Sept FS Thread
Old Sep 5, 2013 | 01:18 PM
crazes's Avatar
Moderator
Default Sept FS Thread
Please read the rules for the new thread. At the end of each month this thread will be unstickied, and a new thread created in this one's place. If you haven't sold your parts, you may post them in the new month's thread. DO NOT BUMP THE OLD THREAD
1) This is for RaceCar parts ONLY. No body panels, fenders etc allowed, unless it is a full race front end. ABSOLUTELY NO useless OEM parts!
2) Do NOT repost your thread over and over hoping to get it on a new page. If your parts sell please remove them from your post. If you sell everything off of your list of parts, report your post to moderator by clicking on the just under your user name and we will delete it.
3)You are ONLY allowed ONE post in this thread. If you are found to have more than 1 post, in the FS sticky all of your posts in the sticky will be deleted, and you will be given an infraction. With enough infractions you will be banned
4) NO WTB ADS!
5) NO COMMERCIAL POSTS AT ALL THIS MEANS, IF YOU OWN A SHOP DO NOT POST BRAND NEW PARTS IN HERE
6) Please provide all pertinent information, including price, and try to return pm's.
We will delete any BS we feel does not belong in here
Please try and limit the size and # of pictures you post. using thumbnails would be fantastic.
From this point on, 3-7-2012, any edit mods have to make to these threads, will result in sanctions. if it persists, the stickies will disappear for good. THIS WILL BE ADHERED TO. No more warnings
EVERYTHING HAS TO HAVE PICS NO exceptions
Old Sep 5, 2013 | 01:34 PM
sohctodohc's Avatar
Default Re: Sept FS Thread
Meziere water pump with lower radiator hose already cut original mount and our own custom mount.
Also comes with water pump delete idler. Everything is for a h-series.
Less then 100 hours on it, only used for half a track season.
Brand new these go for 440 brand new with out lower hose.
Willing to let it go for $350 plus shipping and pp fees
Old Sep 5, 2013 | 01:54 PM
kte324's Avatar
Some left over parts I have for sale. Please make reasonable offers.
Pm me or call/text me if you have any questions or need more pictures. 706-627-9865
*Interested in trades for EG/DC V6 swap parts...mounts, axles, etc.*
- NEW H22 F20B Supertech Springs & Retainers P/N: SPRK-H1005D $275 OBO
- NEW H22 F20B AEM Camshaft Gears $160 OBO
- NEW KS Tuned Kaizenspeed Manual Timing Belt Tensioner $100 OBO
- B-series Vtec Valve Cover w/ Spark Plug Cover Make an offer
- NEW Omni 5 Bar Map Sensor $75 OBO
- NEW Vibrant 3" Silicon Couplers $10 OBO
- NEW Vibrant Performance Intercooler Core 12832 $200 OBO
Old Sep 5, 2013 | 02:20 PM
Turbo-LS's Avatar
All prices are OBO and do not include shipping or paypal fee's. Text me at 203-410-2574 or PM me on here. Thank you
3" downpipe with vband flange and clamp comes with vband to 5 bolt convertion for top mount manifold. $150.00
Precision turbo .63 5 bolt turbine housing for 66 exhaust wheel $100.00
RCI 2050D 5 Gallon Fuel Cell with straps and misc -8 fittings and vent tube $100.00
EMGO Carburetor Syncronizer BNIB $75.00
BNIB JE Pro Seal Piston rings 81.5mm bore JG1004-3209 $100.00
Old Sep 5, 2013 | 03:02 PM
SPOOLINmatt's Avatar
706-346-6024
matt.stover@comcast.net
AEM TruTime Cam Gears, BNIB: $175 Shipped
MSD Digital 6: $200 Shipped
MSD Blaster SS Coils: $30 Shipped EACH, $50 for Both
Aeromotive Pro Pump - $525(On Hold until November)
-Custom Forward Facing Turbo Manifold, Selling for someone else, test fitted on my car to show pictures. Fabricated by Joe Simpson at Tempest Racing.
-Friend purchased it and then shipped out to Japan in the USAF...
With 4" SS Downpipe
Flanged for 60mm Tial
$875.00 OBO!!
