August FS Thread
Old Aug 27, 2013 | 08:39 AM
  #76
JDM JEFFREY's Avatar
Default Re: August FS Thread
25x8.7x13 mh slicks for sale used for 3 passes
300.00 shipped
Old Aug 27, 2013 | 01:20 PM
  #77
vtecace23's Avatar
All Items are plus shipping and paypal. All are in good working condition. Text at 478-338-2844 for more info. Thanks
Full Blown Hanger with twin walbros, -8 feed -6 return lines with filter $400
B series Moroso Pan $100
Innovative B series Mounts for Ek $200
CX Racing Cast mani for b series $50
GSR Cams with aem gears $150. May seperate
Tial 38mm Wastegate $125
Vibrant B Series Timing Belt Tensioner NEW $100
Innovate LC-1 Wideband NEW $175
LS Eagle Rods $175
Old Aug 27, 2013 | 01:32 PM
  #78
popwars123's Avatar
Means of contact: PM(don't check often) and text 7573429549
Price: $ listed below
Parting out my entire car, setup made 651whp reliably. I priced everything as what I would want to pay for them myself, so no lowballers.
Willing to ship some stuff, but would rather not ship bulky items.
Posting some pictures, but this is a lot of stuff so if there's anything in specific, please ask and I can post.
B18a block: $3300
Darton MID sleeves
O ringed
84mm Manley pistons w/ upgraded wrist pins
Manley turbo tuff rods.
ACL race bearings
Golden eagle main studs and main girdle
Type r oil pump
Morosi oil pan
Ati street damper
Cdi Ignition setup: $ 375
Proven reliable on high hp
Oem distributor wired for CDI setup with external coil cap
Crane ps92 coil
Turbo-Ls igniter delete
Summit CDI ignition box
Comp clutch twin disc $700
Edelbrock victor x intake manifold $240
Turbo kit $ 2000
Top speed performance ram horn
Precision pw46 gate
Tial q46 blow off valve
Precision 6262 journal bearing t4 .68 ar
3" v banded down pipe
Wastegate dump tube
Backdoor inter cooler with 3" cold side piping
Fuel setup $ 1000
Sumped tank using Full-race sump
All black fittings
10 an feed to pump
100 micron filter
Weldon 1100-a pump
10 micron filter
8 an to rail
Bdl fuel rail
Aero motive 1000-6 regulator
6 an return to top of tank.
ID 2000 injectors with clips $700
Full race traction bars $240
Trans (has trouble going into 2nd under power) $ 450
Ctr LSD case
Factory LSD and 4.4 final drive
Gsr gearset
New 4th gear
New 3-4 hardened slider
3-4 carbon synchros
Speedfactory scha
Hasport billet "extreme race" durometer ek mounts $ 300
Shift linkage with skunk2 shifter $70
Omnipower 70mm cast throttle body $ 60
Stack egt gauge $40
Ramey built Catch can setup with lines filters and fittings and valve cover $250
Mishimoto aluminum radiator with fan and shroud $ 200
Golden eagle GSR Headstuds (New black style): 100
Samco hoses $50
Oem halfshaft manual $75
Starter $50
Alternator $60
98 ek shell -$1500
Clean title 14x,xxx miles.
maxworx 6 pt cage, carbon fiber hood (cracked and up pipe hole cut)
Dash and wiring in tact
Dents on fenders
No wiring issues
Black housing headlights
Energy front control arm bushings
Skunk2 drag launch coil sleeves
Obd1 conversion harness included
hx wheels (2 flat tires)
Old Aug 28, 2013 | 06:51 AM
  #79
a1320addict's Avatar
FOR SALE
ProEFI 128 Dealer Box $2220
Haltech K-Series Pro Plug-In $1000
AEM V2 OBD1 Honda $1000
AEM V2 S2000 $1000
MSD DIS-4 HO w/ (4) Blaster SS Coils, Mounting Plate, Harness $550
RacePak IQ3 Logger Dash w/ Smartwire, Switch Panel (NO Cables) $2800
e-mail joel@racespeconline.com
Old Aug 29, 2013 | 03:30 AM
  #80
BILLY_BAD_A$$'s Avatar
AEM AQ-1 Data Logger. Mounted but never used. Includes 18" Flying Lead Wire Harness. $420
Old Aug 29, 2013 | 10:31 AM
  #81
tootski14's Avatar
Honda V2 Drag Wheels With Slicks New 700 plus shipping 35603 Decatur,Al
Brand new set of Honda /Acura V2 Competion wheels with M&H Racemaster Tires. Never used. Wheels are 13x8 and will fit GSR brakes. Tires are 24.5x8.5 13 HB11 compound. 4x100 bolt pattern. May fit other vehicles. Contact me for info. 25647six4one30. tootski14@hotmail.
