Sept fs thread
Old Sep 1, 2012 | 01:43 PM
crazes's Avatar
Moderator
Default Sept fs thread
Please read the rules for the new thread. At the end of each month this thread will be unstickied, and a new thread created in this one's place. If you haven't sold your parts, you may post them in the new month's thread. DO NOT BUMP THE OLD THREAD
1) This is for RaceCar parts ONLY. No body panels, fenders etc allowed, unless it is a full race front end. ABSOLUTELY NO useless OEM parts!
2) Do NOT repost your thread over and over hoping to get it on a new page. If your parts sell please remove them from your post. If you sell everything off of your list of parts, report your post to moderator by clicking on the just under your user name and we will delete it.
3)You are ONLY allowed ONE post in this thread. If you are found to have more than 1 post, in the FS sticky all of your posts in the sticky will be deleted, and you will be given an infraction. With enough infractions you will be banned
4) NO WTB ADS!
5) NO COMMERCIAL POSTS AT ALL THIS MEANS, IF YOU OWN A SHOP DO NOT POST BRAND NEW PARTS IN HERE
6) Please provide all pertinent information, including price, and try to return pm's.
We will delete any BS we feel does not belong in here
Please try and limit the size and # of pictures you post. using thumbnails would be fantastic.
From this point on, 3-7-2012, any edit mods have to make to these threads, will result in sanctions. if it persists, the stickies will disappear for good. THIS WILL BE ADHERED TO. No more warnings
EVERYTHING HAS TO HAVE PICS NO exceptions
Old Sep 1, 2012 | 01:51 PM
josh green's Avatar
Default Re: Sept fs thread
706-266-7294
Built K24 Shortblock and Stock TSX Head.
Block: Machine work by CNC Engine Dynamics - Assembled by Mike at Charm City Tuning: 99mm crank, 87.5mm Custom CP 12.5:1 pistons with undersize wrist pins, Blueprint PRO-IBeam rods. ACL Race STD HX sized bearings, soda blasted block, block deck machined
Head: TSX stock head with stock valve train and valve cover
Will trade for B series parts.
Price:
SOLD
Block pic
Head Pic
706-266-7294
Old Sep 1, 2012 | 02:13 PM
GT30EK's Avatar
3 Inch SS Exhaust with Magnaflow muffler for Ek Hatch 200 Pick up ONLY located on Long Island NY.
FJO Wideband with NTK Sensor 100 Shipped
Includes Controller, 4ft sensor wire, and NTK sensor. All perfect working shape
Old Sep 1, 2012 | 02:27 PM
FRernesto's Avatar
F/S Used Precision billet ball bearing 6765 turbo. The turbo is in great condition and has no issues what so ever. Could say "like new" 1000.00
-Borg Warner turbin housing Twin scroll 1.10ar for S400SX 71mm turbo. 115.00 New never used!
-Injector resistor box plus OBD1 injector clips. (USED)25.00
-MF2 Mappable Injector Driver can control either additional fuel injectors or water injection and 2bar map sensor. Instructions included (USED) Make an offer...
Old Sep 1, 2012 | 02:43 PM
Andy@AMR's Avatar
New Skunk2 Pro1 Series Cams. Installed, but never ran. Too much cam for me. ZERO miles. 550 shipped.
Skunk2 Pro-Series Front Camber Kit EK. This was installed, but never ran on the street. They are pretty much new, like the cams. Boots are perfect. 155 shipped.
Trades considered are chipped P28, Neptune RTP, AEM Boost Gauge, AEM Oil Pressure Gauge, 1999-2000 Civic Rear Left Inner Tail lights, and Right Outter Tail Light, 99-00 Civic Passenger Headlight, CTR EK9 Cup Holde, Hondata S300..+cash depending on what you all got.
Old Sep 1, 2012 | 02:47 PM
JDM JEFFREY's Avatar
ID 725cc injectors
With b top hats and chips
300.00+ shipping
Will have better pic tonight
Old Sep 1, 2012 | 02:59 PM
kte324's Avatar
1993 Civic CX
- Clean Title
- Chromoly 10 Point Roll Cage built to NHRA Specifications
- Koni Yellow Suspension
- Omni Rear LCA
- Moroso Toggle Switch Panel
- Autometer Tach, Oil Pressure, Water Temp, & Vac/Boost Gauge
- NGK AFX Wideband
- RCI Aluminum Drag Seat on Honda Rails
- RCI Seatbelt Harness
- RCI 5 Gallon Fuel Cell
- -8an Fuel Feed Lines & -6an Return Lines
- Fuel lines/wiring setup to run dual Bosch Pumps
- Extended Studs, New Front Wheel Bearings & Ball Joints
- Energy Suspension Bushings
- B/D Engine harness
- Battery Box & Cut-off Switch
- Front Brembo Blank Rotors
- Oem Radiator & Extra Driver's side fender
Make an offer. Please PM or Call/Text 404-637-6073 for more info or pictures.
