TR></TABLE>
It would be fun, but it still wouldn't prove that any one guy's head is any better than the rest.........we all know it's all about the combination, no single part can make the engine a winner..........HP contests are always neat to see though.......
The V-8 guys do 'em all the time.