Old Aug 29, 2013 | 04:53 PM
  #82
SwappedTURBOegg's Avatar
S366 T4 .83A/R ceramic coated 500 or trade for a set or serious cams or twin plate for b series. no fittings included less than 400 miles on the turbo.
contact number 248 660 2221
Old Aug 29, 2013 | 07:27 PM
  #83
paulzy's Avatar
Parting my build because I'm moving on with my life, currently have more important things going on right now than racing. Everything is new unless noted. Posting as many pictures as I have but if you need more, just let me know. Not everything is pictured. I have many vouches if you need them.
'96 JDM ITR head- $1000
prepped for LS/VTEC (welded oil hole, GEM dowel pins)
Ferrea Stainless Steel Valves (STD size)
Supertech Dual Valve Springs (turbo spec)
Supetech Aluminum retainers
Supertech Valve Keepers
new seals and gaskets
valve cover is shaved, painted wrinkle black, and has 2 -16AN ports
Cleaned, resurfaced, machined by DG motors
B18a LS block- $2500
Darton sleeves installed by RS machine
Manley Turbo Tuff rods
Manley 84mm pistons 9.0:1
ACL bearings
polished OEM LS crank
ARP main studs
come with oil pan, ITR oil pump, new seals and gaskets, OEM timing belt, alternator
Cleaned, balanced, machined by DG motors
Golden eagle GSR head studs (torqued once)- $100
Edelbrock victor X manifold for B16/ITR- Sold
Edelbrock victor X 75mm throttle body with vanjen setup welded to inlet w/ adapter for Honda bolt pattern(TB is used, adapter plate and vanjen setup new)- $240
Skunk2 Pro1 camshafts for Bseries vtec(New, installed but never turned on)- $500
Skunk2 Pro series cam gears( new, installed but never turned on)- $200 **pending**
Full Blown B-series fuel rail (powdered wrinkle black)- $100
Garrett 18x12x4.5 Intercooler core- $350
ATI damper (race version, installed but new)- $340
comes with matching alternator belt
OBD1 tuck harness built by thevtecnician- $350
Competition Clutch "C" twin disc for B-series (new, installed but never used/started)-$1000
Racerstev heat treated GSR gear set- $500 **pending**
MFactory LSD for GSR with brand new with new bearings- $650
IPG brake booster delete plate- $50
Magnafuel Prostar Fuel pump (used, part #MP-4701)-$450
comes with -10AN inlet and outlet fittings
Hondata S300 with P28 with all options (new, just bought this from Chris Miller)- Sold
Ebay Aluminum Radiator (used)- $40
Summit slim fan 12" (equivalent to FAL)- $60
Keizer front and rear drag wheels (painted satin black)- $2000
front- 3pc / 13" x 10" / 5" BS / 4x100 / bead lock
rear- 3pc / 15" x 3.5" / 1.75" BS / 4x100
tires are M&H 24.5x9.5x13 front and 24x3.5x15 rear with 4 passes on them
Blox Drag coil over (installed, never used)- sold
DSS stage 5.9 axles- sold
comes with GSR chuckles
new OEM honda pads, new rotors, new lower ball joints, new calipers, and new wheel bearings
Innovative Solid engine mounts for Bseries into EG/DC (used)- $260
price comes with rear T-bracket and LH post mount
GSR OBD2A distributor (OEM, not aftermarket)- $160
NGK plug wires for B-series VTEC (new)- $40 **pending**
Stock LS hydro tranny- $225
1994 Honda civic LX shell- $800
complete minus engine and random MISC parts. minor wire tuck
Caged by Excessive Motorsports in Sioux Falls, SD
minimal rust by rear quarter on RH side