Old Sep 5, 2013 | 03:04 PM
BADGUYNY's Avatar
B series divided bottom mount manifold. Flanged for 38mm mvs wastegates. Excellent quality manifold, great welds and material used is the industry standard. Manifold is same quality as many of the top companies. Asking $500 NO TRADES NO TRADES AND NO TRADES
(718) 413-6348
TEXT ME ONLY IF CASH IN HAND
Old Sep 5, 2013 | 03:14 PM
Blown90hatcH's Avatar
FS: Mil-Spec B-Series engine harness out of my 2000 Civic race car. All DR-25 Raychem heat shrink and adhesive lined heat shrink. Mil-Spec Teflon coating wiring. Most sensors identified with Raychem yellow labels with clear shrink. OEM, Deutsch, Bosch, GM, etc. connectors...all brand new, new OEM pins, etc. when I built it. The car had an OEM cluster in it so the harness comes with extra wires on the Deutsch connector for the dash indicators. I will provide a complete wiring pinout for all the sensors. Comes with OBD1 ecu connectors, but they can be changed out if needed. It has been wired for additional Bosch/AEM pressure sensors but also includes all of the following sensor plugs wired in:
OBD2 Alternator
OBD1 Distributor
Fan Switch
Starter Solenoid
Dash Water Temp
Engine Coolant Temp
VTEC Solenoid
VTEC Pressure Switch
Ground
Bosch MAP Sensor
Honda TPS
Turbo Compressor Pressure Bosch Sensor
Turbo Exhaust Back Pressure Bosch Sensor
Crank Case Pressure Bosch Sensor
VSS
Oil Pressure Bosch Sensor
Dash Oil Pressure Light
Intake Air Temp Honda
Injector Dynamics ID1000 Injectors
Fuel Pressure Bosch Sensor
OBD1 ECU
I can add a charge harness for an additional $40 if needed.
Sold
Old Sep 5, 2013 | 05:18 PM
94turbosi's Avatar
Sold
Old Sep 5, 2013 | 06:46 PM
DDTECH's Avatar
FS:
Accufab 90MM Mustang Flange Throttle body. Will come with brand NEW TPS and BRAND NEW IAC Block off plate/gasket. TB is BRAND NEW, was mounted up, that's it.. Asking 285 shipped, which is a steal.FIRM.
screen shot
screen shot
image hosting
image upload no ads
Prototype H22 Cams I've designed for a shelf profile. Cams are ment to be a great upgrade for Stock block h22 setups or mildly built h22 setups. Specs are as followed:
.488 valve lift with 266 duration on intake
.475 vlave lift with 260 duration on exhaust - 600 shipped
lightshot free download
screencapture
screenshot captor
Email: Derek@DDTECHCAMS.com
Cell/txt - 225-384 1 Four Four 1
These cams were dyno tested, results are posted on Honda-tech, up to a 20+whp expected on just DROPPING in.
Old Sep 5, 2013 | 07:19 PM
CDizzle_996's Avatar
BWR D Series Ramhorn
Two bolts seized and broke in this were unable to be pulled out. The holes will be drilled bigger and a nut/lock washer will be needed. It'll still work 100%.
$325 + shipping.
Old Sep 5, 2013 | 08:13 PM
TeagueSpeed's Avatar
Dual Bosch 044 fuel pumps with MB racing dual pump brackets. One pump has inlet and outlet fittings....$300 shipped.
