Questions on ls vtec turbo.. Help!!
Old Feb 24, 2009 | 03:35 PM
joe0522's Avatar
Default Questions on ls vtec turbo.. Help!!
I am doing a ls vtec. My set up is a b18a1 block and im using stock ls rods with nippon low cm pistons. The head is a b16a head with type r springs and retainers other then that the head is stock. What would i have to do to make sure this set up will last long. I dont have the money to buy aftermarket rods and pistons. So please what do you thing? Will it be safe?
Old Feb 24, 2009 | 03:47 PM
turbod da's Avatar
Default Re: Questions on ls vtec turbo.. Help!!
i would use arp rod bolts,keep the revs below 8000,
and most important have a tuneable ecu and tune it
by a well known and good tuner!
Old Feb 24, 2009 | 04:00 PM
Turbo-LS's Avatar
Rod bolts are a must, any OBD oil pump or and OBD1 vtec oil pump and a good tune it will last. depending on what cams you run will be how high you can rev. I personally wouldnt go over 8500rpm if your looking for longevity but if your running b16 cams it wont really make power that high anyway and no need to rev that high. That combined with a set of headstuds and you will be fine.
Old Feb 24, 2009 | 04:09 PM
joe0522's Avatar
i have arp head studs, stock ls head casket, and gsr cams. now whats a better way to run the turbo oil line and ls vtec oil line? i mean should i just buy a oil sandwitch plate to run both oil lines to it?
Old Feb 24, 2009 | 07:16 PM
418whpturboD's Avatar
no need for sandwich..
Old Feb 24, 2009 | 08:33 PM
joe0522's Avatar
ok cool but were would i but the turbo line and lsvtec line at? so i wouldnt need a sandwich?
Old Feb 25, 2009 | 07:24 PM
joe0522's Avatar
anyone?
Old Feb 26, 2009 | 03:29 AM
Turbo-LS's Avatar
run the oil feed off the back of the block where the oil pressure switch goes, IMO put in a TEE so you can still run the oil pressure switch. for turbo feed you can tee off that again or you can put the oil feed to a port in the side of the head to feed the turbo. either way works.
IMO a sandwhich plate works best but isnt needed
Old Feb 26, 2009 | 05:10 AM
joe0522's Avatar
ight thanks guys
PhrequenC
Feb 24, 2008 03:51 PM
string
Sep 26, 2006 12:31 AM
mike5809
Jun 26, 2003 08:51 AM
ChaseIntegra
Jun 13, 2003 01:36 PM
RSZero1
Nov 19, 2002 06:18 PM