clean SD title ready to transfer
Drag wheels DR-16 bronze- $400
comes with good tires, 15" x 6.5" / 4x100 / 40mm offset
shell:
Old Sep 1, 2013 | 10:22 AM
  #84
561teggy's Avatar
Precision 6265 Dual Ball Bearing vband turbo. Great condition. No shaft play. I had it rebuilt by precision 1000 miles ago. Had a brand new exhaust wheel and new seals put in. Works great: $1300
Tial 44mm Wastegate: $280
Tial 50mm Blow off valve: $180
Fullblown fpr in good condition: $125
AEM Boost solenoid: $50
Fuel Injector Clinic 2150cc Injectors with flow sheet, spacers, and washers: $600
Turbo blanket. Not in the best condition but it works: $30
Push lock wastegate fittings and misc vacuum lines: $30
Oil feed line: $15 Oil Return line: $40 Fittings for oil feed: $15
Custom 3" exhaust downpipe back: $300
Z33 Trans adapter plate with hardware: $350
Old Sep 2, 2013 | 12:37 AM
  #85
wickedEG's Avatar
FOR FASTER SERVICE CALL OR TEXT @ (360) 6three2-nine9seven2
water box 16x12x10 with -16 fittings $180
MSD Pro coil $40
Earls 19 row oil cooler $130
RCI seat belts blue $75 for both
Password JDM LS intake Gasket New $25
Sparco 2" seat belt blue $40
XS Engineering I/C $200
B series axles $60 each
Supertech Valves 1 mm over intake .5 mm over on exhaust $150
CP Pistons 84mm 10:2.1 $200
B series Alternator $80
B16 cams $160 for both
Old Sep 2, 2013 | 10:20 AM
  #86
EKfiend's Avatar
Means of contact: 804 551 8247
Price: $$$$
Description:
I've been considering some different options lately so let's see how this goes. I am in no way at all in a rush to let this stuff go, I'm not even sure I'll sell it if my asking price is met. If I do decide though, the long block will need to be the first thing to go. Unless you see that is sold don't bother asking to buy any of the other parts. I'm only selling this stuff in the order listed. So if item #3 isn't sold for example don't ask to buy item #6 unless you plan on buying #3, 4 and 5 also. I have numerous people that can vouch for all these parts.
#1. Fully built H22A longblock - Motor was assembled about a year ago, since then it has seen 2 dyno sessions, 2 track passes, 10-15 street passes and maybe 600 normal driving miles. I have all paperwork for the motor getting built with all the specs the builder used. Built at Laurel Automotive and has never smoked one bit or had the slightest problem. Car made 490 on 17psi. That is a little over half the potential this motor has. Longblock will come with valve cover, fully assembled head, vtec solenoid, fully assembled bottom end, and oil pan. If it's not listed it's not included.
Head:
Skunk2 Pro 1 Cams
Skunk2 Cam Gears
Skunk2 Springs and Retainers
Brian Crower stock size valves
Supertech valve seals
Bottom End:
Darton sleeved closed deck H22A bottom end
ARP head studs
Cometic stock bore head gasket
CP 9:1 pistons
Eagle H Beam rods
ACL main and rod bearings
ARP main bolts
Kaizenspeed balance shaft delete
Kaizenspeed manual tensioner
Etc:
Valve cover w/ 2 -10an bungs
Gates Racing timing belt
New OEM crank pulley
New OEM idler pulley
I'm probably forgetting a few things but I'll add them as I remember.
$3,000
#2: H22A4 Transmission
OBX LSD w/ 500-600 miles
Brand new OEM diff bearings
No grinds, pop outs, etc.