FAST wideband controller w/ sensor....$50 shipped
Old Sep 5, 2013 | 08:30 PM
MoiMotorsports's Avatar
im selling my car 1995 civic ex coupe it use to race in Florida i have a Florida title to it the car as raced its whole life it only has 35k miles on title
i can sell it as turn key i would like to sell the rolling chassis im not in a rush to sell it want to do a rwd car if this dose not sell i will convert it or make it a street car... u can use this car for pro stock like i did in 2011 2012 or a 11.50 index 10 o index u can put a stock gsr in it and it will go 11.50 weigh with a b swap is 1680 it the roll cage mild steel so if u were to change it to chrome molly u can save more weight. i installed the kens kustom straight Axel setup and u can make alot of adj with that where u can change the wheel base so it will 60ft better i has wheeli bars all the windows plexi glass from the company fall (everything in the car there are no short cuts or cheap parts
the price on the car is obo i can take parts off if u don’t want certain things
all u will need is your swap and u can go racing $7,000 i can take off alot stuff where i can just sell u the body i willing to work out a deal even trade for a 99 00 civic si or a fox body mustang or a clean crx
(856) 332-5450 text or call
i will also part the car out so if someone is interested on the car it will be cheaper if some on buys parts off it
kens kustom 4 link with weld racing 5 star wheels with aero space brakes 3,500
nitro 5 gallon fuel cell brand new never used $300
skunk 2 pro upper control arm $200
function forum 2 1 pieces suspension with drag springs $500
nos dry direct port kit $450
edelbrock wet direct port kit $400 still in package
13to1 wiseco gas ported lsv motor with a fully built gsr head ferrea comp plus valves std size springs retainers keepers all matching with electric water pump (can sell with out take $350 off price) motor is assembled with honda bearing has less then 2hours on it
$6000 i can tear it down to show u that its ready to go...
22t water pump electric b18 gsr $300
willwood clutch mater cylinder from kens kustom $80
full hydro b16 trans with quafie gear set with diff and all new honda bearings and synros $4800price drop to 3500
(856) 332 5450
Old Sep 5, 2013 | 09:26 PM
laosonick's Avatar
Used: B Series CC Twin Disc, no track miles, just dyno miles, and like 50hwy miles.
paypal only, will ship tomorrow.
$475firm. paypal email is sourivong79@gmail.com
FLYWHEEL is not included!
Old Sep 5, 2013 | 11:39 PM
SwappedTURBOegg's Avatar
S366 T4 .83A/R ceramic coated 500 or trade for a set or serious cams or twin plate for b series. no fittings included less than 400 miles on the turbo.
contact number 248 660 2221
Old Sep 6, 2013 | 04:01 AM
mikey roman's Avatar
Got Spinwerkes 15"x3.5" skinnies for sale
THIS IS FOR JUST THE SKINNIES!!! FRONTS WERE ALREADY SOLD!!!
NO TIRES JUST RIMS!!!
They are 5x114.3 Lug Pattern
Skinnies were just mounted but none were ever used.
They fit on my RSX and I'm sure they would fit and 06 and up SI along with an ITR.
Selling because I decided to change up my wheels
$500 OBO, message me on here as I check frequently. Thanks
[IMG][/IMG]
Old Sep 6, 2013 | 05:01 AM
rota92
Guest
Posts: n/a
All gone
Thanks!
Old Sep 6, 2013 | 11:10 AM
SpeedFactoryRacing's Avatar
Competition Clutch B Series Level C twin disc for sale. Just sent back to Comp for inspection and testing, new discs were installed. Clutch has 10 passes since the work was done. Comes with flywheel bolts and release bearing as well.
Asking $750
Old Sep 6, 2013 | 01:49 PM
EF'n Sedan's Avatar
Sold
Old Sep 6, 2013 | 02:18 PM
FaceTuned's Avatar
Contact: Tony@facetuned.com
Pay pal: ^^^^^same as above^^^^^
BUYER COVERS PAYPAL FEE'S
PRICE: = $1000 + Shipping
[/I]
I got a full set of slicks / skinny's For sale
[/B]
Bogart 13x8 rims with i believe is a 4.5 or 5" back spacing they fit my integra,
the rims are already drilled and screwed(bead locked) and have some M&H
Race masters mounted front and back.
front need to be changed there's just to many passes on them.
Pm / e-mail or call me to purchase.
[I]
http://www.flickr.com/photos/101539116@N03/9713723842/http://www.flickr.com/photos/101539116@N03/9713723842/ by http://www.flickr.com/people/101539116@N03/, on Flickr
http://www.flickr.com/photos/101539116@N03/9713721308/http://www.flickr.com/photos/101539116@N03/9713721308/ by http://www.flickr.com/people/101539116@N03/, on Flickr
Complete MSD Ignition. Blaster II coil , Digital 6 , and OEM gsr distributor OBD2.
Asking $400 + shipping
http://www.flickr.com/photos/101539116@N03/9710487685/http://www.flickr.com/photos/101539116@N03/9710487685/ by http://www.flickr.com/people/101539116@N03/, on Flickr
GE FUEL RAIL / FIC 1600cc injectors(low impedance).