More info and pictures of the car can be found here: http://hondamarketplace.com/showthread.php?t=3081727
Old Sep 1, 2012 | 03:02 PM
legomytego's Avatar
k20z1 parts for sale email me for fastest response vdodd45@yahoo.com
all parts located in md eastorn shore willing to drive to meet up or ship at your expense all parts are obo
k20z1 block 86.5mm bore fresh from the machine shop $300 have oil pan front cover and other random parts.
k20z1 crank micropolished/inspected $200
cp pistons 9.0.1 86.5mm brand new $500 thease are $600+ new
eagle h beam rods brand new $290 i have new acl rod bearings i can include
will sell everything for $1100 all machine work was done by justice racing thru tempest racing.
Old Sep 1, 2012 | 03:52 PM
ls_on_boost's Avatar
sold
Old Sep 1, 2012 | 06:07 PM
SynTeg's Avatar
I accept paypal only. Email me at SynTeg@gmail.com for inquiries.
Brand New ASP Aluminum Catch Can Kit V-2
Catches excess build of carbon and sludge from both your engine and intake with a total volume of 2qt 18oz. No need to move your battery, this aluminum catch can kit fits perfectly in your old battery location. Kit includes ASP aluminum oil catch can, a Fullriver HC680 battery, and an aluminum ASP tie down.
$325 shipped
B&R Catch Can AN Fitting Kit (Black)
1 - 10ft Pro Lite 350 Hose
10 - AN Straight Swivel Seal Hose End (black)
2 - AN 10 90degree Swivel Seal Hose End (black)
1 - AN Hose Separator (black)
$150 shipped or $425 shipped with ASP Catch Can Kit above.
1995 Honda Civic DX Hatchback Rolling Drag/Street Shell
Located in Las Vegas
$4000
- FRESH Acura NSX Monte Carlo Blue Pearl multistage paint job
- Strada Ind 3 Piece Front End with fender vents
- 10 Point Custom NHRA Legal Spec Chromoly Roll Cage done by ForceFed Performance painted gunmetal
- Parachute Mount
- Fuel system - Sumped tank with Magnafuel Pump and -8an lines (good for 800+whp)
- SkinnyKids fab traction bar
- Complete exterior (lights etc) and Full interior with Del Sol seats
- Extended wheel studs
- Shift Linkage
- XXR 15" Wheels with 90% left tires all around
- Brand new windshield installed
- Carbon Fiber rear Wing
- ASP rear bumper Diffuser
- Plus many other parts i'm probably forgetting.
Old Sep 1, 2012 | 07:29 PM
TegraGSXR's Avatar
All items have less than 5000 miles. Prices are or best offer. More items listed at http://hondamarketplace.com/showthread.php?t=3080308
Clutch Master twin disc for 90-91 integra, B series small spline- $500
Golden Eagle vtec b-series head studs, torqued twice- $75
B series vtec valve cover with two -10 bungs- $75
xenocron OB0-OB1 adapter harness- $75
Single backdoor intercooler core size is 4.5x9.5x21
Old Sep 1, 2012 | 10:44 PM
nycvr6's Avatar
For sale: Brand New Precision 7175 Ball Bearing Turbo
Turbo was only used for fitment, no oil or exhaust ran through the turbo. The compressor inlet is the 4" anti surge and is machined smooth and there is 4" bell mouth on it, the outlet has a 3" wiggins ferrule welded to it, brand new wiggins clamp included. It will come with both a .81 and a .96 T4 turbine housings, both brand new as well. This turbo goes for over $2200 with one turbine housing, I am only asking for $1750 for everything here. Best way to contact me is by email at nyvrsixxx@aol.com , or you can message here, but it may take longer to get back on here. Here are some pictures.. Thank you for looking!!!
Old Sep 2, 2012 | 06:19 AM
Turbo-charged's Avatar
precision 750hp intercooler $350
aluminum radiator with fan $150
15" rota track r's. about 20 miles on them with brand new nitto tires $700
3" skunk 2 exhaust $375
aem fuel rail $65
clean freshly painted shell with 10pt chromolly cage $3500
b18c5 block- sleeved, 9:1 pistons, rods, cams, springs, retainers, ported head, arp's, etc. $3750
Old Sep 2, 2012 | 07:56 AM
boostedhfrex's Avatar
FS
-Aem ems series 1, obd2a but comes with a obd2-obd1 jumper for eg guys $600
-AEM epm, new $250
-Rywire coil on plug plate for b16/gsr head bnib, $80
-Moates ostrich romulator 2.0, best offer
-hydro b16 trans, needs 3rd, best offer (local pickup)
-yonaka h22 eg/dc mounts bnib, $80
Old Sep 2, 2012 | 09:39 AM
artie89's Avatar
FULLBLOWN DUAL FUEL PUMP SET UP WITH TWO WALBRO 255 8AN FEED
6AN RETURN - 400 SHIPPED
BUYER PAYS 3% PAYPAL FEE
Old Sep 2, 2012 | 10:52 AM
Kyle R's Avatar
Means of contact: PM or email (kyle.ritchie@gmail.com)
Method of payment: Paypal (or cash in person)
FS: Precision T4 6262 (.60 A/R comp; .68 A/R exhaust) with "E" cover (3" inlet; 2" outlet)
1k miles on the turbo. I'm selling to offset the cost of my new BW turbo. The turbo has zero in/out shaft play and minimal side to side shaft play. I put down 475whp with this turbo @16psi.