$600
#3: Golden Eagle Intake Manifold w/ matching fuel rail
Does not include throttle body or injectors
$650
#4: AEM COP Setup w/ Version 2 OBD2A ECU
Has 2 dyno sessions and 50 driving miles on the whole setup
EPM
K series coil packs
Custom Momentum Autoworks coil pack harness
$1,500
#5: Kaizenspeed Forward Facing H22 Manifold
Bought from Reid at Kaizenspeed (Have receipt)
Used for a short time on their H2B EK Hatch
T4
Twin 60mm wastegates
Black ceramic coated
$850
I can be reached at 804 551 8247 for more info or pics
Pictures:
Old Sep 2, 2013 | 01:24 PM
  #87
94turbosi's Avatar
Garret 4294R 128 AR ball bearing with precision billet wheel all heat coated and heat treated Blk coating turbo is in excellent shape no smoke or damage to any of the wheels $1600 plus shipping and 3% Paypal
Dual bosh pump set up with hanger and dual filter and set up -10 in -8 out pumps are farely new upgraded to Weldon pumps are in excellent shape
$500 plus shipping and 3% Paypal
Old Sep 3, 2013 | 10:12 AM
  #88
ShawnR's Avatar
Means of contact: 757-689-0110
Price: $See list
Description: Wilson 80mm Throttle body, we have two, but are being sold individually. $225 ea
-6 Feed & return fuel sys line for a EG hatch, can be modified to work on other honda's. Comes with the Aeromotive regulator. Capable of 600hp. $200
Mishimoto Silicone Radiator Hoses Honda Civic EG/EK (92-00) 40$
Brand new, never been used Meziere Electric water pump, remote mount inline,1 in 1 out, 55GPM, standard motor, black. $375
http://www.meziere.com/ps-1148-1116-wp336s.aspx#
Star Machine Reverse vacuum pump, custom made for a B series, with a mandrel for a ATI dampner- $800
P-tuning Bottom mount turbo manifold-$550
Benefits of the low, bottom-mounted turbo location:
- The turbocharger is situated low and further back in the chassis for better weight distribution and handling.
- The turbo manifold design keeps the hot exhaust runners, down pipe, and turbine housing low to reduce excessive engine bay heat.
- The design also prevents any unnecessary heat soak to the oil filter (factory location).
- Another very important aspect of the low mount design is that it allows us to develop an EXTREMELY high flowing 3” downpipe with only two, VERY low angle bends. This, among other design aspects, greatly contributes to the very quick turbo spool-up and high overall power output.
Turbo Manifold design:
- True Equal Length Design (all runner lengths are within ~ 5/8” of each other).
- Very smooth flowing runner design with gentle radius bends and minimal directional changes. (no tight radius weld-els were harmed in the production of this manifold).
- The full T304 SS construction (including even the CNC-machined head flange) creates what is essentially a rust-free manifold.
- True, symmetrical merge collector (this is not a mini-me style collector).
Old Sep 3, 2013 | 01:12 PM
  #89
therunnerz's Avatar
s2000 drag shell fresh black paintjob new wheels and tires
ford 9 inch rear end 4link...10pt cage hard top etc strange suspension
complete rolling shell with those parts listed $6,000
Turbo manifold sidewinder with dumptubes and downpipe..$900
tial 44mm wastegates x2 $400
t1 custom catchcan with s2000 valve cover $250
s2000 custom Intercooler Garret core ......$500
Turbo400 drag transmission with custom driveshaft and s2000 engine plate
built by rossler transmission pretty much the ultimate auto trans......$3500
Custom radiator with shroud and spal fan with welded bungs ...$250
Will sell all toghether or part out lmk thanks this is the s2k from hell bad *** build and everything was built right serious car here
thanks call or text for questions
Old Sep 4, 2013 | 05:27 PM
  #90
93egboosted's Avatar
What's up HT? Time to partout the car a friend and I put together. All the parts came out of a 99 civic hatch. Car made 760hp @ 32psi on c16. Any questions or if you want more pictures of certain items hit me up 860 301 6150. All prices liste don't include shipping or Paypal fees.
Solid hasport mounts including all the body brackets
$250
Peak boost bottom mount manifold t4 twin tial 44mm flanges includes dp and dumptubes
$750
Steel braided clutch line
$40
Gsr linkage with prothane bushings
$125
Comp twin disc 1500 miles tops!
$800
Golden eagle cam gears b series
Sold
Edlebrock ported intake manifold Blox 76mm tb omni 4bar map golden eagle rail
$425
Full-race pro am traction bar
$250
Mishimoto front mount with piping tial 50mm flange includes tbolts and clamps
$500
Custom catch can setup with all lines and fittings
$500
Also have a fuel system
Ek sumped tank
Aem filters
2 Bosch 044 pumps
Pump relay
T1 clamp
-10 feed
-8 return
Areomative regulator
$1000
Any questions text me 8603016150
John
crazes
Sep 30, 2014 05:18 PM
crazes
Aug 31, 2014 09:17 AM
crazes
Oct 5, 2013 09:41 AM
crazes
Oct 1, 2012 04:14 PM
ahobbs
Sep 1, 2012 07:23 AM