FJO INJECTOR DRIVER COMBO
$300 SHIPPED.
http://www.flickr.com/photos/101539116@N03/9713722634/http://www.flickr.com/photos/101539116@N03/9713722634/ by http://www.flickr.com/people/101539116@N03/, on Flickr
http://www.flickr.com/photos/101539116@N03/9713723418/http://www.flickr.com/photos/101539116@N03/9713723418/ by http://www.flickr.com/people/101539116@N03/, on Flickr
ITR VALVE COVER CUT
Asking $75 + shipping
http://www.flickr.com/photos/101539116@N03/9710486005/http://www.flickr.com/photos/101539116@N03/9710486005/ by http://www.flickr.com/people/101539116@N03/, on Flickr
http://www.flickr.com/photos/101539116@N03/9713725288/http://www.flickr.com/photos/101539116@N03/9713725288/ by http://www.flickr.com/people/101539116@N03/, on Flickr
MAC BOOST SOLENOID - specifically for use with boost by gear or wheel speed. aem , s300 , motec , ectune, neptune etc... whatever you got that supports it.
ASKING $45 SHIPPED I GOT ABOUT 6 OF THESE LEFT.
http://www.flickr.com/photos/101539116@N03/9713725994/http://www.flickr.com/photos/101539116@N03/9713725994/ by http://www.flickr.com/people/101539116@N03/, on Flickr
CHIPPED P28 ECU WITH ANY BASE MAP NEEDED
$150 SHIPPED
OBD2B - OBD1 JUMPER HARNESS
NEW $85 Shipped
vibrant oil return line flange - 1/2npt threads
$25 shipped
http://www.flickr.com/photos/101539116@N03/9713726510/http://www.flickr.com/photos/101539116@N03/9713726510/ by http://www.flickr.com/people/101539116@N03/, on Flickr
OBD2B - OBD1 JUMPER HARNESS - 99-00 CIVIC / INTEGRA
$50 SHIPPED
BLOX OIL FILTER SANDWICH ADAPTER - B,D,H,F,K SERIES MOTORS
$40 SHIPPED
http://www.flickr.com/photos/101539116@N03/9710491581/http://www.flickr.com/photos/101539116@N03/9710491581/ by http://www.flickr.com/people/101539116@N03/, on Flickr
X 4 ARP EXTENDED STUDS 4 PACK - CIVIC , INTEGRA , ACCORD
$20 SHIPPED EACH
http://www.flickr.com/photos/101539116@N03/9710491419/http://www.flickr.com/photos/101539116@N03/9710491419/ by http://www.flickr.com/people/101539116@N03/, on Flickr
X3 - ARP ROD BOLT SET FOR B18A/B - B20 / D16 MOTORS
$40 SHIPPED EACH
http://www.flickr.com/photos/101539116@N03/9713720710/http://www.flickr.com/photos/101539116@N03/9713720710/ by http://www.flickr.com/people/101539116@N03/, on Flickr
Selling a brand new Turbo manifold. Built in house and constructed of
sch10 304ss
with all CNC'D flanges.
B-SERIES RAM HORN
T3 FLANGE / 38MM WASTE GATE FLANGE
SCH10 304SS TIG WELDED IN HOUSE.
ASKING $500 + Shipping
http://www.flickr.com/photos/101539116@N03/9710493735/http://www.flickr.com/photos/101539116@N03/9710493735/ by http://www.flickr.com/people/101539116@N03/, on Flickr
http://www.flickr.com/photos/101539116@N03/9710493543/http://www.flickr.com/photos/101539116@N03/9710493543/ by http://www.flickr.com/people/101539116@N03/, on Flickr
Collector welds
http://www.flickr.com/photos/101539116@N03/9710493309/http://www.flickr.com/photos/101539116@N03/9710493309/ by http://www.flickr.com/people/101539116@N03/, on Flickr
Some Welds
http://www.flickr.com/photos/101539116@N03/9710493077/http://www.flickr.com/photos/101539116@N03/9710493077/ by http://www.flickr.com/people/101539116@N03/, on Flickr
Give me a call or e-mail
regards,
Tony
Old Sep 6, 2013 | 06:32 PM
rogueeg6's Avatar
Everything is unused unless stated otherwise. Only put in for mock up.