$600 shipped OBO
FS: Precision 600hp intercooler (painted flat black using Eastwood radiator paint) with 1k miles
$300 picked up (local pick only)
Old Sep 2, 2012 | 10:59 AM
rudebwoy's Avatar
Summit racing 5 gal fuel cel $110 shipped
Kirkey racing seat with cover and custom eg bracket $160 shipped
peakboost 3" top mount downpipe with cutout $120 shipped
custom topmount 3" race downpipe with vibrant muffler 2 bungs $100 shipped
3" cold side charge pipe backdoor with vband flanges and tial bov flange $70 shipped SOLD
3" muffler new $60 shipped
3" vibrant muffler/resonator $80 shipped
3" rice chamber $40 shipped
3" custom vband test tube $55 shipped
Tein basic coilovers used with eg hats. surface rust removeable. $450 shipped
HPS cold air intake pipe $60 shipped
CX racing oil cooler kit and new oem filter, test fitted but never used $120 shipped
D series cast t3 manifold $60 shipped
blox 76mm td with vband, no map sensor port $120 SOLD!
used mfactory shaft brace cuff with new shims $130 shipped
PTE 1600cc injectors and FJO driver package deal. $300 shipped
momo steering wheel and hub $120 shipped
autometer carbon fiber speedo 3 3/8 $160 shipped
autometer carbon fiber tack 3 3/8 $130 shipped
autometer carbon fiber volt gauge 40 shipped
autometer carbon fiber fuel level works with oem sending unit. $90 shipped
black anodized bezel rings fits the above gauge sizes. $25 each
Virgin p28 ecu $110 shipped
44mm straight dump tube $25 shipped
OEM fuel tank straps new EG $30 pair shipped
Old Sep 2, 2012 | 11:13 AM
Jdmsolutions's Avatar
1600cc injectors and FJO driver- 180shipped
Garrett T4/T67(runable but could use a new ex wheel)-150+shipping
pm or txt (406)670-8840 ask for pics
Old Sep 2, 2012 | 06:07 PM
Jas9848's Avatar
Spinwerks 13x8 powder coated black with Mickey ET Drag 24.5x9 slicks. $600
Located in MD, can ship at buyer's expense.
Old Sep 2, 2012 | 06:45 PM
b-built's Avatar
15" spinwerk rims powder coated white and black m/h 26x10 slicks rims and tires $500 paypal and shipping not included 516-403-7564
Old Sep 3, 2012 | 08:29 AM
deeh22bubble's Avatar
Crx subframe with rack n control arms $100
Crx aftermarket front n rear sway bars $200
Brand new blk housing head lights eg $75
Brand new carbon fiber duck bill $100
Used 50/50 tail lights $30
Complete heater box eg $40
Thanks u can call or text me at(917) 662-7295 thanks
ashtons300zx's Avatar
Up for sale are my ID2000's for a B-Series. These are basicly brand new, only a couple months old. They were ran just on the dyno and several passes down the track and thats it. The tophats are anodized black. Comes with pigtails. They were pulled off the rail so they didnt sit with fuel in them and have only sat for the last month. Used c16 fuel only with these. Asking $750 shipped for them.
Also have a T1 Race Developement Exhaust Backpressure buffer kit, comes with the SS line with -3 fittings. Canister done in Wrinkle Black. Asking $75 shipped
Black T3/T4 turbo blanket. Works great and comes with the securing springs. Only a month old and barely used $60 shipped
Old Sep 3, 2012 | 10:16 AM
SPOOLINmatt's Avatar
706-346-6024
matt.stover@comcast.net
Liberty's Gears 1st generation 3rd gear, countershaft side, 34 teeth, 1.36:1
I no longer need to keep it as a spare
$100 OBO
Set of 3 used manley rods(NOT TURBO TUFF) - 5.430" length for B18C1 GSR Crank. $85
706-346-6024
Old Sep 3, 2012 | 10:17 AM
fresh_manny21's Avatar
$875 Shipped
New never used
Picked up for my street car but had a change of plans
Blackworks K-Series T4 Twin Scroll Turbo Manifold (Dual 44mm wastegates)
Contact info:
mannyxp21@gmail.com
or send pm
http://www.bwrusa.com/product_p/bwtm-k-ts-44.htm
Old Sep 3, 2012 | 01:07 PM
evilone's Avatar
Brand new competition clutch kit, 4 puck unsprung. For k series part # Stage 5 K20 RSX Civic Si 8037-0420, paid 425 will let it go for 350 shipped