JoJo/Strada Eg 3 peice front. Bought in 2010 never saw any action. Was fit to oem quality and all the fiberglass waves removes for a nice clean look. front is drilled to use Dzus fasteners on the corners. Located in the Pittsburgh area. Can drive some to meet or set a date to get it to the Baltimore area and or Columbus is as far as im willing to go. CAN BRING TO WCF!!!
1000$ OBO
15x8 Exospeed/Nitro Star 8's and rears 15x7 will separate and can get centers recoated. 900$obo for the set. 500$fronts 300$ rears. No tires.
600$obo 800$/all 3 dump tubes. Go Autoworks T4 Top Mount manifold. 44mm waste gate flange. Coated to match turbo. Can come with under car Wastegate dump. 3" hood exit down pipe. 3" under oil pan down pipe for use with your own exhaust. All are coated to match the turbo.
300$ obo 44mm Tail Wastegate black in color. Coated to match turbo.
200$ obo Tial Q Bov
500$obo Double back door Go Autoworks IC using VanJen clamps. Bov flange located on IC. 24x12x3.5 Turbonetics core. Can include charge pipe to TB.
500$ obo All In Fab intake manifold. B16/TypeR flange. Fully polish. Mustang style or OE Honda TB flange.
60$ obo Electronic boost controller w/mil spec connector. Will include male end with long pigtail.
400$ Bosch 2000cc injectors. Never used. Comes with pigtails.
Golden Eagle scatter shield 150$
BDL Cam gears 100$ can come with REAL arp hardware for 130$
50$ Hard Race EG/DC camber kit. Never used.
Old Sep 6, 2013 | 06:42 PM
93egboosted's Avatar
What's up HT? Time to partout the car a friend and I put together. All the parts came out of a 99 civic hatch. Car made 760hp @ 32psi on c16. Any questions or if you want more pictures of certain items hit me up 860 301 6150. All prices liste don't include shipping or Paypal fees.
Solid hasport mounts including all the body brackets
$250
Peak boost bottom mount manifold t4 twin tial 44mm flanges includes dp and dumptubes
$750
Steel braided clutch line
$40
Gsr linkage with prothane bushings
$125
Comp twin disc 1500 miles tops!
$800
Full-race pro am traction bar
$250
Mishimoto front mount with piping tial 50mm flange includes tbolts and clamps
$500
Custom catch can setup with all lines and fittings
$500
Also have a fuel system
Ek sumped tank
Aem filters
2 Bosch 044 pumps
Pump relay
T1 clamp
-10 feed
-8 return
Areomative regulator
$1000
Any questions text me 8603016150
John
Old Sep 6, 2013 | 06:59 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
STR intake manifold for b16 some scratches needs to be polished two top throttle body holes need to be re threaded comes with all sensors $400 plus shipping 8503459689
Old Sep 6, 2013 | 08:14 PM
kartunezgsr's Avatar
Full catch can setup with valve cover 6 -10an lines black catch can with two filters and b series valve cover askin $400 Obo
Old Sep 7, 2013 | 05:59 PM
hondacivic946's Avatar
Whats up H-t im parting out my turbo civic let me know what you want to buy
Aem boost cel 75obo
Cp 84mm 9to1 300obo
eagle ls rods 150 obo
hondata 4 bar 75obo
m&w pro 10 kit 500 obo
skunk2 pro series contraol arms 175 obo
Last edited by hondacivic946; Sep 26, 2013 at 11:32 AM. Reason: still some good parts left
Old Sep 8, 2013 | 12:18 AM
wickedEG's Avatar
FOR FASTER SERVICE CALL OR TEXT @ (360) 6three2-nine9seven2
fluiddamper $280
Honda CBR coils $80
AEM Twin Fire ignition $280
Golden eagle GSR head studs $80
water box 16x12x10 with -16 fittings $180
MSD Pro coil $40
Earls 19 row oil cooler $130
RCI seat belts blue $75 for both
Password JDM LS intake Gasket New $25
Sparco 2" seat belt blue $40
B series axles $60 each
CP Pistons 84mm 10:2.1 $200
B series Alternator $80
B16 cams $160 for both
